Wood splitter auto cycle
/ Wood splitter auto cycle #1
drzmatt
Central NY
Kubota 7610
How do I add auto cycle to my wood splitter? Do I just need another valve or is it more complicated than that?
/ Wood splitter auto cycle #2
What do you mean by 'auto cycle' ? Mine will return to 'home' by itself and stop, but when splitting, the handle has to be held continuously. Are you looking for a complete automatic cycle, no hands, or to just start the cycle, no hands?
Not sure I would trust everything to 'work' good and not get something or someone in trouble with something like a splitter that is automatic.
Would like to hear more about what you need, to answer your question. Don't have ESP on this end. /forums/images/graemlins/grin.gif
Most of the commercial splitters have auto cycle as an option. By this they mean that all you have to do is put the piece of wood on the splitter and pull the lever foward. When you do this the cylinder comes foward splits the wood and returns to the home position automaticly. I am looking to add this option to my splitter.
/ Wood splitter auto cycle #4
Do you have specific brand names in mind? Or are the 'commercial' splitters you are referring to those that are out of reach of the operator, like the ones the bucked-off block falls into the splitter trough and the split is then initiated? I may be only thinking of the ones most discussed here, that the operator also has to hold the piece of wood being split. Don't think one would want to have these on 'auto' cycle. But as to what to do, seems a detent on the control valve in both directions.
/ Wood splitter auto cycle #5
I have a buddy that has a splitter with fully auto cycle. Is a "better" machine, meaning he spent about 4K on it. It has a log lift, 45 ton and good stuff like that. I on the other hand have the 1200.00 34 ton model ... I've been meaning to get a look at my friends splitter to figure out what I would need to accomplish an auto cycle for mine. Sure would make life a lot easier. Maybe someone here can save me the trip!....Scozz
I was looking at Timberwolf specificly. I'm sure that any commercial splitter would use the same valve. I just want to know were to get one. I can't believe that it is a total secret. Someone must know where to get one.
/ Wood splitter auto cycle #7
I looked a the Timberwolf web site a few weeks ago. They have a manual in PDF that you can view. Looked they they used a multitude of valves to accomplish their cycling ... was too complicated IMO...Scozz
/ Wood splitter auto cycle #8
</font><font color="blue" class="small">( How do I add auto cycle to my wood splitter? Do I just need another valve or is it more complicated than that? )</font>
Probably the cheapest way is to buy and use this valve:
Prince Double Detent Valve
It probably isn't entirely what you are looking for but it might get you most of the way there - is has double detents - in otherwords, a detent for the extension stroke and one for retraction. When the valve completes it's extension stroke (or exceeds the detent disengagement pressure) it kicks into neutral. I believe you then have to manually place the valve in the retraction position, and when the cylinder retraction completes it will again spring center to neutral.
It would be nice if it automagically retracted after extension but I don't think it does that - hopefully I'll be able to verify that in the next week or so once I finish all the welding on my splitter and have it operational.
Scozz is correct on the TW splitters - I looked at the PDF manual before I started building my splitter months ago but at the time wasn't into spending the extra coin to accomplish full auto cycle and went with the above.
You need to carefully consider using such a solution as above - they are not recommended, probably mostly due to liability concerns - the Northern Tool webpage carries a warning that they can be dangerous (like logsplitters aren't ?) - something could go wrong. FWIW.
/ Wood splitter auto cycle #9
</font><font color="blue" class="small">( Looked they they used a multitude of valves to accomplish their cycling ... was too complicated IMO )</font>
Actually they use a single double spool valve to do the auto-cycle - the other valves are for the hydraulic log life and the hydraulic wedge lift.
Using a double spool valve with single detents on both spools (or a pair of valves with detents) it should be fairly easy to create an auto-cycle. The TW manual gives some hints, biggest one being that both spools have to be put into detent at the start of the split cycle. My assumptions would be as follows:
1. The valve controlling the return stroke is second in the chain and is fed from the first valve which controls the extension stroke.
2. When the valve controlling the extension stroke is placed into detent, the flow to the valve controlling the retraction stroke is cut off making it inoperable, regardless of what postion the valve controlling the return stroke is in.
3. When the valve controlling the extension stroke completes and comes out of detent, hydraulic fluid is then fed to the valve controlling the return stroke. Since it is already in detent it retracts the cylinder and then comes out of detent at full retraction, spring-centering to neutral.
I'm not entirely sure how all the plumbing and the hydraulic line routing would be, would hafta think about it a bit. Hope this helps.
