which Harbor Freight quick hitch ?
/ which Harbor Freight quick hitch ? #1
wbyman
I need a quick hitch for my John Deere 4005 and I noticed Harbor Freight has a 26 1/2" wide and a 27 1/2" wide model. Which is the proper size to get ? Thanks !
/ which Harbor Freight quick hitch ? #2
Measure the distance between the pins on your implements and see which would be the best fit. You'll want some clearance between the inner surface of the QH and the implement to prevent binding.
BTW, it's possible the larger QH is for a category 2 3PH. I don't know the typical spacing on a Cat 2, so that is just a guess.
They both say category 1.
/ which Harbor Freight quick hitch ? #4
Then I suggest you get the one that best fits your implements with the least modification.
/ which Harbor Freight quick hitch ? #5
Item #98487 is cat II
#97214 is cat I
On the HF webpage there are clickable tabs to view a pdf of the product manual.
/ which Harbor Freight quick hitch ? #6
Then somebody's got something wrong. Full Cat 2 pin spacing is 32". What I think you're lookin' at is a Cat 1/2. Previous advice is germane, measure the distance between your implement lift pins. Otherwise the Cat 1/2 connects to Cat 1 lower lift arms, but has hooks big enough to pick up 2 lift pins.
I personally got so frustrated with my HF QH, that I replaced it with Pat's Easy Change hitch system. Never looked back.
//greg//
/ which Harbor Freight quick hitch ? #7
The 26 1/2 is the first one they offered it was usually a little too narrow for the implements. People were bending and or cutting them to make it wider like the newer model that is 27 1/2. The 27 1/2 is the one I bought, it is a cat 1 but the spacing makes it fit more implements. Measure your implements as Roy said it makes all the difference.
/ which Harbor Freight quick hitch ? #8
Ditto on the 27 1/2" size.
You can read a whole bunch of posts on the issue.
Also you'll possibly find that your implement pins are too small in diameter so you'll need to go to TSC and get bushings - cheapest way to work around this issues.
Another issue might be the hook for the top connection.
It fit some of my implements but not all.
I went to TSC and ordered the adapter they have for their quick hitch and now I use it for all the implements.
/ which Harbor Freight quick hitch ? #9
I went with the 27.5" between the pins as this goes along with the
ASAE category 1 dimensions.
/ which Harbor Freight quick hitch ? #12
A lot of older cat 1 implements were 26.5". Most of the newer cat1 implements are 27.5" and the cat 2 stuff is 32". I made the mistake of buying the 27.5" QH without measuring all of my implements and found this out the hard way. :eek: :ashamed: What I should have done was not buy one at all, just being lazy and it got me nowhere except a little bit poorer. ;)
More info coming soon. (A64557)
More info coming...
2023 Bobcat L28 (A64911)
2023 Bobcat L28...
TOTE OF HEAVYEQUIPMENT HOSES (A68842)
TOTE OF...
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2013 CHEVROLET 2500 HD (INOPERABLE) (A67714)
2013 CHEVROLET...
x (A68191)
x (A68191)
