Why SSQA?
/ Why SSQA? #21
I remember very well the days of our 4020 JD tractor with pins to remove and put back in to go between the snow bucket or the hay fork. Make sure you carry a 5lb hammer and a large punch on the tractor to help remove one of the attachments. Then I always enjoyed immensely the 2 dozen or more trips on and off the tractor to get all of the 4 pins in place. 2 dozen trips, if everything went just perfectly. Yeah, I won't have another loader w/o a quick attach for the bucket, etc.
/ Why SSQA? #22
/ Why SSQA?
xfaxham.
I can see where you are going, but I'll hold off even so. If, 10+ yrs from now, I'm still kicking and need it, I'll probably be happy to spend the cash, and happier still that the money I could have spent on the SSQA was well invested and earned the price of a nice shiny new JDQA grapple in the meantime :) .
But you warned me, so you get first dibs on "I told ya so" :)
/ Why SSQA? #24
But you are going with a JDQA and not a standard JD pin on bucket, correct?
/ Why SSQA?
Yes. H165 loader with bucket and forks like the one in the video in the first post on this thread. I think it will be the best match for what I want to do. Not sure how much weight it can lift, but the dealer is bringing one out on Saturday and I'll find out. I have some large ash logs to lift with the forks (or not).
/ Why SSQA? #26
JD does offer SSQA as an option instead of their design. I would inquire as to the cost difference.
scdeerslayer,
I'm not much worried about any of that. I'd rather bet on what is, than what might, maybe, could be, someday. Thanks for your thoughts though.
It's much easier to plan ahead now than to regret the decision later. SSQA was the best modification to my previous tractor.
Don't know what I'd do without it. And there are a multitude of sources for lighter compact tractor SSQA attachments so I never worry about the system being too heavy.
Jay
/ Why SSQA? #27
I was involved in the purchase of a JD 3720 some years back. I had to pitch a fit, get rude, and provide the bundle number to the sales guy to get SSQA on the FEL. Even then I had to go to a competitive dealer to buy a bucket. Deere dealer couldn't find one to order, even.
/ Why SSQA? #28
Now that it is fully clear that you are going with the JDQA I have no problem with that. It sounds like they make plenty of other things to fit their's as well. I was concerned if you were making this sizable investment and then dealing with pin hookups.
/ Why SSQA? #29
On another thread, I asked "I'm about to buy a new tractor - about 39 horses. Why would I really want SSQA adapter for it if all I plan on using on the front end is the bucket or forks?" To which someone replied, "That's really a topic for another thread. Changing between a bucket and forks without SSQA is going to be a real PITA." If you go to the 9:05 mark in this video, it shows someone switching from bucket to forks faster than I can type this. I'm wondering that the advantage of SSQA is and whether i need it. I don't need anything faster than what is shown here: YouTube Link: https://www.youtube.com/watch?v=kkePTlU9pNU&t=373s
Man, that tractor has some cool features! How much is it?
/ Why SSQA? #30
Just a lazy uninformed salesperson, all colors seem to have them. I could find all that info in under 5 minutes using the free to anyone JDParts system.
/ Why SSQA? #31
And I don't and have never worked for John Deere! :)
/ Why SSQA?
Kenny,
We may have to talk about a couple of those hooks. Look really interesting to me if they bucket on this thing is strong enough to take it. I'll find out more on the weekend when I have a sample to tryout.
The SSQA does sound promising. I can see advantages. I'll chew on it for a while longer yet, but I'm close to pulling the trigger and right how JDQA is winning, but not by a lot.
/ Why SSQA?
Well, that sort of depends on how I fit it out. Maybe $36k when all said and done but I think a bit less. I've got a list of stuff and I'll have to consider the details a bit more. Base price for the tractor is something between $25 and $26K.
/ Why SSQA? #35
I don't see going further on the front end than the forks and the bucket. I've spend 16 yrs with an 8n and no FEL at all. I think I'm good with the fork and bucket arrangement. I'm going to gamble on it anyway.
Thanks.
Now to resolve loaded tires or chains, and the tire position questions. With those, I should have it all figured - I think.
Having been in your shoes years back, I'll bet this is a thought you'll come back to a few years from now as your needs evolve.
/ Why SSQA?
