Winter starting - TC40DA
/ Winter starting - TC40DA #11
</font><font color="blue" class="small">( that's when I bump the throttle up enough to get it into the 1000 rpm range. I still believe in keeping the rpm below 1000 when it's cold. )</font>
Jim, I don't know enough about diesels to really have a knowledgeable opinion on this, but I thought I've read several times where folks on TBN recommended cold idle speeds, for any period of time over a minute or so, of something higher, so as to provide good lubrication. Have I missed something or misinterpreted this?
/ Winter starting - TC40DA #12
</font><font color="blue" class="small">( ...thought I've read several times where folks on TBN recommended cold idle speeds, for any period of time over a minute or so, of something higher, so as to provide good lubrication. )</font>
Duane, I'm not sure I understand your question, but are you saying that someone recommended idling at higher than 1000 rpm when cold to establish good lubrication? I don't recall reading that, but I have read that all engines should have time to warm up the cylinder walls to prevent scoring. I think that danger goes away pretty quickly once the oil pressure is established on modern engines, but I still can't bring myself to raise the rpm much above 1000 rpm for a couple of minutes in warm weather and even up to twice that long in "Texas-cold" weather. I've also heard that once lubrication is established, an engine under moderate load warms up much faster than a no load condition. I suppose all those things could be true. I had a neighbor who used to start his car and race the engine way up high immediately. I used to cringe because I could swear I heard the valves rattle. /forums/images/graemlins/smirk.gif
/ Winter starting - TC40DA #13
djradz,
I am also not an authority on this especially when it comes to Tractors. However... /forums/images/graemlins/blush.gif....I would think lubrication for a Tractor is similar if not identical to a vehicle. I had a debate with a fellow colleague I used to carpool with on this exact question. I was brought up (from my limited understanding) that warming the engine at a standstill was a good thing. My colleague disagreed & finally told me if I did'nt believe him then I should read my car owners manual. Sure enough, in small print, the manufacturer recommended only running the engine with the car at standstill for approximately 30 to 40 seconds when first starting in cold weather. Then you are supposed to move forward SLOWLY for another couple of minutes & SLOWLY get up to speed. I believe this is to allow lubrication to get to all the moving parts much quicker. I would think the same applies to Tractors. Jim & others will either concur or slam me big time. /forums/images/graemlins/grin.gif
/ Winter starting - TC40DA #14
</font><font color="blue" class="small">( Jim & others will either concur or slam me big time. )</font>
/forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Kozak, I think you are hedging your bet. /forums/images/graemlins/wink.gif
I checked my Owners Manual and it says nothing I could find about engine rpm or warmup. From that I'd say as soon as the oil pressure is established to wash the cylinder walls and lubricate all moving parts, you are good to go, but I still can't bring myself to operate at full engine PTO rpm until the temperature is in the green operating range or very near it. That happens pretty quickly on our tractors if the coolant drain "bypass" is closed off as many of us have done.
I did notice something very interesting relating to the ROPS. My Operators Manual said that if you operate the tractor with the ROPS folded or removed, you should not wear the seat belt. I bet I could start pages and pages of controversy with that statement in the open forums. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smile.gif
Edit: My brain is just waking up so I thought of one more thing. /forums/images/graemlins/blush.gif
When you start a very cold engine, it takes a lot more effort from the starter and the engine turns over more slowly until it starts. Why is that? Is it because the cold engines tolerances and clearances are closer/tighter than spec or is it completely due to the viscosity change of the oil/lubricant? If it's because the cold engine tolerances are tighter, what effect is running the engine at high rpm? Any? Hmm...
/ Winter starting - TC40DA #15
Jim,
didn't I hear something that the new green tractors are actually reving up their engines automatically to lower emissions during warm up? Now they said that it didn't hurt the engine. But who knows if their engine is built for that or just a hoax.
As for me I am a firm believer in synthetic oil, starting the engine up and let it idle for 10 to 20 sec. at 1000rpm then working the engine in a moderate level until she is getting the operating temperature. Then give her the juice. Never had an engine fail, always got high hours or km with that procedure and the engine warms up faster.
