Wind down my chimney
/ Wind down my chimney #21
I seriously doubt your 18 inch stub did anything for your downdraft problem. I'm sticking with the 2/10 rule - get that chimney 2 feet higher than anything within 10 feet of it.
I do plan on extending it properly when the weather warms up in a month or two. For now, my hot water tank and pilot are staying lit. The flame on the burner is nice and uniform now. No flickering or blowing out. The flame used to blow around and even flare out of the front of the access door. I take this to indicate that venting has improved. I plan to raise it up properly and use two braces.
/ Wind down my chimney #23
18" is a start and I'm glad that it's working better now .... I'm somewhat surprised ... actually shocked ... that the original passed inspection.
The 2/10 rule is also what applied in Alberta and I had a similar draft problem even though my chimney was 12 feet tall (from the exit on the roof .... but still wasn't far enough away from the roof as it was one of those REALLY steep alpine jobs.
That looks like a pretty stubby chimney and I'd not worry about guys to support it unless you plan to extend it a LOT.
I used a 10 ft 2x4 and a level to check to see what height I needed .. finally ended with a 16 foot chimney (and 2 sets of brcing!)
Good luck ... btw did you inspect your CO2 monitor?
/ Wind down my chimney #24
For what its worth, I'll add my two cents worth. I was literally burned by a down draft problem at our former house even though the chimney was above the roof peak and therefore met the 3/10 rule in our area. What happened was that a downdraft forced the flame from the furnace outside the bottom edge of the cabinet and apparently there was some flamable material close enough that it caught fire. We had just left on a vacation but fortunately our daughter came home the night we left. The dog woke her up about 4 am and she immediately smelled the smoke and called the fire department. They arrived in short order and limited most of the damage to the basement. There was a lot of smoke damage and the dry cleaning bill alone was over $10,000.
So my message is to make sure that there are no flamable materials anywhere near your furnace, hot water heater, etc. that could be ignited by a downdraft. After the fire I made a small wall out of concrete blocks around the furnace and kept that area meticulously clean. I also put a water sprinkler head over the furnace. Probably overkill but it eased my mind. In our current house the burners for both the hot water heater and furnace are quite high off the floor so there isn't the same danger. But I still keep the area around them clean and free of flamable materials.
/ Wind down my chimney #25
<font color=blue>When I went to start my tractor I found a fresh pile of 'CRAP' on the seat. My wife has six cats that live in the garage. I have no proof, but........</font color=blue>
Is that what they mean by a one cat hitch?
/ Wind down my chimney #26
keeping flammable stuff away from flames is a good idea in any case, Howard. Agree with you 110%
/ Wind down my chimney #27
good info hwp - gonna check my hot water and furnace tonight when I get home.
/ Wind down my chimney #28
CO is formed from combustion without adequate oxygen. For example, if you run a propane space heater in a sealed room you'll burn the oxygen out of the air and then you'll produce CO. With your down draft it sounds like you're getting plenty of oxygen, hence no CO.
Howard, I like that concrete block idea. I think I'll put to use, just to be safe.
Jerry
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2008 FORD F-150 PICK (A66091)
2008 FORD F-150...
2008 Sterling Acterra 2,000 Gallon Water Truck (A66736)
2008 Sterling...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
2000 (INOPERABLE) KENWORTH T800 (A67714)
2000 (INOPERABLE)...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
