Why you should change your oil
   / Why you should change your oil #181
I sure miss Builder.
Chris
What are you inferring "builder" as it seems to be an "inside joke".
Been around TBN for a long time, so what gives?
   / Why you should change your oil #182
I think he believes someone changed their screen name...Could be wrong.
   / Why you should change your oil #183
   / Why you should change your oil #184
An actual sending unit on a 2001 f150?
That's the first I've heard that. No calling you a liar or anything, but I've replaced a lot of oil sending units on those generation of trucks they've all been the on/off variety.
Its been a few years, but as far as I remember, there was actually two sending units. One for the gauge and one for the ECM. The guage one had a "bulb" to it, so I thought it was a full sending unit. This was on a 4.2L V6.
I was also under the impression that it was a full sending unit, as you could removing the damping to the gauge by bypassing a set of resistors in the cluster. Of course I'm speaking from memory of info I learned 8-9 years ago, so it could be a little cloudy.
   / Why you should change your oil #185
You may be correct. With a scan gauge hooked to the OBDII port you can get exact readings on almost all parameters.
   / Why you should change your oil #186
i would think the psd's would have a real sender for the ECU to look at. The fuel injection on the PSD's uses oil in part of the process.. etc.
   / Why you should change your oil #187
I'm all for real gauges but make them an option so my wife isn't flippin out everytime the needle isn't in the "normal" range.
Builder was another poster with very valuable information and "real world" experience as a contractor with heavy equipment and not some weekend mechanic repeating the same stories of their neighbors.
As is typical around here though, he wasn't a Ford fan so he was blasted and put down at every chance until giving up and not posting in this area anymore...
I miss his information as well along with pics of that beautiful 4x4 dump truck. Just search his username and you'll see.
   / Why you should change your oil #188
I'm all for real gauges but make them an option so my wife isn't flippin out everytime the needle isn't in the "normal" range..
I 'WANT' my wife to flip out when needle is not where it should be.
that's how you save a vehicle from overheating, or running without oil.
What I'd be in favor of are customizeable digital dashes. with flat touchscreen panel tech so easy to do ( ipads..e tc.. ) you could configure a dash with any gauge set the ecu/engine sensors could support. have analog needle gauge display.. digital segment display.. etc., numerical display.
you should even be able to configure it for some basics.. like spedo and idiot lamps .. like a simple message center... just show speed and then if a problem occurs.. have the dash flash red overtones to get your attention.
tech has been available for this for MANY years. that display and a simple DSP.. and the average cellphone has enough cpu power to run it.
heck.. a bluetooth tether to your smartphone/pad/tablet and display extra engine data that way.. etc.
   / Why you should change your oil #189
You can get the "Torque" app for android. That lets watch your gauage and sensors. You can also use it for a scanner in generic OBDII. You have to buy a bluetooth adapter for the OBDII port.
   / Why you should change your oil #190
Where??
   / Why you should change your oil #191
now if the dash just had all that built in. had one info center.. have radio controls and all there.. could be all touch screen even.. if you wanted it.
grab a gauge and enlarge it with 2 fingers like on a smart phone.. move a gauge somewhere else.. don't have anything hard coded in place.. other than a few usable defaults to just get in and go and customize later. maybee have a few memory spots to save different gauge setups..e tc..
   / Why you should change your oil #192
You can get a el cheapo of ebay. I got one and it did not work.
Then I was going to get This one. It looked like the best for the money but I never did buy one.
Here is a list of adapters.
   / Why you should change your oil #193
Different oil pressure. The HEUI system uses the HPOP to pressurize oil to pressures between 600 and 3000psi. It uses the IPR and ICP to regulate and monitor the pressure.
   / Why you should change your oil #194
YeA that would be cool, but its not like trucks do not already cost to much, all we need is electronics that will last 10 years then tweak out. I mean these trucks today cost as much as a small starter home!!!
   / Why you should change your oil #195
and I see my point completely sailed over your head.
think outside the box.
if you have no oil pressure.. which your oil pressure gauge should be telling you that you are having issues... then you will be having injection issues soon to.
say you have a leak and are loosing oil.. most machines I've seen start showing lower oil pressure and fluctuations when you get to the point where the pickup is having troubling getting oil from the sump. around that time you should be having injection issues as well. IE.. everything's related.
   / Why you should change your oil #196
really? a 50K$ truck and you are complaining about a 500$ touch screen mod?
leave the chrome 4" tail pipe down elbow off and call it even.. :)
it may even be cheaper if you figure that you don't need all those gauge bodies in that dash cluster, and instead just need a screen interfaced to the 'new' ecu.// etc..
   / Why you should change your oil #197
I neither own a truck worth over $3 grand nor have a smart phone. I wont pay for a 50k truck or for a phone that I cant use more than half the day.
   / Why you should change your oil #198
Thanks dmace for the reply that clears it up some. I'll just stay agnostic on brands as its how you treat them.
Carl
   / Why you should change your oil #199
I've always owned used trucks too.. :)
   / Why you should change your oil #200
Personnally I think it would be another under used toy for me.
Check Engine Diagnostics * not something my OBDII reader can't do.
Real-time gauges *could be nice IF there are more gauges then I already have if the dash.
Fuel Efficiency and MPG * Already in the info center
Engine Sensors * Would neat, not sure how usefull though
Customizable Dashboard *cool factor
Real-time Dyno
Data Logging
The data logging might be real nice to help diagnostics if you logged good mile, so you could refer to them when you have real problems.
Thanks for the links tho. I think I'll leave this item on "it might be nice to have" list.
GPS Track Mapping
Skid Pad
Video recording and data overlay
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
