Window Glazing -- what am I doing wrong
   / Window Glazing -- what am I doing wrong #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
We have an old building where I noticed that the putty was virtually all gone from the window panes. So I tried to used traditional window putty but found it way too hard to work with. So I got some DAP in a tube and tried applying that. I've had some success but have to admit its a pretty sloppy job -- especially in the corners. So my first question is: do I push it or drag it along the seam? Second, is there a trick to this or is it just a matter of practice.
Thanks
   / Window Glazing -- what am I doing wrong #2
The traditional putty is easy to use as long as it isn't too old. The key is to take a hunk of it and knead it and roll it in your hands until it becomes very soft and pliable. Then put it into place and use the glazing tool to drag over the putty and leave a smooth surface. If it cracks and separates as you drag and doesn't have a smooth surface, you didn't work it and mix it enough before placing it. I've never used the stuff in a tube but I assume you still have to use the glazing tool to finish it.
   / Window Glazing -- what am I doing wrong #3
I think that the "binder" in old-school glazing putty is linseed oil that will separate out over time in the can. So like Kenny says, you have to knead it to redistribute the oil and soften the rest (clay?) until it is smooth and pliable. Then it should be MUCH easier to work.
- Jay
   / Window Glazing -- what am I doing wrong #4
I have been working on re-glazing some very old windows where the wood has dried out and have had some success brushing on some boiled linseed oil* into the muntins where the glass sits so it can soak in and renew the wood. Then I push a bed of Dap 33 glazing putty into the frame with my fingers for the window pane to rest in prior to placing the glass and pushing in the glazing points. As KennyG & JRobyn correctly point out working the putty to get it warm and pliable makes the job easier. The boiled linseed oil (dries faster than plain linseed oil) will renew the wood and prevent the dry wood from drawing the oil out of the glazing putty which can lead to cracking. Some people just go ahead and paint the muntin with alkyd primer, but I find the traditional putty sticks better to the oiled bare wood on old windows. I just go ahead and apply the putty immediately after brushing on the BLO. I let the finished glazing putty dry for a couple of days or longer prior to painting with a coat or two of alkyd primer.
The DAP in a tube is I believe a latex product as opposed to the more traditional glazing compound so may not work well with my method described above.
*Care must be taken when working with linseed oil and rags as they rags can spontaneously combust if left in a pile or dropped into a garbage can as the oily rags will generate heat while drying. Additionally, boiled linseed oil contains additives that can be toxic, so care should be taken while handling it
   / Window Glazing -- what am I doing wrong #5
KennyG & JamesHW have it. Oil the bare wood when you have everything out, points, Dap 33, a glazing tool & a little patience and you'll have new looking windows in no time. I let the glazing age a week before priming & painting. I leave a little line of paint past the glazing onto the glass to seal the glazing in when cleaning up.
Now what I'd like to know is how to get the old glazing out efficiently. A heat gun or infrared heater works, but it seems like I always crack a pane. Too impatient, I guess.
   / Window Glazing -- what am I doing wrong #6
I usually seem to just wait until it falls out. :confused3:
   / Window Glazing -- what am I doing wrong #7
Glazing used to be one of my tasks at the mom & pop hardware store where I worked after school. always used a propane torch to soften the glazing for removal. The pointed flame is easier to direct the heat away from the glass. Helps avoid cracking.
A little linseed oil on the putty knife used to smooth out the new glazing compound will help the knife glide smoothly across, rather than pull, the compound.
   / Window Glazing -- what am I doing wrong #8
There are several good videos on YouTube that show how to lay down the putty.
   / Window Glazing -- what am I doing wrong #9
When done. put the oil soaked rags in a 5 gallon pail of water to let the oil separate out from the rags. This greatly reduces the chances of fire from the Linseed oil.
   / Window Glazing -- what am I doing wrong #10
If your using Dapp in a caulking gun use masking tape on the windows. Makes application and clean up easier.
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
