Why you should change your oil
   / Why you should change your oil #141
hid for sure then, but not led.
i know a guy with led lamps and they are super super spendy.. and when you replace them.. the cluster has to be replaced.. or sent in and they repalce units of it! OMG$$$$
   / Why you should change your oil #142
So Chris, what is currently happening with your BIL's truck? Engine swap? Has anyone taken it apart yet? I'm curious to know what the specific mode of failure was (beside the general lack of maintenance).
Right now its sitting at my friends shop. I gave him the filter I cut open and he was astonished. He could not believe it still ran. He said the metal was mostly from the timing chain and of course bearing, lobes, journsls, ect. He thinks all the issues started in the timing chain area though.
My BIL has a second vehicle so its just sitting while they try to get Ford to warranty it.
Chris
Chris
   / Why you should change your oil #145
Wow, no conscience there huh?
   / Why you should change your oil #146
Chris
The Variable cam timing works off of oil pressure and so do the timing chain tensioners. I can't remember off the top of my head how much oil pressure it takes to operate the VCT. I imagine it was extremely low on oil pressure so the timing chains were probably slapping around really bad making a lot of noise and the VCT could not operate properly which will make noise.
Not sure. After I changed the oil the pressure gauge was right in the middle.
Chris
   / Why you should change your oil #148
Chris
That's because Ford doesn't use an oil pressure gauge. It's an on/off switch that just grounds with any pressure over about 8psi. This makes the gauge go to the midpoint.
As far as I know GM is the only domestic or otherwise that still uses a proper functioning gauge.
   / Why you should change your oil #150
this doesn't 'appear' to be how it really works... at least on my fords. at startup, the op comes up within a sec or so, hits lower mid of guage, in another couple sec's, hit mid or a hair above.. pretty much stays there.
if it was really an open /closed issue.. seems the gauge would hit it's mark as soon as it came up and not adjust after another second? unless the gauge is some how settling...
ot saying you are wrong on this.. just saying it appears to act different inthe 3 powerstrokes I have..
   / Why you should change your oil #151
Unless the diesels are different, he's right on the OP sender, its just a switch on the gas engines, they dont fluctuate. Dont see why the diesel would be different.
   / Why you should change your oil #152
i swear it seems to come up to a point, then move a hair higher? I'll have to look real close tonight when leaving work.. maybee I'm getting the yukon mixed int here.. I know it's oil pressure gauge changes with rpm.. etc..
   / Why you should change your oil #153
Chris
I have seen them right in the middle but you put a mechanical gauge in it and it show 5psi.
   / Why you should change your oil #154
It is after a certain year. I am not sure what all models are like that. It is not just Ford that is like that. I have changed the oil in a lot of vehicles and as soon as they fire the gauge is in the middle.
Watch this Ranger how quick the gauge comes up.
   / Why you should change your oil #155
The diesels are different. They use a proper sending unit. But the do use a 'slosh module' that dumbs down the signal and basically shows you an average reading without the highs and lows.
   / Why you should change your oil #156
now I'm wondering. :)
I'm going to pay extra attention to mine this weekend.
my 350 and 450 are older.. IE.. 99 early and late models respectively. Setting here at the screen.. my mind is telling me the needle throbs to lower mid, then ups to about mid after a total of 2 seconds. lower mid after a second.. seems to do this on both 350/450. Can't say for sure on the 250.. it's my work truck and I'm usually thinking about work when I get within 5' of it.. :)
   / Why you should change your oil #157
ok, so it's a compensated gauge setup.. I'm familiar with those... keeps you from having the 'nervous' gauge syndrome like some mechanicals have when run with no restriction orifice.
Feel better now.. thought I was going crazy :)
   / Why you should change your oil #158
I don't think there are like that. I think you have to get up into the mid 2000's. I prefer a mechanical gauge because you really know what you have.
   / Why you should change your oil #159
Could be, I know Dodge's use a switch to show pressure to the ECM. The ECM then uses coolant temp and rpm inputs to determine what the dummy gauge shows, not a real reading at all. I have installed Isspro gauges in my truck, including a real oil pressure gauge.
   / Why you should change your oil #160
Many if not most oil pressure "gages" are just fancy idiot lights nowadays. I remember when Saturn came out they had real gages. After a couple years they went to the "idiot gage" type. I asked a sales guy (an actually knowledgeable one) why after a test drive and he said "I get that you understand it, but we would get many calls from people saying the oil pressure gage was going all over the map as they drove and asking us to fix it. Far easier for the company to just make it a dumb gage..."
The average idiot is too much below average, IMHO...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
159118 (A60430)
159118 (A60430)
BOBCAT T300 SKID STEER (A60429)
BOBCAT T300 SKID...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
GIYI VB59-59" HYD VIBRATING BUCKET (A60430)
GIYI VB59-59" HYD...
2018 Kubota U17 (A53317)
2018 Kubota U17...
