windmill composter
/ windmill composter
Re: windmill composter/blades-props
SHF,
Sounds good to me! /w3tcompact/icons/laugh.gif
We must have made the same kinds of drawings in physics class (while we should have been paying attention). /w3tcompact/icons/tongue.gif
I remember a v-8 powered toothbrush, with every known gear/lever/pully. etc. in between. Thinking IN "the box" was the self-discipline problem /w3tcompact/icons/wink.gif !!
Larry
/ windmill composter #42
Jor El
Box? What box? I think I might have dumped it in the burn barrel by mistake. /w3tcompact/icons/shocked.gif
You could do the same thing with a conventional windmill. As it turned, it would spin a small waterwheel which would lift water from a trough into a channel and carry it to the upper bin, now a water tight container.
One thing nobody ever accused me of is making things too simple. /w3tcompact/icons/laugh.gif
SHF
/ windmill composter #43
I just found an article on Lubrication of Worm Gears while roaming around on the net. This should be useful ...
/ windmill composter #44
Re: windmill composter / Minto\'s Wonder Wheel
Branch,
I had some time to think about Minto's Wonder Wheel. It is definitely innovative and could probably do the job of a conventional windmill.
A few caveats (but not necessarily showstoppers) would be:
1. If the heat source was the compost (an assumption) then designing a heat exchanger to extract heat from the compost while the compost is slowly being turned over would be hard. The heat exchanger would have to stay covered by compost to absorb enough heat to make this work.
2. Having the heat exchanger be tough enough to withstand the corrosive (hot, wet) compost environment - and also the inevitable pitchfork / shovel when getting the compost out.
3. Designing the heat exchanger so that the rotating barrel (assumption) could be tilted to get the compost out.
4. The propane tanks (or substitutes) would probably be hotter than the compost in the summer sun. So, the device would probably not turn in the day - only a couple of hours at night. This may actually be beneficial.
I would tend to think that having the compost as the heat source would make it a little too complicated - but it is an interesting alternative to provide rotational power if an alternate energy source is used.
I think it's GlueGuy that has a bunch of solar panels on his place. Maybe he'll donate one to the cause /w3tcompact/icons/smile.gif
/ windmill composter #45
RPM
I was wondering if Minto's wheel could be enclosed in a kind of insulated box, thereby shading the gas cylinders. A solar collector could be used to heat water and this heat could be transferred to the bottom cylinder by use of a Hydronic Radiant Panel. The main problem would be to keep the box from heating up. (Maybe an astrofoil product?)
It would be helpful (from a cooling and heat transfer standpoint), if the wheel could be angled somewhat from the vertical so that it would be easier to transfer the heat without heating the whole box. An ideal situation might be to situate near a small stream and use a hydraulic ram type pump to supply cold water to cool the "off" cylinders. Or, with the extra HP, could we find some way to power a small fan to cool the off cylinders?
SHF
Maybe a fresnel lens/mirror combination could be used to heat the lower cylinder.
<P ID="edit"><FONT SIZE=-1>Edited by StoneHeartFarm on 06/27/01 10:14 AM (server time).</FONT></P>
/ windmill composter #46
I don't have any experience with composting so my assumptions are very possibly way off the mark. My experience so far is with grass clippings in a plastic garbage can. Within a couple hours they tend to get real hot, far more than the roughly 4 degrees Minto mentions. With this limited info I proceed.
I start with the concept of a cement mixer. A plastic garbage can angled up, paddles angled such that they will give a screw motion that folds the compost onto itself and contain it in the barrel. That barrel is slid into an identical barrel, minus paddles. A gap will exist at the bottom of the two barrels which I fill with water. This is my heat exchanger. Reversing rotation and angling down should cause the compost to come pouring out. If I create a decent seal between the two barrels the water should stay captive. Problems 1-3 solved?
Shading the condensing tanks along with a little mist of water could use evaporation for cooling?
I've got to cut the lawn this afternoon so I'll play with this. We're having mid 80 days so I'll see what kind of temperature difference I get. I'll set up two barrel sets, one with clippings, one empty, then measure the water temperature at the end of the day and again in the morning. If I have at least a 5 degree difference I think I'm on the way. Improvements like painting the outer barrel black should be able to improve the differential. We'll see.
Branch
/ windmill composter #47
Branch,
I guess I'm wondering why the compost heats up. Is it because of microbial action? If so, will turning the compost relase the heat, cool the pile and prevent the little critters from doing their job?
SHF
Re: windmill composter / Minto\'s Wonder Wheel/super magnifier
Hi Guys,
Now this IS getting interesting. /w3tcompact/icons/smile.gif
I agree that the "summer sun" on the hopefully-cooling tanks is a "no-problem" issue, solved simply by a piece of canvas or plastic tarp for shade. The "cooling mist" sounds good too! A small sprinkler head at the "rest" position of each of the "cooling" tanks could do the trick, with the "heating" tank being shielded(from the water-fallout, but not from the sun).
