WHY ???????????????
   / WHY ??????????????? #21
The hitch geometry is different also. The higher category hitches are made for higher hitch heights along with wider lateral and vertical spacing between the points. Bigger loads need bigger pins.
It was an excellent evolution. Implements were categorized by the loads they impose on the tractor and hitches were designed accordingly. If an implement is cat1, it will fit your cat1 tractor and not be too heavy for your CUT to pick it up.
   / WHY ??????????????? #22
Then to complicate the issue, there's the implements for SCUTs like mine. Cat 1 pins on cat 0 spacing. :)
Ian
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
