WHY ???????????????
   / WHY ??????????????? #21
The hitch geometry is different also. The higher category hitches are made for higher hitch heights along with wider lateral and vertical spacing between the points. Bigger loads need bigger pins.
It was an excellent evolution. Implements were categorized by the loads they impose on the tractor and hitches were designed accordingly. If an implement is cat1, it will fit your cat1 tractor and not be too heavy for your CUT to pick it up.
   / WHY ??????????????? #22
Then to complicate the issue, there's the implements for SCUTs like mine. Cat 1 pins on cat 0 spacing. :)
Ian
Case Axial-Flow Combine Wheels NO RESERVE (A56438)
Case Axial-Flow...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2020 MACK P164T (A58214)
2020 MACK P164T...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
