What is your experience with Stabil?
/ What is your experience with Stabil? #61
Steven I bought a brand new stilh weed eater used can premix and carb messed up before the summer.
Ahh. Not all canned stuff is equal. That is, saying something else didn't go wrong w your tool beyond a fuel mix.
True Fuel was awful but I think they changed their formula recently so the stuff seems better. Their 40 to 1 mix is preferable if you're gonna use this brand.
VP stuff is pretty good.
Stihls 2 cycle mix seems a bit too oily to my liking.
Echo's stuff I think is good.
That's the only brands we sell and I have had experience with so there probably are other mixes that are worthy.
Seeing we sell Stihl equipment, I will say they (In general), run too lean from the factory. We adjust this before the customer picks it up.
Don't know what went wrong with yours but I would not leave any canned fuel within the tool after use if its gonna sit for awhile, no matter what they say about their product.
/ What is your experience with Stabil? #62
Have used the blue marine stabil with good results, red stabil not as good for me. Use Star Tron and a splash of Seafoam now year round. Never a problem with this combo mix, even for gas that has been in tank for several months to a year
/ What is your experience with Stabil? #63
I'd be interested to know your thoughts on 2-stroke storage. I use my chainsaws pretty consistently during fall/winter/spring, but they sit mostly unused all summer. Each spring, I dump all remaining fuel out of their tanks, fire them up, and run them dry.
Everyone from mechanics to amateurs to my own saw shop tells me this is bad practice, because I'm running the saw lean as it consumes the last drops of fuel. They say I'd do better to refill the tank with canned fuel before storage, and running that through the machine, leaving it fueled rather than dry.
Sure, maybe that is better, in theory, but I've never done it and I've never had a problem. Also, you seem to be saying that may not be the best practice, after all.
/ What is your experience with Stabil? #64
Posting this here because this is where the ad popped up after reading WinterDeere's post.
"Kia's for sale" it said. Not Kias, but Kia's. You'd think someone responsible for placing even irritating ads would have a better command of the English language.
Okay, immigrant's rant over, back to the subject.
/ What is your experience with Stabil? #65
You raise a good point Winter.
That increase in engine speed as tool empties fuel is indeed a lean condition but it is so short, it doesn’t do much damage if any and the reason for that is because the oil film on moving parts protects internal components for the short lean duration.
I have always emptied my tanks and drained fuel bowls for long term storage. I have never had a problem doing this.
One of our techs does the opposite. He fills his tanks with VP brand canned fuel, runs the machine for about 20 seconds and shuts it down. He also claims no problems. I did that once with a canned two cycle mix and had a problem. If one likes to do this, I trust a mix of no ethanol fuel that you mix with your own 2 cycle oil that either has a stabilizer or you add one, over the canned 2 cycle mix for long term storage.
/ What is your experience with Stabil? #66
Thanks, arrow! Sounds like I'm good to keep running 'em dry, it has certainly worked well enough for me, so far.
I empty the bowls on my generator and walk-behind leaf blower carburetors, Honda and Subaru, respectively. Easy enough with a drain screw on each, and a shot glass or old yogurt cup in-hand. I even occasionally do it on the walk-behind mower and pressure washer, but those have those crappy stamped steel bowls that can only be drained by loosening the center mounting screw. I hate those.
I've never even looked at how to do that on any 2-stroke handheld OPE. Is it easy enough, or not worth the trouble?
/ What is your experience with Stabil? #67
There are larger 2 cycle engines you can drain such as motorbikes and generators. The smaller carbs such on a chainsaw or weed wacker, don’t need draining as mostly all of the fuel is sucked out of the carb when getting empty. Also, to get any residual fuel out of a float chamber on a small 2 cycle carb is not worth it.
You can also use your last fill with 2 cycle mix that has no ethanol.
/ What is your experience with Stabil? #68
I have never used it and will not waste my money on the stuff.
I have a 5 gal gas can on the back porch its in the open just a
roof and Its been like about 17 or 18 months and I just filled the
weed eater and works fine.
willy
/ What is your experience with Stabil? #69
Do you store with a full tank?
I’m always like “if I store with a full tank, there’s no room for condensation” Or so they say.
There’s the store with tank full crowd and store with every last drop removed crowd.
I have not really paid too much attention to whether the tank full or not, but I run the carburetor empty on engines where it's easy to do so.
Here is a prime example, my 1976 TroyBilt Horse which almost always starts on the first pull after sitting 6 months or months in the barn.
PS. The gas tank has a fuel shutoff valve.
/ What is your experience with Stabil? #70
I've got a 45 YO Sears front tine walk behind tiller. It has a 8 HP BS engine with the gas shut off above the glass bowl. I use it less and less as I get older...........But.......when I do use it I just drain residual gasoline, remove and clean the glass bowl, add fresh gas.......and .... it starts right up year after year......even though it is stored outdoors with a big wash tub hainging upside down over the engine. I've been using ethanol free gasoline with red Stabil for years.
Cheers.
Mike
/ What is your experience with Stabil? #71
OP I also live in NY and have bough bad E0 fuel. It was at a station with many options of fuel. I now only buy E0 fuel at stations with there only high test being E0. Lots of cars use it and this means more volume is ran through the station.
In my area and a rule in general this means your going to be buying 91 octain E0 fuel at Stewart's.
You have alot of water in that fuel tank. I would dump, clean and put fresh on.
/ What is your experience with Stabil? #72
It was for either one, as my post was about stored gasoline.
Some of that gas goes into vehicles with carburetors, some with EFI. And some gets used for other purposes, once my experiments fail and the gas is no longer usable in vehicles or other engines.
/ What is your experience with Stabil? #73
I only know that once we started using Ethanol free gas we have not had problem!! My snowmobile is a 95 model Yamaha 4 cycle 4 cylinder and the problem we had every year was the needle valve was stuck. had to take the carbs apart and use needle nose pliers to get the needle free. Each carb had two o rings that we had to replace at 8 dollars each times 4 carbs.( that was Yamaha price.We found a local gaskets supplier that got us the metric O rings and he gave them to us. said they cost him about 75 cents for all of them) Have not needed any for the past 8 years or more since we started using ethanol.
/ What is your experience with Stabil? #74
I'd have no problem with using ethanol free gas, but driving some 200 miles to fill up the 200 gallon tank I can do without. And it takes a while to load the tank on a trailer and then set it back in its place when returning.
So far it seems like regular 86 octane and Star Tron works just as well, both of which I get delivered.
/ What is your experience with Stabil? #75
Fortunate that I have 90 and 89 ethanol free within 10 miles of house. Only use that for my 2 stroke equipment. Run 87 regular unleaded in the 4 stroke air cooled engines. Like you I run Star Tron plus I add a splash of Seafoam. Engines seem to like it as some may set close to a year before ran again. Never have problems getting started and running even after not being used for so long.
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
PALLET OF (73) 4.80/4.00-8 GOLF CARTS TIRES (A64281)
PALLET OF (73)...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