/ Wood splitter auto cycle #10
Northern Tool has a valve made for log splitters. It has a auto return. Item# 2020: Prince Log Splitter Detent Valve.
I would not want to use a valve that was detented on both ends. Could be a safety concern on the split stroke.
I have built several log splitters. Mounted the valve over top of cylinder. Made a extension to valve handle that hung down below valve. Attached a spring to handle to pull handle to return position whenever handle was released from moving splitter cylinderforward . Connected a 1/4" rod to cylinder pusher with a clevis. Rod was extended back through handle extension. Put a collar on rod that would push handle to neutral position to stop return of cylinder. Collar was adjustable to control stroke of cylinder. My splitters had 24" stroke. Most of my wood was cut to 18". Set collar to return only 20". This saved cycle time.
Neighbors dad bought my last splitter. I'll see if he can send a picture of the return assembly.
/ Wood splitter auto cycle #11
I put an auto cycle valve on my home made splitter a few years ago, i got it from the "prince direct" overstock on line catalog. It was about 150.00, plus you wil need some tees, adapters (grainger)and four hoses and you will be in business. This spring i will be adding wedge adjust and log lift.
glenn.
/ Wood splitter auto cycle #12
gav64 ... Do you have a model # on that valve? It accomplishes a fully auto cycle wiht one valve? thanks ..Scozz
/ Wood splitter auto cycle #14
scozz-i couldn't find the prince direct web site, maybe they shut it down but went to the main site under valves and printed out the auto cycle rd-5000 page, it gives you the spec and part # for the different set ups i believe mine is a rd522mmee5a4b1. it also gives you a schematic, you will also need a pressure gauge and snubber if you have to adjust the relief setting, i do have to sometimes. good luck. glenn
/ Wood splitter auto cycle #15
Doh !
Why couldn't I find this info eight months ago ...... possibly because I didn't ask here on TBN ...... /forums/images/graemlins/grin.gif
Great info Glenn.
BTW, what's a snubber ?
/ Wood splitter auto cycle #16
Ron, I'd appreciate a pix of that if possible ... having a hard time visioning it. Sounds like your set -up oly made it auto return, not auto forward? ...Scozz
/ Wood splitter auto cycle #17
It's going to be a while before I get a picture. Splitter is up at their cottage in Northern Michigan. Will not be going up there until the snow melts in early April.
Your right. It is only auto return. I don't believe it is a safe way to operate with auto forward stroke on a manual loaded splitter.
/ Wood splitter auto cycle #18
You should never have an auto forward on a log splitter. One slip and its all over for any part of you that may be in the way. Your life or someone else's might be injured because of it. I tried to buy one in Ma. years ago. The dealer I buy my hydraulics from said they were illegal. Now I hear they are legal. Go figure. One of my brother's almost lost a hand years ago splitting wood. He had his hand on the front of a log when he was putting it on my splitter. He said "Go Ahead". I noticed his hand just in time and reversed my ram. I have an auto return on mine.
/ Wood splitter auto cycle #19
With all due respect, while I appreciate the concern for safety, the last thing people generally, or this country in particular, needs is government officials 'outlawing' legitimate products to 'protect' us from ourselves.
The fact a logsplitter manufacturer (some would say the premier logsplitter manufacturer) makes such a product commercially available is evidence of a need or want. When used properly the product is no more more dangerous than say an automobile, the commercial availability of which we all pretty much take for granted.
Having some commissar over in DC dictating what I can or can't have in the way of tools just ain't my ideal scene.
The incident with your brother is unfortunate - thankfully he was not hurt due to the fact that you were paying attention and observing good safety practices (Look, don't just listen) Hopefully he has learned something from that experience - namely that one should NEVER load a log splitter by holding the log on the ends - you always hold it on the sides when placing it into/on the splitter.
/ Wood splitter auto cycle #20
Randall
You are not stating the Auto Cycle correctly.
The below quote is from a post you made back last summer. It is not the same thing that you are recommending and using on your splitter.
<font color="blue"> Timberwolf offers a similar type of valve set on thier splitters up which they call AutoCycle - but in looking over the manual for one of their splitters, I see they use two separate valves to to do it - one apparently for the split, and another for the return stoke. To use AutoCycle both valve handles have to be set into detent at the start of the split. </font>
Finishing Mower (A64047)
Finishing Mower...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
Honda Rancher 300ES Four Wheeler (A64047)
Honda Rancher...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
