Why SSQA?
/ Why SSQA? #41
I just traded in a perfectly good 1720 New Holland with a nice Stoll FEL for a Workmaster 50 in part due to the SSQA feature on the FEL. I know that I stepped up from a compact to a utility sized tractor but the SSQA is so nice to change from bucket to forks. I'm getting a grapple and the hydraulics for my tractor this week so that will be another nice feature of the SSQA. Like RickB stated in the larger CUT or utility units most manufacturers have utilized this type of attachment system. Noting wrong with the JD system but your options are for Deere attachment compatibility units only.
/ Why SSQA? #42
I am a grapple user too. I used mine just yesterday to pick up whole 30+ foot trees and take them to the brush pile. Sure I have forks too, they are great for picking up pallets. :) Can you stack logs and brush on forks? sure you can. You get off and stack it carefully, and go very slow so it doesn't fall off, or you put on your grapple, grab a mouthful and take off for the pile. I had tractors for decades before I bought a grapple. In fact looking a people's grapples here on TBN is what prompted me to get one. They sure are handy.
/ Why SSQA? #43
The SSQA has one major drawback compared to the JD system,,, IT IS HEAVY!!
So, if the SSQA is heavier, that means less load in the bucket,, each and EVERY bucket full.
The JD quick attach has one major drawback,, those linch pins used to hold the bucket on.
If you get any where NEAR a twig,, that twig will grab the linch pin, it is GONE.
If I had a dime for every linch pin I have lost over the last decade,,,
I could afford a cup of coffee at Starbucks,,, :laughing:
(NOTE: I have a SSQA on my IH 584,, I did a DIY install of a SSQA takeoff)
/ Why SSQA? #44
Maybe so. But probably not in the way you think. I may be wishing I had more horses and the ability to run a small square baler for a few hundred bales a year. I doubt the 39 horses in this thing will do that.
I'm somewhat of a rookie, but I've also spent the last 15+ years making do with an 8N so I know something about what has to happen.
That tractor will pull a small square baler. Just stay out of big hills since the weight of the baler and possibly wagon will push you around into spots that you don't want to be in. You have enough HP however.
/ Why SSQA? #45
Some aftermarket ones are heavy about 150-175 lbs but most stock ones are relatively light 70-90 lbs. I put a heavier one one on my tractor and it did not effect the performance much at all. It does make my life much easier and is well with the minuscule loss of performance. I have lost some lynch pins off of three point equipment, I think that is the weak point of the JDQA system. The I'd one probably takes about 10 seconds more to attach than the SSQA. Plus I usually have a lunch pin close on one of my fingers and they hurt. If I had the JDQA I would buy the black stronger lynch pins.
/ Why SSQA?
I'm pretty sure I can solve the lynch pin problem. That doesn't worry me at all.
The weight of the SSQA does, but not a whole lot. I don't really know what these things can lift in terms of the objects that I want to move. I know it's rated for 1598 lbs or something like that (or 1150 lbs on the on-line) specs, but I have no idea what a 10 ft ash log weighs and relative to those numbers. Saturday. I'll simply try to pick it up.
The grapple - that is one sexy, attractive, t-rex of toy. I can see why folks might want one. Maybe even me. I wonder if JD even makes one. I suspect I'd have to add a couple more hydraulic lines up front to run it. But anyway, that's the biggest argument for the SSQA.
Thanks for the comments on the hay baler. I don't know if I'll ever do it, but I have 2 horses, and if we move from the acreage we have now to one with hayable land, then I would give it a shot. I'd pick up bales separate.
Steve, your long set of comments were great. You have me thinking about not only grapples but weight. I am trying to NOT fill the tires. My 8N has loaded tires and it's super helpful of course. But the wife wants to ditch the lawntractor and mow with the 3039. I like the idea of one less motorized piece of equipment to store and maintain. But driving the 3039 on the lawn with loaded R4 industrial tires will be a bit much I think. So, I was thinking I would put chains on it in the winter (which are pretty useful anyway). And then I have a 3 point box that I used to use for hauling stuff years ago. I would rebuild that into a large rear weight in place of loaded tires to use whenever I'm working with the FEL. I will definitely opt for a Quick Hitch on the 3 point to make that whole on-off thing easier.
This thread has turned out to be much longer and more useful than I thought it would be. Many thanks to all. I look forward to Saturday to see what this little green bug of a tractor can really do.
/ Why SSQA? #47
You will be able to find plenty of grapples with the JDQA setup. Yes they of course will require the hydraulic lines run up to the front, but that is doable.
Here is a handy calculator to get an idea of how much that log is going to weigh.
Timber and Lumber Calculators at WOODWEB
/ Why SSQA?
James, thanks... 1150 lbs with my guesses on dimensions. If that's correct, it should be a good test. I may need to put something like the mower on the rear to help with balance.
It's a heck of a lot of money for these green things but it is sort of fun to shop around. Learn a little bit everyday.
