I'm pretty sure I can solve the lynch pin problem. That doesn't worry me at all.
The weight of the SSQA does, but not a whole lot. I don't really know what these things can lift in terms of the objects that I want to move. I know it's rated for 1598 lbs or something like that (or 1150 lbs on the on-line) specs, but I have no idea what a 10 ft ash log weighs and relative to those numbers. Saturday. I'll simply try to pick it up.
The
grapple - that is one sexy, attractive, t-rex of toy. I can see why folks might want one. Maybe even me. I wonder if JD even makes one. I suspect I'd have to add a couple more hydraulic lines up front to run it. But anyway, that's the biggest argument for the SSQA.
Thanks for the comments on the hay baler. I don't know if I'll ever do it, but I have 2 horses, and if we move from the acreage we have now to one with hayable land, then I would give it a shot. I'd pick up bales separate.
Steve, your long set of comments were great. You have me thinking about not only grapples but weight. I am trying to NOT fill the tires. My 8N has loaded tires and it's super helpful of course. But the wife wants to ditch the lawntractor and mow with the 3039. I like the idea of one less motorized piece of equipment to store and maintain. But driving the 3039 on the lawn with loaded R4 industrial tires will be a bit much I think. So, I was thinking I would put chains on it in the winter (which are pretty useful anyway). And then I have a 3 point box that I used to use for hauling stuff years ago. I would rebuild that into a large rear weight in place of loaded tires to use whenever I'm working with the FEL. I will definitely opt for a Quick Hitch on the 3 point to make that whole on-off thing easier.
This thread has turned out to be much longer and more useful than I thought it would be. Many thanks to all. I look forward to Saturday to see what this little green bug of a tractor can really do.
