Winch work
/ Winch work #12
Well to start with, all 3 are "open" blocks - in that you can just place the cable on without having to open the side of the sheave. I suppose they would be just fine as long as you have some tension on the cable. I kinda like the second block which allows you to use a choker chain as you attachment sling. The third block (6 ton self release) could be really usefull but could also be really dangerous if you are not paying 110% attention. When that slider pops the release you might get some significant changes in tension that could be "exciting".
They are a bit expensive for casual use but I'd probably get some if I was in the business. I have found snatch blocks at flea markets and such for from $10 to $40, depending on condition and size. Make sure the sheave (rotating center section)is firm and rotates freely - a wobbly sheave indicates a worn bearing (could be fixed - maybe). Also, and this is pretty important, be carefull of the size of the sheave and the clearances on each side of it (between the sheave and the body). You can ruin a cable, a rope and or your load if the cable pops out of the sheave and down the side of it. (I look at things more from a riggers view then a log puller - though I like to do both). Sake Mense?
John Deere XUV825E (A61307)
John Deere XUV825E...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2025 32in. JBD Hydraulic Concrete Mixer Bucket Mini Skid Steer Attachment (A59228)
2025 32in. JBD...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
