Winter fuel
/ Winter fuel #41
This video shows some differences, with Hot Shot coming out on top. You can skip the first part which focuses on wear reduction for some reason. Later in the video he tries freezing samples with different additives.
/ Winter fuel #43
What's your strategy for a not-often-used tractor?
I've let my tank get pretty low, hoping I can fill it with winter blend. But, when do they start putting out winter blend?
I feel like I have three choices.
  • Wait until I need the tractor (snow removal) and hope they have the winter blend out by then.
  • Fill it with summer fuel and add conditioner (I have and generally use Howe's)
  • Buy and mix #2 & kerosine (what ratio?)
How do you approach this situation.
Note that I am in Vermont, so it will get below 15°F before you know it. We've already seen 26°.
Couple things: 1.) Ethanol in fuel creates water in the fuel over time which results in premature damage to the inner parts of the engine; (2.) the engine lube should be quality synthetic.
/ Winter fuel #44
If you want the good stuff that mechanics, farmers and truckers use, try Hot Shots.
Power Service is OK, but it’s like the generic stuff found at every corner store.
While I haul the PS ...
I switched from Howes to the Hot Shots a couple of years ago ...
For summer use I use there Everyday ... Everyday Diesel Treatment (EDT) | Top Diesel Fuel Additive PLUS I add half a dose of there LX4 for added lubrication (The EDT does have some LX4 in it, I just add a bit extra!) ... LX4 Lubricity Extreme: Ultra-Low Sulfur Diesel Additive for winter I use there Winter Defense anti-gel ... EDT+ Winter Defense | Hot Shot's Secret PLUS I add a half dose of there LX4 for added lubrication like in the summer ...
Also twice a year in spring and fall I add there "cleaner" Diesel Extreme (in place of the EDT) ... Diesel Extreme | Injector Cleaner & Cetane Booster PLUS a half dose of the LX4 ...
I buy the quart size, but available in smaller sizes ...
Water is BAD! I use a treatment that uses a de-emulsifier, which separates out the water, so it can be drained from the bottom of the fuel bowl ... Water can also help the "bugs" grow ... is more common in bio-diesel mixes ...
My company will let me buy whatever brand I want at the truck stops, they put it on the fuel card with my fuel purchase, I use the "Winter Defense" anti-gel in the winter, nothing in the summer ... We primarily buy at Pilot/Fly J or Love's, and usually a 5-20 % bio blend ... For myself I buy at the local farm co-op where the farmers, county road department buys, so does the school, police/fire/EMS ...
The current mandated ULSD (ultra low sulfur diesel) doesn't have the lubrication that the old stuff did ... That's why I add extra lube ... While bio-diesel does have better lubrication than dino-diesel, it also has a much higher absorbing abilities to aquire water, so I prefer not to use it ... Most additives also increase the centane level, as in the USA it's usually only in the low 40's . . . Japan where both my diesels were made run around 50 centane, burns cleaner and starts easier!
/ Winter fuel
Couple things: 1.) Ethanol in fuel creates water in the fuel...
I'd be rather shocked if diesel additives had ethanol in them. It's bad enough in gasoline - I buy ethanol free whenever possible (available at two stations near where I live) for my vehicles and ONLY ever in my small engines.
/ Winter fuel #47
When using Power Serve 911, just think of gasoline with maybe a bit of lubricity added;
There are actually 3 variations of 911.
from the SDS;
/ Winter fuel
/ Winter fuel #49
It's very light hydrocarbons, highly solvents and easy ignition. A great many years ago a touch of gasoline would be used in a pinch, certainly not recommended.
But either will eventually dissolve the paraffin particles that are what has dropped out of suspension in the diesel fuel.
/ Winter fuel #50
My old 1982 Mercedes Benz 240D manual called for up to 30% gasoline in the diesel tank, for winter driving ... I do know that gasoline will kill the "bugs" that grow/live in the thin layer between water and diesel fuel, I used a 10% mix ... Cleaned it right up, no need for a biocide.
2014 Freightliner M2 106 24FT Reefer Box Truck (A59230)
2014 Freightliner...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
TANK MANIFOLD (A58216)
Deere 35P (A53317)
Deere 35P (A53317)
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
