Why huge differentials on trucks?
   / Why huge differentials on trucks? #61
I can understand the torque bit, especially for large equipment. However, how do they keep the ratio down to around 4.0 in regular pickups with such huge ring gears? Ratio on the tiny Miata differential is 4.1. Think the ratio in my Tacoma is about 3.6. It revs MUCH lower at speed than the Miata.
Most trucks get those granny gears via the gearbox and/or transfer case, not in the differential.
Ralph
The car is geared a lot higher overall. Compare the trans ratio. A truck with a 4:11 rear end and a 1-1:25 overdrive gear will probably be at 3,000 rpm to maintain 70 mph. I’d be fairly surprised if the car is really got 4-1 gears in the rear end. With such little tires you’d have an effective gear reduction of a lot more than a pickup. It doesn’t make any sense to put 2 or 3 overdrive gears in the trans to make up for a rear end gear that’s too low.
   / Why huge differentials on trucks? #62
Force applied and material strength required to oppose force.
   / Why huge differentials on trucks? #63
Good thread. I was reading about Mercedes Benz EV trucks with no transmission or differential because the motor output shaft is at the wheel. I grew up in an area where they used "third members" instead of differentials. Maybe I should have put that in the You Might be Old thread.
Yep, as well as "rear end" and "pumpkin".
   / Why huge differentials on trucks? #64
The first time I peaked under the Taco Wagon( Ram Power Wagon ) I noticed how enormous both ends were. The front & rear are both - Dana Spicer 80 Track Lok. I have the electrically activated locking knob on the lower dash in the cab.
   / Why huge differentials on trucks? #65
Trucks have pumpkins....Miatas have small gourds.
   / Why huge differentials on trucks? #66
Dana 80s are very strong systems. The e-lock system demands strong systems. The rear axle is also equipped with a limit slip for normal driving. A full understanding of the locking system should be applied when using this system. Very easy to damage the powertrain when both axles are locked. The manufacturer added every precaution they could to protect the vehicle from the inexperienced operator. Lockers will only engage when T-case is in 4Lo. Front locker will not engage unless rear locker is engaged.
Very capable system. To quote a saying my Dad used a lot. "What this requires is a high level of maturity". :D
   / Why huge differentials on trucks? #67
Miata should have a fraction of the maturity that we who post here represent. :D
Planetary final drives on axles reduce size & torque demand on pinion and increase what's then delivered to axles by their ratio. Works for tractors, HumVees, and .. mine trucks. Hummers gain ground clearance and can use lighter, faster turning drive components by spur reduction at hubs, IIRC at 2:1 or so.
   / Why huge differentials on trucks? #68
I thought that you were discussing vehicles, not women.
Oh, wait a minute...
   / Why huge differentials on trucks? #69
Up until the 90s, I thought all difs were of cast construction. Working in an automotive stamping/welding plant, I saw how they crafted a Dif out of stampings for HONDA and other vehicles.
I always feel rather guilty seeing my 3/4 ton Dif on the hoist at my Mechanics. That thing only transports little old me, 99.999% of the time!
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
