Which Causes More Pollution?
/ Which Causes More Pollution? #21
Good question!
As said above you have to define pollution. Carbon footprint? Atmospheric only? Particulate?
On one hand when you chip them you're not (immediately) releasing the carbon into the atmosphere like your are with a fire. The carbon is still stored in the wood, you're just putting that stick into a state where decomposition will occur sooner. However, you are adding carbon to the atmosphere/environment that was brought from underground to make that diesel (and all the carbon it took to get that gallon of diesel to you.)
Pine brings up an interesting point on decomposing producing CH4, perhaps making an argument that decomposing is more harmful (creates more greenhouse gases) than burning?
What might be missing from this discussion is how much of the carbon (or methane) from decomposing stays in the soil vs. how much goes into the atmosphere and balancing that against the amount of diesel used? :confused3:
Seems to me that bringing up lakes of oil from an underground storage to burn on the surface (i.e. adding carbon to the system) would be worse in the long run then the terrestrial (zero sum) circular systems of transformation (burning or letting it rot). (-This is where someone mentions volcanoes and sea vents.)
:2cents:
Doesn't the whole system hinge on sea plankton?
/ Which Causes More Pollution? #22
Nah. What's really scary is the frozen methane deposits on the ocean floors. Those babies let loose and we're all doomed! :hot:
/ Which Causes More Pollution? #23
Look at it this way...
If you burn the branches or let them rot on the ground, you're still going to release just as much carbon into the atmosphere, just one way takes a lot longer, but exact same carbon effect. However, you can plant some trees, Pecans perhaps?:laughing: and make up for it pretty quick, as the trees will suck up carbon each year as they grow. Its kind of neutral. Tree sucks carbon from the air and stores it in the wood. Burn tree, it goes back to the atmosphere. Plant, it stores, over and over.
If you chip it with a fossil fuel powered implement, you are still going to get a pile of chips with the exact same amount of carbon in it as before it was chipped, and then you have the chips to dispose of by either burning them or letting them rot, which still releases the same amount of carbon into the atmosphere, PLUS the carbon from the fossil fuel that you burned, which would never have been released, had it been left in the ground, trapped forever.
So, the answer seems to be... burn them whole and plant some more trees, don't chip them. ;)
But... If you bury or compost the chips, the carbon binds to nitrogen and becomes fixed. Then it's not being released. Or... You could make bio-char, wherein you burn off the volatile compounds from the wood and get it to the charcoal phase and then cut off all the oxygen. The resulting charcoal doesn't release its carbon for centuries, if ever. Composting could be an option here, but the biochar would probably require a more complicated procedure than desired to burn twigs on a large scale.
/ Which Causes More Pollution? #24
Go suck on that exhaust pipe and see how that clean air works for ya! :laughing:
Wow, can't take it?, try eating a bag of wood chips see how works for ya! : laughing. HS
/ Which Causes More Pollution? #25
FWIW...
CO2 (Carbon dioxide) which is mostly what enters the atmosphere when you burn organic material is actually 20 times less harmful (as a greenhouse gas) than CH4 (Methane)...which is what enters the atmosphere when organic materials decay on their own...
Actually there are two kinds of composting. If you have a "heap" that is loosely packed and turned over frequently, it will decompose producing mostly CO2 because there is plenty of oxygen (aerobic). If it's densely packed and cut off from air (think of your average garbage dump) then the decomposition is anaerobic and you will get a lot of methane because of the lack of oxygen.
OP here again. My younger brother who has spent many hundreds of hours behind a wood chipper also added to the conversation that a pile of branches the size of a one story house might take 2 men days to run through a tractor driven chipper that has to run at full PTO speed. It would add up to a good amount of diesel fuel or gasoline depending on the size of the chipper. Our trailer mounted gasoline chipper is 22 HP and the diesel tractor driven chipper is 75 HP. Burning is obviously cheaper as far as labor and time and maybe better for the environment than burning fossil fuels for days on end by way of a engine.