Forgot to mention something. Driving the turbo cool again after working full bore is important too.
Max
/ Winter starting - TC40DA #16
</font><font color="blue" class="small">( Duane, I'm not sure I understand your question, but are you saying that someone recommended idling at higher than 1000 rpm when cold to establish good lubrication? )</font>
Exactly, but it was not in the NH forum, so I'll have to do plenty of searching when I get time. Seems like it was either in the oil or operating forums. I think what they were saying was that diesels either don't lube well when cold or at low RPMs, or maybe don't warm up well at low RPMs, so the warmup is extended - something like that. I was hoping someone would chime-in or recall - hopefully someone with a much better memory than mine. /forums/images/graemlins/confused.gif
/ Winter starting - TC40DA #17
Some excavators have that feature too, but slightly altered. First the engine will idle and as the engine warms up the computer will rev the engine a couple hundred rpms higher every minute or so, until the hydraulic fluid is warm. I like that idea better, than rev a cold engine. But again... if the engine is built for reving up while cold, like a better oil pump and more oil passages for quicker lubrication, why not? Since the Boomers don't have that feature, I wouldn't try it.
Max
/ Winter starting - TC40DA #18
I will agree on synthetic oil; the best for cold starts and everything else. Read about it anywhere. We all might get confused about cold engine references as car manufacturer must meet federal mandates to gas mileage so they will tell you to start and drive; this is not great news for the internal parts of an engine or drive train but it will dictate better gas mileage to the manufacturer. It only makes common sense that all fluids are a "little" stiffer when cold; thus move more slowly cold; much lubrication has left internal parts via gravity so when starting cold "be careful" start it up as slow as possible without it stalling; this may mean a little "extra" throttle to keep it running let it warm up ; I don't think you need more than a minute; if it is a hydro unit ; keep it in nuetral and step on forward and reverse pedals to move fluid around a little; run your FEL through its cycles and begin work; just like when you get out of bed in the morning; most do not start running as fast as they can at first. "just be logical" engine block heater is what I should have.
/ Winter starting - TC40DA #19
Diesel engines have a much higher compression ratio than gas engines, and most have longer strokes than gas engines. There is always a period of time the engine does not get any lubrication when it first starts (after a long period of shut down) therefore it is a good idea to start the engine at slightly above idle RPMs. The pistons on diesels travel more in the cylinders because of the longer strokes and are more susceptable to wear until the oil reaches the cylinders. Usually the bigger the engine the longer you should idle it before putting it to work. The modern car gas engine lubricates almost instantly and so the warm up period is reduced to seconds.
/ Winter starting - TC40DA #20
Hi all -
To me, this (lubrication, idling, warm-up) is a very important topic, and I highly recommend this thread that I think was being referred to.
To idle or shut off - which is best?
Here's a quote from one of my posts in that thread:
"This thread has caused me to make some significant changes to my "old" way of doing things. I used to wait for the engine to reach normal operating temperature before even taking off, and at a fairly low idle, maybe 1000. Now I warm up at a faster idle, more like 1400, and take off much sooner, maybe after reaching 1/4 of normal temp, at around 2000 to get the engine to warm up that much more quickly. No heavy work until it's fully warmed up, as always."
I'd like to add that I'm using Amsoil 10W-30 synthetic, especially for the cold weather (I hear you Jinman about warming up in cold weather), and for the added protection I think it provides in the event of a cooling failure. Just a little insurance I guess, that I might never need, but nice to have IMO.
Don't want to start a dino/synthetic debate, to each his own. Amen.
Ratchet Straps (A59230)
Ratchet Straps...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A59228)
2025 BrushFox...
2017 Ford Focus Hatchback (A59231)
2017 Ford Focus...
2006 Lufkin FLII 45ft. 40 Ton T/A Piggyback Flatbed Trailer (A59230)
2006 Lufkin FLII...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