Maybe so. But probably not in the way you think. I may be wishing I had more horses and the ability to run a small square baler for a few hundred bales a year. I doubt the 39 horses in this thing will do that.
I'm somewhat of a rookie, but I've also spent the last 15+ years making do with an 8N so I know something about what has to happen.
/ Why SSQA? #37
Those small balers don't really take a lot to drive. I'd jump at the chance to try your tractor on one, as long as it wasn't huge steep hills... if a 20hp Wisconsin will power one easily then you should have enough. You don't need to pull it fast.. Baling is a good sideline if you have summer to play with, a good earner if you have the gear.
Glad to hear that you've got your machine sorted out to your liking, too. Keep us posted
/ Why SSQA? #38
That's good, because either QA is better than the pins.
/ Why SSQA? #39
The video shows a quick connect setup - that is Deere proprietary, not the more universal SSQA. Very similar in function, and speed, but you'll be a bit more limited in implement selection since you'll only be able to get Deere style implements. If you'll be purchasing brand new, and never sharing, it likely won't be an issue.
No quick connect at all would require removing 4 pins (two pivot pins, two cylinder pins), and reinstalling those 4 pins every time you change attachments. Very time consuming, and messy due to all the grease. That's not what is shown in the video.
On time consuming with out it, I had a JD 96 hp 4020 with an 8' loader bucket. Had 2 cylinders meaning 4 hookup points. I work alone. Bucket weighs several hundred pounds. 2 fixed lower points to line up and then the top two which have a little margin as the cylinders have a little flop. However, even after you get the bottom lined up and up and down on-off the tractor to get it all lined up, then comes the cylinders......usually one protrudes just enough more or less than the other to make hookup next to impossible without more up and down and up and down in and out of the seat, up and down.
My Branson 6530 has the Skid steer quick attach adapter (whatever you call it) and it takes all of 10 seconds to load an implement from the seat....course I have to get off and push the lock levers down but................My swaps are between bucket and hay forks.
/ Why SSQA? #40
embuggerance - I love it!
Thanks.
Well the QA question has been asked and answered (several times) - Get which ever suits you best but definitely get a QA of some sort.
Now - to address the rest of your questions / comments. Our first tractor was also an 8N - still got it (just finished the hydraulic rebuild last Sat - fun stuff). My father bought it when I was in my Preteen years. I'll be 45 this year, so to say I have grown up on it would be fair.
We just upgraded to the Kioti in Late fall '15 and I can promise you, no matter how well you got by with the 8N, you'll marvel at all the "stuff" you can do now that you couldn't before. So don't discount those with the "plan ahead" advice. My father fell into that trap and will today admit (albeit very grudgingly) that we should have gone one step larger. That being said I still love the CK and it will do what ever I need, sometimes I just have to make more trips ;)
Loaded tires vs Chains - Load the tires. You'll need counterweight for the FEL anyway, it's a relatively small cost in the big scheme (most dealers will include it in the price), and you can always add chains later if need be.
Tire position (I'm assuming you mean width) I have been to IA a few times and I know you're a teenie bit flatter than us hillbillys in SW VA, but unless you have some other reason / restriction for keeping them narrow, the extra bit of stability the wider stance gives you is worth it.
And lastly - let me second (third, fifth, whatever) the advice on a grapple. I wanted one before we ever started tractor shopping. It took me a year of having the Kioti before I could convince Dad it would be a good thing. Again today he admits I am right (very slowly and after much prodding). And as someone who also has pallet forks - unless you have a specific use that only forks will do (for us it's moving hay bales) then skip the forks and get the grapple.
Dad thought we could get by moving brush, downed trees/logs, etc. with just the forks (so we bought them first) and you can if you work at it but the grapple makes it so much easier.
I will add that putting a thumb on your bucket, forks, or having it movable between both is also a viable option that others here have done. I simply had a need for the root / rock gathering abilities of the grapple also.
Well - these are my thoughts and opinions - worth exactly what you paid to get them and double your money back if not satisfied.
Whatever you choose to do I know you're going to be thrilled with the upgrade and I wish you many happy years tractoring with it.
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2025 48in Land Leveler Skid Steer Attachment (A66734)
2025 48in Land...
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