/ Which Causes More Pollution? #27
Exactly. Burn them. Its easier on the environment in the long run and easier on your wallet in the short run... win-win.
/ Which Causes More Pollution? #29
Nature makes lightning. Lightning makes thousands of fires all over the world, daily. Fires make 'pollution' in the air.
If nature makes the lightning that makes the fires that make the 'pollution', how can it be called 'pollution'? Its part of the natural order of things.
On the other hand, nature makes the oil, which we then make into diesel fuel or gasoline, which we then burn and make the pollution...real pollution as it's not part of the natural order of things.
I wish your logic worked in all cases. I have friends who live in Tennessee coal country and they have told me of coal veins from deep caves that run up near the surface that have been burning/smoldering for hundreds if not thousands of years supposedly started by lightening. So is the coal burning by a act of nature not pollution because it is part of the natural order of things, and coal burned by man at electrical generating plants pollution? :confused3:
/ Which Causes More Pollution? #31
It's easy to forget that Nature is not here to serve us. Nor is it our job to "balance" things. We just happen to be here for a breif period and have made massive changes in that period. Its very possible that we will also be replaced by something else when either our own actions or some external force makes humans extinct. Our goal with things like pollution or even natural cycles (think ice age) is to try to minimize them enough so that the narrow parameters we need to live are maintained.
In terms of pecan orchards is there a market for the chips? There's a 100 acre apple orchard next to me and when they trim the trees every year they pile them up on trailers and bring them to a chipper then seem to sell the chips. I'm not sure if they're going to some kind of wood burning plant (there's a few around) or maybe for mulch or something else...
/ Which Causes More Pollution? #32
Check wally world or the box stores BBQ section...a 2# bag of hickory, pecan (which is in the hickory family), mesquite, cherry chips etc. etc...goes for about $4...
I suppose there is a market for pecan wood chips for BBQ but in my area of S.E. Texas (Houston) there are so many native pecans on ranches that drop limbs every year that most get their BBQ wood for free. Same goes for Mesquite which grows in this area also. At the turn of 1900 mesquite was limited to Texas right at the Mexican border 250 miles S.W. Of my location. Little by little it has creeped North and East and is now growing in S.E. Texas. To our East a few miles is the Westen boundary of the Southern pine forest that goes from Texas, Louisiana, Mississippi, Alabama, Georgia to N. Florida. Unfortunately the State of Texas has given permits to electrical generating plants in East Texas to burn pulp pine wood and pine bark.
I would bet that a huge percentage of the cost of the BBQ wood chips is labor to grind the wood up and transportation. Unlike the lumber industry that has huge areas growing trees and has mountains of bark and chips left as a by product, pecans and cherry and have to be collected and processed from smaller orchards etc. Though mesquite is plentiful mostly in West Texas the distances to ship are great. Thus the excess cost....
/ Which Causes More Pollution? #36
I still have a hard time swallowing an EPA / SCoUS ruling that CO2 is a pollutant when every green plant on earth needs it to survive and increasing CO2 concentrations encourages more plant growth, which of course produces more O2.
/ Which Causes More Pollution? #37
If nature did it,then it's part of the natural order of things, no matter how much or how long.
It's a natural thing and that type of situation has happened since the beginning of time and will continue until the end of time.
Anything we do, even if it gives the same result, is still pollution, because it was caused artificially and not part of the natural scheme of things. We are affecting nature.
Using the strictest scientific definition, I believe I'm correct.
/ Which Causes More Pollution? #39
The chipping produces more "pollution", if you are thinking co2 is pollution. The chips will break down and oxidize over a long time putting out (eventually) the same amount of co2 as burning. BUT, all the exhaust from the chipper engine is added to that total. But it is less per year, so it looks better.
Practically there is no real difference, do either.
/ Which Causes More Pollution? #40
Percentage wise, there's a huge difference... did you read the part about how many hours it was going to take to chip them?
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
