Winter fuel
/ Winter fuel #61
And no recommendation for any temp below -8 F,
That 2 degree Celsius range, line in his manual looks like a technical writer mistake. Happens all the time in owners manuals
/ Winter fuel #62
What's your strategy for a not-often-used tractor?
I've let my tank get pretty low, hoping I can fill it with winter blend. But, when do they start putting out winter blend?
I feel like I have three choices.
  • Wait until I need the tractor (snow removal) and hope they have the winter blend out by then.
  • Fill it with summer fuel and add conditioner (I have and generally use Howe's)
  • Buy and mix #2 & kerosine (what ratio?)
How do you approach this situation.
Note that I am in Vermont, so it will get below 15°F before you know it. We've already seen 26°.
Get your Diesel now.
/ Winter fuel #63
I'm waiting another few weeks just to be sure its winter blend even though the station I buy it at is where a lot of big trucks fill-up
/ Winter fuel #64
Around here, the early winter fuel has only been treated with anti-gel. Later, when it really gets cold, is when the fuel starts being blended with #1-D fuel.
/ Winter fuel #65
Use a kerosene fire spaced heater for an hour on your mule warming it from one side
and you will not have to worry about freezing fuel.
Yeah... but you will have to worry about being late for work! :ROFLMAO:
Your method would be great for those who have schedule flexibility, like retirees or those working from home. But the last thing most "working folk" need, when they wake up to a surprise blanket of snow, so to waste an hour warming up their tractor... before they warm up their tractor.
Everything from my winter gear to storage was arranged based on being able to clear my way out within 20 - 40 minutes, on any morning I wake up to a surprise snowfall -- or in which the snowfall ends right as I should be leaving for work, as seems to often be the case around here.
/ Winter fuel
Ditto. Although I've rarely been surprised by a significant storm in the last 20+ years what with the advent of internet forecasts and notifications. And I am in a situation whereby, as long as the road is plowed, and we got less than 3' of snow, I could almost certainly get to work, as it's all downhil and pretty steep at that. Then again, I'm not really needed at work... :D
/ Winter fuel #67
The data certainly is there, but I catch myself failing to look at it enough, during the work week. I always know what the weather is going to be on the weekend, as I plan my outdoor chores for the week, but I've been surprised on random Tuesdays or Wednesdays, more than once.
/ Winter fuel #68
Of course if you're running #2 fuel in your salamander it may take an hours work to get it purged out and flushed with #1 fuel so it works.
/ Winter fuel #70
That's when I'd be using @leonz's recommendation, to just heat the machine with my kero jet heater prior to starting, until I can get that old fuel run thru and replaced with the proper fuel. While I'd not want to have to "pre-heat" my tractor all winter long, doing it for the purpose of just running some old fuel through does sound better than draining, purging, cleaning, and disposing of what's already in the tank.
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
206320 (A57192)
206320 (A57192)
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
