Tires Why not fill front tires?
/ Why not fill front tires? #42
If the tires are loaded to the top of the rim only, there is plenty of give left in the tire. I actually prefer the ride and handling of the tractor with the filled tires. If someone were to fill the tires solid, that is the only time that I can see that there would be a real problem.
Just my opinion.
/ Why not fill front tires? #43
I grew up in Iowa and started operating tractors in 1958. At that time tractors were much smaller and lighter. 50hp was a big tractor. Carrying fluid in the tires was uncommon even then. Wheel weights were the answer. If front-end weight is necessary and you are not carrying external weights on a front bracket, install it. Fluid can be corrosive. This is simply a recommendation. Like George Carlin said, "go ahead and pray..what can it hurt"
/ Why not fill front tires? #44
I grew up in Iowa and started operating tractors in 1958. .....Fluid can be corrosive. .."
Lots more non corrosive options today compared to CaCl. RimGuard and Windshield washer fluid are both non corrosive. For those in the South even just plain water is a viable option and essentially non corrosive.
There are some benefits to wheel weights but they can be quite pricey and are not available for all tractor models.
/ Why not fill front tires? #47
I'm running a Kubota M5040 with Rimguard in fronts and rears. I found filled fronts w/ice chains give me more control/traction while doing snow removal with an 8' front blade. So far 300 hours with this setup and no problems. BTW, my dealer said he has never seen a problem develop from using filled fronts and he's been doing this over 25 years.
Terry
/ Why not fill front tires? #48
Loading of the front tyres does nothing for stability as the front axle pivots on the center pin . If you ever get to a position where it does help you , get ready to hang on as the axle stops are pretty high up :D .
/ Why not fill front tires? #49
It is obvious by the number of post on this topic that our forum is divided on this topic. My personal opinion is like one member said quoting George Carlin, What can it hurt. It may or may not add to stability, but it for sure adds some traction. I think is is preferable to add 50# of weight to the tire rather than hang it on the frame as far as wear goes. As for dampening, the 25% air in the top will dampen quite sufficiently and I have never heard of water creating a problem with steering stability in a tractor. I cant believe that it would even be noticeable on one of these small CUT or SCUT since they at most would only hold 4-5 gallons of liquid and many of them less than that. Folks talk about wear on the tires: most of the wear on a 4WD front tire is from the overspeed ratio of the front to the read tire. It is set up to run a little faster than the rear when new like 1.02 to 1 or something like that. As the front tire wears from this minute slipping, then the ratio keeps getting closer to 1:1 and the wear slows down. I personally wouldnt buy any tractor if the dealer told me I couldnt load the front tires. I would simply tell him that if his tractor is designed so light that adding 50# or weight to the front is going to damage it then I dont want it because I plan to put more than 50# in my FEL which would be the same axle loading regardless of where the load came from.
That is just my 10cents worth.
/ Why not fill front tires? #50
Foam filled front tires = less front flat tires ????
/ Why not fill front tires? #51
I haven't noticed any compression issues with the fronts on my JD3720 with the loader full. In fact, when I have the pressure to max, I still get as much compression as I would feel comfortable with. I wouldn't want any more.
The filled fronts don't bounce as much. That does aide stability. It isn't always a side-to-side issue that ends up causing problems.
/ Why not fill front tires? #52
Art, how many CUTs with less than several thousand hours have you ever had to replace ball joints on? I don't believe I've ever seen a post on TBN regarding worn out ball joints so this is just new to me. I am sure it is an issue with older machines with many thousands of hours and decades of service but is this really a reason not to load fronts? I'm wondering if you rebuild engines more often than front suspensions. Is it the light weight Kubotas with this issue or do heavier machines also have the problem?
Actually I've seen it more often on other makes then what we sell as being common even some models without the added weight that just with "normal" loader work broke steering components with less then 1000 hours.
Kubotas weight makes it easy for the weight to be put where it needs to be and still remain nimble and well balanced. Heavy machines burn more fuel and adds stress to driveline components.
On most tractors steering parts will begin to fail around 2000 to 3000 hours on loader tractors although it depends a lot on the amount and type of use. You can double that number on tractors without loaders or those that don't carry the loader all the time.
Engines we work with will last 5000 hours with little or no effort although lack of maintence will fail sooner, they will also go triple that!
/ Why not fill front tires? #53
I agree foam filled fronts are the way to go. Expensive though.
/ Why not fill front tires? #54
My experience.
Loaded frts leaked as the tiny valve corroded from calcium.
Slow un-noticed leakage totally rotted out rim and replacement was a major expense.
Really don't find much differance with the now unloaded fronts.
/ Why not fill front tires? #55
My experience.
That's a calcium problem. There are much better options now. No one I know still uses calcium.
/ Why not fill front tires? #56
I have a 1715 N/H FWD 27 HP. All four tires are loaded & all four tires have been turned around to the wide setting. They don't recomend turning frount around but it doesn't have loader. I use on West Virginia Hillsides and I need all the help I can get. I as use R-1 Tires as R-4's don't want to stay put on the side of a hill. It does a good job I think every pound helps in my case.
Hesston 3717 4-basket Pull-type Hay Tedder (A66408)
Hesston 3717...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
New Holland 451 Sickle Bar Mower (A66408)
New Holland 451...
2012 KENWORTH T370 CAB & CHASSIS (A65643)
2012 KENWORTH T370...
LS XR4046 Tractor with Front End Loader (A65579)
LS XR4046 Tractor...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
