Loader Where to put Hooks on M7060 bucket?
   / Where to put Hooks on M7060 bucket? #11
Here's the thread on how I did my weld on hooks for an M7040. Maybe there's an idea here in that I used a backing plate.
I have another M7040 and am going to use the Kenny's bolt on setup because I won't be lifting very heavy stuff. If I was going to lift heavy stuff or only had one tractor I would weld a plate on for support like I did and then add the hooks. You can always take the bucket to someone that can weld. It fit's in a pickup or small trailer.
I have welders and can do it, but I don't really want to do it right now being brand new and also not lifting too many really heavy loads. I can use forks or other things like my grapple that are heavier built to lift things if I need to.
   / Where to put Hooks on M7060 bucket? #13
Not to demean Kenny at all but, I just went to the local ACE hardware and purchased some hooks with pins attached, ground them flat on the bottom side and attached them to my excavation bucket with my pulsed MIG., needle scaled them and gave them a coat of Kubby orange. I believe I paid 5 bucks each for them. Bought 3.
   / Where to put Hooks on M7060 bucket? #14
But we sell Made in the USA ones for about the same price, ready to weld...and no grinding required.
   / Where to put Hooks on M7060 bucket? #15
I realize that Kenny, which is why I commented 'not to demean you'. For me, it was a 5 minute trip to the local ACE hardware and I prefer supporting local business when possible anyway. Local businesses have to survive as well or they will be gone. I prefer dealing local versus online unless no local merchants have what I want, then we go to plan 'B'.
   / Where to put Hooks on M7060 bucket? #16
Mine are mounted on top - Makes it easier to access from the front and stays hooked better until the load is picked up opposed to the back. Whether a light material or heavy bucket, the caution is loading within requirements of the entire loader. Mine are Kennys and are bolt on. Didn't want to get into repainting after welding.
   / Where to put Hooks on M7060 bucket? #17
If not comfortable, hire it out. Bucket fits in the back of a truck. If welded on the tractor, you MUST disconnect the battery or be very experienced and willing to pay if the wiring in blown up.
It's not an issue of not being able to weld, it simply an issue of I don't like grinding on new things and then painting over them when I don't see any reason to. I am a bit picky about my equipment.
   / Where to put Hooks on M7060 bucket? #19
That depends on a number of things like the percentage of electronics on board and more importantly. the location of the ground clamp (and how clean the grounding point is) in relationship to the weld (electrical discharge) it is. Stray currents are effectively mitigated when the grounding clamp is close to the weld process as physically possible. Myself, I'll always establish a clean (paint and corrosion free) grounding point as close to the weld as possible without physically interfering with the weld itself. Never disconnected a battery (if welding on a tractor or motor vehicle) and I've never had an issue with 'frying' any electronic component. Stray currents occur when the ground point is away from the weld or the ground point is corroded or is a high resistance point.
   / Where to put Hooks on M7060 bucket? #20
I'm **** about my equipment, always have been but I'm not adverse to welding or modifying something and then having to refinish that part. Get yourself a couple flap discs in progressively finer grades instead of 'grinding, use the flap wheels to clean the surface for prep and blend it prior to refinishing. I quit using abrasive wheels a while ago and went to flap discs for pre weld prep as much as possible.
20 year old ****.... You can warm your lunch on the motor and not have to wrap it...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
Fox Super Shop Multi-Tool Woodworking Machine (A56860)
Fox Super Shop...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
206707 (A58375)
206707 (A58375)
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
