Why binders?
/ Why binders? #11
<font color="blue"> "if the winch malfunctions in any way......disaster strikes"
</font> We can put that in a lessons learned column. Guess that's why I was trying to clarify what you were writing.
/ Why binders? #12
That's exactly why I mentioned it in my very first post on this thread 6-26.
<font color="blue"> "I still toss a safety chain on the front end" </font>
It's just my "belt AND suspenders" mentality. /forums/images/graemlins/grin.gif
/ Why binders? #13
I use pull over binders. One post suggested using bungee cord to hold the handle, while this would work I wire the handle to the chain. Talk a small amount of wire and tread it through the eye in the end of the hadle and wrap it into a link and tie off. Never comes loose. I have a bud that thought this was me being to safe. He had MY tractor on his trailer and did not do this. When he go home, both biders had over centered and released. Good thing I made him set the gears and parking break.
Binders are great pieces of gear when used correctly.
/ Why binders? #14
<font color="blue"> I wire the handle to the chain. </font>
I use a 1" wide strip of self adhering Velcro. Run it through a link and around the handle.
OkieG
/ Why binders? #15
MLB,
I use a combination of one lever binder and one rachet binder.
Use one on the front chain, and the other on the rear chain.
<font color="blue"> Mine come loose more often that I would like and are a minor pain to use </font>
Use wire (ala higgy) or Velcro or...and they won't come loose. Use the lever binder on the first chain you place. Make it easy on yourself, throw the lever on the binder (and secure it with wire, etc.) with a little slack in the chain. Then, use tractor power to take slack out and tension the chain. Set the parking brake with the chain nice and tight. Finally, place a chain at the other end of your tractor and tighten it with the rachet binder. Now, everything is snug and you are ready to go.
OkieG
/ Why binders?
</font><font color="blue" class="small">( MLB,
OkieG )</font>
How is using a binder on the back that way any different than using a chain through a grab hook and then tensioned? (assuming the pull from the front as well)
/ Why binders? #17
<font color="blue"> How is using a binder on the back that way any different than using a chain through a grab hook and then tensioned? </font>
Sounds like a good idea. Using a grab hook instead of the lever binder might work really well. I don't know if grab hooks are weight rated like chain and binders are, but you would think they would be as strong as the chain they are "grabbing".
Does anyone know if grab hooks are rated? If they are, I'll turn my lever binder in for a grab hook. Thanks for the idea MLB!
OkieG
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2011 Chevrolet Express 2500 Cargo Van (A59230)
2011 Chevrolet...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2012 Toyota Camry Sedan (A59231)
2012 Toyota Camry...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