An interesting but probably not-practical heat source idea is a large fresnel lens focused on a black metal heat-exchanger plumbed into the tank-heater bath-water. I say this because I have several of the (40" square?) plastic lenses such as are sold (or at least used-to-be) by Edmund Scientific, and have experimented with them a little in the sun.
With the lense supported on a frame at the focal length (I seem to recall about 50"), the "hot-spot " (claimed to be 2000-3000 degrees f.) IS for sure HOT!
I timed a pot of water coming to a boil, and it was pretty quick, though I don't remember the time.
The hot spot looks like a flashlight beam on the target, and with no hiss or smoke to remind you what is going on, is easy to carelessly pass your hand through, while positioning things, or measuring temperature, ...YEEOOUUCH!! NOT-RECOMMENDED! You will move your hand very-quickly, I can report for sure! /w3tcompact/icons/shocked.gif
Amazing how much energy is available from a square-yard or so of sunlight. /w3tcompact/icons/crazy.gif
A collector(funnel) of panels/mirrors could gather the energy from several times the area, ...not simple to align properly, but scary if accomplished.
Drawbacks: 1. Must "track" the sun's movement, or the spot will soon move off-target.
2. Not sure how the plastic material of the lens itself will hold up to the UV degradation of extended exposure.
3. Only operational during the hours when sun-position and cloudless sky cooperate.
With a modicum of "cooperation" though, the water in the bath should retain enough energy to heat the tank-to-be-emptied fairly quickly, without losing too-much heat, until the clouds moved-on, and more energy could be absorbed.
"Don't try this at home!" may be overstating things, but kids playing with this thing w/o adult supervision is a no-no! It's DANGEROUS!
You have to be constantly watchful that you don't carry it in such a way that the sun comes in focus on anything you don't want burned. For a comparison, consider this: When I held a lit-match to a piece of dry cardboard, it started to "flame-up" after some number of seconds. When held under the lens, it was burning NOW!! Nearly instantly!
To others who may have been (as I now shamefully admit ) "mad-scientists" as kids, and might have toasted an ant or two during sunbeam experiments, this thing is the "hydrogen-bomb" of magnifying glasses! /w3tcompact/icons/tongue.gif
Are we havin' fun yet?
Keep those ideas comin', boys and girls! /w3tcompact/icons/laugh.gif
Larry
/ windmill composter #49
Why not just construct a GIANT version of the novilty "Drinking Bird"? Seems like if we built several of them, large enough we could turn a crankshaft!
Steve
Steve,
Guess I never paid any attention to those "drinking birds", ...could you explain how they work?
Larry
/ windmill composter #52
Re: Branch's solutions
I like the idea of a barrel in a barrel for the heat exchanger. Couple of suggestions there - I had discounted this idea too quickly I guess because I assumed that all barrels around this size (55 gallon or similar) are the same diameter. Do they come in different sizes or would modification be needed? Also, the barrel that holds the compost should preferrably be a good heat conductor. Steel would be best for heat transfer, but plastic would be better for corrosion resistance.
With regard to the temperature differential. Shading would work - would probably have to put each tank in a vented box as this wheel may get too big to create a shade for the whole thing. Would be pretty easy to construct. The addition of a water spray sounds like an additional source of power would be needed (well-pump etc.) - might want to stick with the shading.
A compost heap should get up to around 120 degrees or so (after a couple of days). The trick is to then work out how much of that heat can be transferred to one of the rotating tanks. A tank in full sunlight would get above 120 easily - hence the problems in sunlight ...
In fact, there's a potential for the heat source to be sunlight (direct or as JOR EL suggested with a fresnel lens) and then have a cooling apparatus - let part of the problem be part of the solution.
/ windmill composter #53
I picked up a link through the Weird Science website. This one has quite a bit about different configurations for Minto's wheel.
One of the approaches they are trying is multiple wheels on the same axle. They are also suggesting putting cooling fins on the tanks to aid in reducing the temperature in the off cylinders.
There is one REAL interesting comment though. They are mentioning table top models. It occurs to me that IF you can build multiple wheels on a single axle, and IF you can build a table top model, than why couldn't you built a much smaller machine that the 30' job we've been discussing? I'm thinking something under 8-10 feet tall that could be housed in a common storage shed. Something with multiple wheels say 8-12. That might solve several problems, as the unit would be hidden, and the temperature in the building could be easily moderated to ensure maximum power output. Also, this site is recommending using 1" hard copper tubing to transport the gas from cylinder to cylinder. They are hoping for 6 RPM.
Here's the address (hope I can figure out how to make this link and jump).
