Winch Modifications
/ Winch Modifications #41
Maybe you could just leave it in the garage and use a big wheel garden cart to take it out when you get stuck?
We have a garden cart made out of plywood, angle iron, conduit and it has 26" bicycle tires on it. I can haul 50 pieces of firewood on it. It is so balanced that I can do that with one hand. The large tires let it roll over anything.
Or you could stow it on top of the engine compartment, perhaps?
/ Winch Modifications #42
Bob,
That isn't a bad idea with the attachment plate on the back.
If you want an idea for something similar to what you already have, why not put the second receiver pointing straight up just to stow the winch. Then when you need it you can move it to where you need it, the front or back.
/ Winch Modifications #44
Bob Rip a suggestion about knowing when to stop the winch before you pull it in too far. Pull the cable out to where you can just see the hook while sitting in the seat of the pt, then measure the distance from the winch to the hook on the cable. After you have done that then make up a short chain just a little shorter than the distance from the machine that the hook was visible. With that short piece of chain on the winch as you roll it up when you can just see the far end of the chain then you know that you have it pulled in far enough without pulling it in too far that might work.
/ Winch Modifications #45
The second receiver would point straight up. You would stow it there. That should save some length on your PT. The reciever you built would be changed to only have the one receiver pointing backwards. When needed you would install it in that receiver. I know i may not be explaining this well enough. Keep asking questions till I make it clear.
/ Winch Modifications #46
I took the machine out today with the winch on back. I did not need it, but it did not interfere with the use. I am thinking about shortening the two inch receivers. I will have to grind off the reinforcements at the end, and then weld them back on. The machine is very long the way is it. Suggestion here would be appreciated.
Nice job Bob! just a thought for you on how far the winch sticks out back...if you were to cut and reweld the 2" so the winch straddles atop your (top) receiver, you would both reduce the back extension and lift the winch even further...perhaps to the point that you could glance back and see it. kind of hard to explain but visualize a u shaped sort of affair (on its side). this way you could still easily attach via receiver
second thought would be ...you could reconfigure your brackets so that the winch would operate horizontally but the receiver connection could be vertical per 3238's suggestion. again, you would raise the winch further and reduce rearward extension... hope this helps
Bob,
That's not a bad suggestion, and I seriously considered it. However, I could not open the engine cover to check oil and add gas without removing the winch. That would be a lot of pain. I wonder if I put a receiver on the engine cover if the cover balance would be so bad it would not stay closed?
Good suggestion. Gotta ponder this one.
All of these comments got me thinking. Thanks for the suggestion. I decided to put a two inch receiver facing left, between the other two 2 inch receivers. So I now have three of these things on the back of the PT. I then slid the winch in from the left, just for storage. I don't think I would actually use it there. If I did I think I would need some more reinforcements. The whole assembly now sticks out about 11.5 inches. That's one foot shorter. I think I can use the other receivers with the winch going sideways. I think this is an excellent approach. We will give it awhile and see.
Again, the comments are very helpful and force me to think of other ways or maybe even use a comment. See pictures.
/ Winch Modifications #51
BobRip,
So where did you find the hydraulic connectors for your PT? I am looking for a male and female for my power take off for a small attachment I am making/getting. Thanks
/ Winch Modifications #52
Tractor supply places sell them, some auto parts places, and plenty online including Ebay.
Ken
/ Winch Modifications #53
Will they fit those Italian things we have on our Power-Tracs? If so I will be going there real soon. I have one of those places just down the road. Thanks
/ Winch Modifications #54
I was able to find the smaller fittings (although I recommend taking one in to make sure they are a perfect match). But the larger PTO fittings I just swapped for a more reliable (local and I can get more whenever I want) brand.
I got mine at Northern. I got some from NAPA and they looked like the PT ones, but did not work. Close, but no cigar. Take a pair with you to make sure they fit.
I also tried my local Tractor Supply and they did not have the 1/4 inch in stock. I don't know if they sell them in the online store. It seems they did not have them there either.
/ Winch Modifications #56
I'm looking for the larger fittings/connectors. I hope this isn't going to be a real pain trying to find some that fit and costing me an arm and leg. I will have 3 attachments that will use the larger fittings.
Thanks
/ Winch Modifications #57
It will be a pain. You can mail order them but I am pretty darn sure they won't be local.
Time to swap to flat face like Ken...
Thanks
Tractor Supple did have larger fittings.
/ Winch Modifications #59
My one attachment I bought used, well motor and connectors they have a Parker 6600 series connectors and they fit perfectly on my Italian Power Trac connectors. Now if I can find who sells them I should be fine.
/ Winch Modifications #60
I bought the main PTO connections for my PT425 backhoe project(you know, the one I still need 10 hours to finish :laughing: ) at Bailey's.
They have changed their website a bit, so you may want to call to check. they used to list them by brand name and now they are not.
Hydraulic Cylinder Components, Products
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2019 John Deere R-4038 (A61306)
2019 John Deere...
