wood stoves
/ wood stoves #21
Not only does it matter to the insurance companies, but if your house burns down and it is traced back to the pellet stove your insurance might not pay if you haven't informed them of the stove.
Most likely your insurance company will want the installation signed off by a licensed furnace installer before they will insure it.
Good Luck. Been there. Your turn.
"Permits?? I don't need no stinking permits!!"
/ wood stoves #22
I've had a VC stove in the basement for a few years and now have a Waterstove 200' from the house.
No smoke, no wood in the house, no mess to clean up, no ashes to clean out, and can heat the whole house.
Ok, a little more $$ up front, but consider the ++'s.
OBTW. make sure your chimney is sized/speced for the stove. I will NEVER have another chimney system without a Stainless Steel lining flu.
gary
/ wood stoves #23
Is this really the case. Does everyone with a stove have it covered with a homeowners waiver or something.
/ wood stoves #24
My insurer requires an annual inspection/cleaning by a sweep on their list of approved contractors, no extra cost to the policy itself. You'll definitely want to declare the stove and find out what specific requirements or writers they might need.
I'll gladly pay once a year to let someone else climb 10' over an already 30' tall roof to clean it out from the top, then I just clean it out the best I can from the bottom every month thereafter.
/ wood stoves #25
I think there is a big swing on what insurance companies require as far as woodstoves. When I bought my house 6 years ago, I had to change insurance companies as the one I had would not insure woodstoves period.
The company I went with didn't even blink when I told them I had a homemade woodstove. They covered me for 6 months before the guy came out and looked at it. BTW I have since bought a Lopi Liberty to replace the homemade job and I now burn half the wood. These new stoves are really a lot better.
/ wood stoves #26
We are about to change from an insert, Buck Stoves, to a free standing stove as part of a remodel. The Jotul Firelight, catalytic converter and about $2500 six years ago, we use at another house has just been great so I figured I would go that way again. Now you guys have reminded me that I have read some good things about the soapstone stoves and wonder if I should do some more looking.
Anyone care to comment on their soap stone stove, brand, model and price range?
MarkV
/ wood stoves #27
I'm curious, how long does the typical catalytic converter on these stoves last? 100,000 logs? /forums/images/graemlins/smile.gif
/ wood stoves #28
.......ten years or 100,000 logs, whichever comes first. Providing the original owner services the vehicle (woodstove) in accordance with the manufacturers approved schedule and only uses original equipment logs............. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ wood stoves #29
Wonder if the warranty includes original owner body. Just finished slitting and stacking a 3/4 ton pickup of wood.
Egon
/ wood stoves #30
I have a Hearthstone Soapstone stove. I like the stove but it is trickier to run than some others I have used. This has nothing to do with the soapstone and everything to do with the design. As far as the soapstone, it does as advertised, it's a little slow to start throwing heat when first started as the stones take a lot of energy to get hot. Once hot, they do stay warm a long time. Overall I do like it. I will say my Hearthstone hates to be "raced." It likes a nice slow even burn. If you overload it, it will burn too quickly and run the flame up the chimney. I've owned others you can load right to the top with no problems. I believe it has to do with the chamber design. The other feature is how it feeds air. On the back there is a "flapper" over a hole maybe two inches in diameter. The flapper is on a wire connected to a control handle at the top. As the stove gets hotter, the metal wire expands from the heat, gradually closing the flapper over the air source to help slow the fire. The problem is that in order to not allow too much air when starting the stove, you need to keep it open only a little. Then once it gets going, the flapper wire expands and the flapper closes off the vent hole, choking the fire. It requires pretty regular adjusting as you go. I'm thinking of changing the wire to a thicker one that may have less variation.
My stove has no catalyst. I miss my stoves that had one. I like the way they run. I've found that in order to run one right, you need a thermometer on the top of the stove. At 500 degrees, close off the damper and let the catalyst burn the smoke. I have found it works really well.
/ wood stoves #31
I forgot to mention - they aren't cheap. What you spend is related to how big it is, whether or not it is ceramic or just cast, etc. I would expect to pay north of $2000. I couldn't bring myself to pay that much. I bought a used one and completely tore it down, replaced all of the internals, and re-built it. I think I paid around $300 for the stove in pretty tough shape, spent another $400-$500 rebuilding it. Came out great.
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2021 WACKER NEUSON LIGHT TOWER (A63569)
2021 WACKER NEUSON...
2006 Zodiac Hurricane Inflatable RIB with Myco T/A Aluminum Boat Trailer. (A61574)
2006 Zodiac...