SHF
http://users.mildura.net.au/users/egel/tempw.htm
/ windmill composter #54
Okay, so my brain's burning on this one, trying to figure a way to get more hp and RPM out of a shorter than 30' tower.
I'm imagining this wheel starting to move from a dead stop. If the top and bottom cylinders are precisely at nadir and zenith, then there would be a slight hesitation while gravity undertakes to spin the wheel. As the top cylinder falls, the speed would gradually increase until the maximum speed is reached at the bottom of the arc.
I am assuming that this accelleration phenomenon would occur on each cycle. There would be a slight hesitation of the top cylinder as gravity begins to grab ahold and pull. I beleive this hesitation is partially to blame for the low RPM.
I'm wondering if there is a way around this hesitation. Specifically, think of 2 wheels stacked like and OREO cookie. Imagine each wheel has cylinders around the outside corresponding to the numbers on a clock. Why couldn't the #6 cylinder on the #1 wheel be connected crosswise to the #1 or #2 cylinder on the #2 wheel. The #7 cylinder on the #1 wheel would then connect to the #2 or #3 cylinder on the #2 wheel, and so forth. It seems this would eliminate or reduce the hesitation effect by placing the weight in a more comfortable position for gravity to grab it, without overly sacrificing the height of fall (shall we call this the "head"?).
Also, out of curiosity, what would happen if we applied the heat to cylinder #7 or 8 instead of #6. (In a system plumbed dead opposite). That would offset the heat and cooling sources.
What I'm trying to do is increase HP and RPM to the point where this might wind up being more than just a funny toy for grinding grain or turning compost. (10 to 20 RPM with 25 HP could possibly be geared up to handle a small generator.)
Whatcha think?
SHF
/ windmill composter #55
Re: How the wheel accelerates (or not)
SHF - I think you will find that it is a fairly smooth process. The transfer of fluid between the tanks would be gradual (filling by condensation) - and this same gradual process would be repeated in all the tanks around the wheel.
/ windmill composter #56
Re: Multiple wheels on a shaft
I don't think you need multiple wheels. You could just get away with long tanks mounted parallel to the axis of rotation - it's the same effect for a lot less effort. (Instead of a disc rotating, it would now look more like a cylinder rotating about its axis)
You could use some big old gas bottles like they use for welding gases.
/ windmill composter #57
Probably a good point to summarize the approaches suggested so far:
1. Windmill powered composter (original idea)
2. Water powered composter
3. Electric starter-motor powered composter
4. The 'Rube Goldberg' - combination of using a windmill to gradually load shot into buckets that rotate the drum
5. Minto's Wonder Wheel
Just thought it would be useful to summarize briefly for any new browsers!
/ windmill composter #58
Now if only this could be run via solar energy..../w3tcompact/icons/smile.gif If it will compost chickens...it'll compost anything!!
Kevin
/ windmill composter #59
The original 30' wheel was supposed to put out almost 9hp! That's enough to Hp to spin one humungus pile of compost. The 8' diameter is much more appropriate, I think, for your average non-commercial compost slinger.
By what I found at those websites I posted earlier it seems like 1 rev. per day would be adequate. Speed is not necessary for composting.
Really enjoying the ideas you're all throwing out! Somebody might even build one before the fun of brainstorming wears out.
Branch
/ windmill composter #60
I'm thinking the HP output is probably a product of the radius of the circle. ie, the greater the radius the greater the leverage of the falling bottles, hence the greater the HP output. If this works anything like the power output from wind dynamos, it would be a progression, so the 4' radius would not be 45% of the 7' radius but something on the order of perhaps 10%. 8' wheel 1 hp? This is all fuzzy math and speculation (but that's okay, the government does it with your taxes /w3tcompact/icons/laugh.gif), and probably couldn't be proven without building one.
I still think the multiple wheel arrangement has some merits. Easier to balance (I'm afraid this might be a biggie), and the loss of one set of cylinders through leakage, etc wouldn't upset the whole apple cart. I'm wondering if, in a multi wheel arrangement, why you couldn't heat the #6, #7 and #8 cylinders on the #1, #2 and #3 wheels (1 on each wheel). This would put all wheels in a different stage of expansion/condensation at all times. I'm also wondering if a faster reacting fluid is available. Something that would boil quicker and condense faster.
What I'm aiming at is being able to use gearing on the 1 rpm pto of this beast to derive 3600 rpm. This means either more hp or greater rpm, since the gearing process would more than eat up the 8.5 hp output. Hence, multiple smaller wheels to increase hp, and small modifications to tweek out additional RPM.
You guys get me a way to generate electric power off this bad boy and we'll have a composter that will run itself, with a computer probe to figure out when it needs turning and water. /w3tcompact/icons/laugh.gif
SHF
