Where do you place jack???
/ Where do you place jack??? #1
bigshovel
central, pa
1998 nh tc21d
I have a New Holland TC21D. There just does not seem to be any good place, or room on the rear end to get both back wheels off of the ground to swap wheels. The fixed drawbar appears to be a good spot however I don't know if it will damage drawbar or casting. Opinions welcome.
Brad
/ Where do you place jack??? #2
It may require two jacks. One under each side to get both off the ground. Or jack up one side and use a jack stand the do the other.
/ Where do you place jack??? #3
This is the way I did it. One spot in the middle and it was way to unsteady.
What are you swapping, turfs and ags? One side at a time is safe to.
Rob
/ Where do you place jack??? #4
I place a floor jack directly under the draw bar bracket for jacking. You're know soon enough if it's positioned correctly. Once high enough, I place a jack stand under both sides of the rear axle and lower the floor jack just enough to seat the axles on the jackstands.
The draw bar bracket under the Deere 790 is robust and can take the load. You can always put a piece of wood between the jack and bracket if you're worried about damaging the bracket.
/ Where do you place jack??? #5
Rob
Plus when you pull off the tire on one side the side with the tire still on weighs more so the tractor tilts to that side putting the remaining tire on the ground so that you can't get the tire off, forcing you to use a second jack anyway. Not that I have ever had this happen to me more than once.
/ Where do you place jack??? #6
Brad
You'll be fine lifting under the drawbar, I lifted my TC21 a number of times using it. Be aware though...the front axle pivots and when you start to raise the tractor, it will lean to one side. But it will only tilt so much, so don't get nervous.;)
You can either stuff a wood wedge into the front axle pivot to eliminate the movement, or just raise the rear of the tractor high enough for both tires to clear the floor and then stick a couple jack stands under the axle and it'll level out when you lower it back down.
/ Where do you place jack??? #7
Brad
Use 2 stout (and I mean stout, 8-10 ton) stands. One under each axle. Jacks are used to jack, not support. After taking off one wheel, the tractor will want to pivot and can quickly do bad things.
If you're married, go show your wife this thread and let her know you were about to do something that was almost certain to end in a broken something. Tractor, bones, or even death. That way she can either way way up your life insurance, or slap some sense into ya. (Her choice).
Thanks for the replies, I leave the fel on so front axle articulation is a non issue. My turfs are about 5 inches shorter than the R4's per "NH spec" so entire rear axle off the ground is a must. Both sets of tires are filled so jockeying them any higher even with assistance of hoist is a pain. I guess I'll get a set of heavy stands.
Brad
The amount of life insurance she demands now leaves me with suspiscion. Or she sees me as very accident prone.
Brad
/ Where do you place jack??? #10
I've removed rear tires by placing a floor jack underneath the side of the drawbar I want the wheel off of. That works great. For removing both sides, I think I'd put in a prop underneath the axles to keep the tractor from tipping.
Ralph
/ Where do you place jack??? #11
What Roy said.
/ Where do you place jack??? #12
Farmwithjunk said:
What Roy said.
I've done that many times. worjs fine. BTW another good reason to \have a backhoe, no jacks needed, stabilizers lift tires just fine.
Andy
/ Where do you place jack??? #13
I agree that jacks are meant to jack not to support. But John, this is a 3000 lb tractor and your only talking 1/4 of that on each jackstand, Even for me, Mr Safety a 20,000 pound jackstand seems a little overkill for a 750 pound load.
Andy
/ Where do you place jack??? #14
Andy
Man's being proactive for buying a larger tractor!
Seriously, a good quality set of jackstands is worth it, IMHO.
Andy
I just wish I could afford a $4000 plus backhoe to lift the rear of my 790!
/ Where do you place jack??? #15
Andy
It's not about the vertical support. It's about the lateral support. When (not if) the tractor starts to tip to the side a "correctly" rated stand will twist and fold up like an accordion. You have to get up to the big ol' heavy dudes to be able to support that type of dynamic side load. If you've ever seen one fail, you wouldn't question for a moment.
Also, they will typically have the ratchet type adjustment. MUCH nicer to just position and lift to set height. No diddling around with pins. Same for removal, just take off the weight, flip the lever up and slide them out. Minimizing the time under is important to me.
/ Where do you place jack??? #16
Andy
LOL @ 20,000 pounds to lift 750 pounds.
2017 Maserati Ghibli Sedan (A61574)
2017 Maserati...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
Case CX75C (A62177)
Case CX75C (A62177)
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
