Why SSQA?
/ Why SSQA? #61
This is the Bob-Tach style adapter that I DIYed onto the IH 584,,
The adapter is VERY heavy,, probably close to 300 pounds.
It probably came off a skid steer that was over 150 HP.
Then, I added close to 50 pounds of steel making an adapter so that it would pin to the loader arms.
The weight does not bother me,,
a neighbor drove his 1978 Ford F150 off the side of a small farm bridge.
My forks were able to pick up the front of the truck,, and put it back on top of the bridge.
Nothing I will ever want to lift will weigh that much,,, :D
/ Why SSQA? #64
On baling hay, we have a Kubota L3830 which has 32 PTO horsepower and it works well baling hay with an older New Holland hay baler I think it's a 269 but don't me.
Aaron Z
/ Why SSQA? #65
Euro/Global is the farm tractor standard here now, even Deere finally went to it from their proprietary systems.
Skidsteer is still the norm on compacts and smaller utilities.
/ Why SSQA? #66
Proprietary I thought meant having the exclusive legal right, if that is the case why is it so easy to get Deere carriers from aftermarket sources. Deere (or any of the big oems) do not strike me as companies that would allow there to be so many copycats available on the market. Maybe it is more of an expired patent issue?.... not a legal scholar myself but the only carrier I have ever struggled to get via aftermarket channels is the old early 90's and before skid steer carrier that a few users adopted before joining to the now bobcat style ssqa but they where tough to get from the oems also. IMAO
/ Why SSQA? #67
Proprietary more like they came up with and used, not so much that no one else could use it. Perhaps "from their own design couplers" would have better used. Although I can't readily recall many after market Deere coupler attachments around here, was mainly the 500 series "lynch pin" or 600/700 series "latches on each bucket" systems, most people buying those bought the attachments at the same time. Wasn't uncommon to see a tractor traded with the bucket, forks spears etc all with it for new ones. Now you see tractors traded just with a loader with euro coupler and no bucket!
/ Why SSQA? #68
Proprietary in this context means non-universal. You can find attachments out there from other makers but you won't find those coupling devices on anything but Deere loaders. Any way you slice it, the market and supply for these attachments is a fraction of those made and sold for SSQA or euro couplers.
/ Why SSQA? #69
/ Why SSQA? #70
^ yes, this is what I meant when I used the word Proprietary. I did not not explain it as well as you did.
/ Why SSQA? #72
Yep, lots of trips with smaller "bites". grinning all the way..:D
I wouldn't even care to park the tractor and move it by hand.
/ Why SSQA? #74
That surprise's me, you give some very good answers here and I suspected you worked at Finch's JD dealership. :thumbsup:
Well thanks! But nope...I do however live about 3 miles (as the crow flies) from the Westminster location.
/ Why SSQA?
Is the bucket attach system on a new 2016 Kubota an SSQA system? I know it is quick on and off, similar to the JD, but I didn't get the impression that it was skid-steer compatible.
/ Why SSQA? #77
Generally, yes they are except they call it the "2 Lever Quick Coupler". Some very small BX models with one dump cylinder do have a Kubota proprietary system however.
/ Why SSQA? #79
Kubota what?. It depends. Some of the smaller B series have a proprietary system. Some just have pin on (shiver :eek:) etc.. Gotta say which one you are looking at.
/ Why SSQA?
Indeed, My mistake. It was an L3901. I'm basically comparing the JD 3039R and the Kubota L3901. Leaning Green, but the money is still in the bank at the moment
2022 EZ-GO ELITE...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
KMC 3386 (A64119)
KMC 3386 (A64119)
2016 Kawasaki 62Z7 Articulated Wheel Loader (A61572)
2016 Kawasaki 62Z7...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