/ Why SSQA? #49
Oh, absolutely, you will need a heavy rear weight on the rear. Don't even attempt picking of a log of that size without proper ballast. I know you are trying to avoid liquid ballast, and you can do without it in many circumstances, BUT if you don't have it, be SURE to always keep proper ballast on the 3pt when doing any loader work. I have about 800 lbs in my ballast barrel now and sometimes wish for more. I also have liquid ballast in the tires. There is nothing more disconcerting than having one or both of the rear tires off of the ground.
One example of when only liquid ballast will help you is when you are doing some kind of rear blade work. You often lose traction when blading dirt or gravel or something, and the blade itself doesn't help you as it is on the ground and resisting your forward motion. But the liquid ballast can mean the difference in moving forward or spinning your wheels. I can understand your reluctance to add liquid ballast because of wanting to keep your tractor light on the lawn.
/ Why SSQA?
James, the rear blade issue I see coming. I blade snow - at least in the old days before it went the way of the dodo - with te rear blade. And loaded tires are hard to beat for that. However, with 4x4 and chains and the FEL on the front, maybe I get by that way okay. This whole idea of mowing the lawn with the 3039 is misguided I think but I would like to dump the lawn buggy.
/ Why SSQA? #51
Well, you will have to decide what your priorities are on the lawn thing. Personally I think your 3039 might be a bit large for lawn duty, but you have to decide that for yourself. A lot depends on how much straight mowing and how much around the rose bush mowing you have to do. :)
Tractors do their work by weight, the more weight the more work that can be done. The first four letters in Tractor is T R A C. as in traction. :) gotta have traction or a tractor is just an expensive noisy toy.
/ Why SSQA? #53
Thanks guys. I'm fascinated by all the different gear you have over there. I did put a 4000 hours on an ASV positrack and thought the SSQA was a pretty neat design. I made an adapter plate so all the euro stuff for the tractors would also fit, did a lot of bale work with it etc.
The JDQA seems a hybrid of the two but it's not always good to be different!
So what is the standard over there for large tractors? Euro or the SSQA?
By large, say a 180hp-200hp tractor with a loader? Don't think you need much more on a FEL
The global attachment system is actually more the norm today than oem specific carriers for ag tractors. Or local dealer has nothing on the lot over about 80 hp that does not have a global carrier. They only special order oem carrier's as needed, the global version has been around for many years is really just a scaled down version of what has been use on industrial machines (like payloaders) for even longer. Part of that has to do with how easy it is to make the carrier's hydraulically actuated since all it requires is moving the pin linkage assy to the left or the right.
/ Why SSQA? #54
I am a grapple user too. I used mine just yesterday to pick up whole 30+ foot trees and take them to the brush pile. Sure I have forks too, they are great for picking up pallets. :) Can you stack logs and brush on forks? sure you can. You get off and stack it carefully, and go very slow so it doesn't fall off, or you put on your grapple, grab a mouthful and take off for the pile. I had tractors for decades before I bought a grapple. In fact looking a people's grapples here on TBN is what prompted me to get one. They sure are handy. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=497225"/>
Plus, their great for scaring people!
/ Why SSQA? #55
I've never found anything that fit in my bucket that it wouldn't lift. Lead might be an exception, but there's not much of that laying around.
/ Why SSQA? #56
Gold bars might be an issue also. But in a good way:D
/ Why SSQA? #57
First I have to add a hearty +1 to what James has said - rear ballast / counterweight is an absolute must. I think our CK35 is a little lighter in the loader than the DK35 James has but he spec sheet still calls for 700lbs of rear ballast IN ADDITION TO loaded rears - so see what the owners manual tells you & build your counterweight accordingly.
We built ours out of an old barrel that we filled with scrap iron & concrete. Then we added a 3PT Quick Hitch and it won't connect to our counterweight (bad geometry in the design on our part) :ashamed: So until I can do a little redesigning I generally hang our Rotary Cutter off the back. It's not 700lbs but it's enough for now.
As for the extra lines for the grapple - there are ready made kits that are pretty much bolt & go (W.R. Long is a popular one and I'm sure JD has a factory option as well) or with a little time & knowledge you can piece mill your own together. I did ours that way. If you decide to do yours then let me know; I can tell you all the things I did wrong so you don't repeat them. LOL
As for the mowing duties - I'll have to step back on that one because I have zero experience there but I understand your issues with the loaded vs unloaded tires.
Be sure to come back after the test ride and share your thoughts.
/ Why SSQA? #58
I don't know if you are familiar with the AMC zombie apocalypse series The Walking Dead, but I always thought that a large grapple equipped tractor would be very helpful in scooping up and disposing of all of those zombie bodies.:)
Maggie did use a large JD tractor to run over a particularly annoying and very noisy little automobile.:) I say put a grapple on that thing.
/ Why SSQA? #59
In that world, Ted had passed on (bless his heart) and they didn't have a tractor that needed a grapple on their way through NC to VA. For those that don't know this area very well, Alexandria is just outside Washington, DC and is 40 miles from any farm that has a tractor like that. And definitely no forests.
Those of us that live in this area think the writers could have done a better job scouting a geographic area that better fit their storyline.
/ Why SSQA? #60
Can someone post a pic of a "global carrier"?
Is that different than a Bob-Tach?
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
John Deere 400 (A64119)
John Deere 400...
