Jacking points
/ Jacking points #1
Breech
Southern PA
2002 NH TC33D - Replaced a 1950 Ford 8N
Good afternoon,
Just curious from all: what are the best places (both front and rear) to jack a TC33D tractor up from, as I replace tires?
The rear seems much easier as I was thinking right under the spot the tow bar connects to the rear axle. The front, not so sure....
John
/ Jacking points #2
If your jack goes high enough the front cross member will work, but on the front axle by each front tire works too.
/ Jacking points
Just looking for one spot up front to place the jack, and we'll use jack stands to take the tires off.
/ Jacking points #4
I use the loader to raise the front. A big floor jack under the rear drawbar to raise the rear tires for putting on my chains.
/ Jacking points #5
When I had my TC33D, I would jack it up from the front bumper/frame with my farm jack. It is good to unload the front axle when greasing the axle pivot. If the FEL is on, I could use that too.
/ Jacking points #6
If you use the draw bar or anything really close to the center then remove a wheel you may find that the tractor will tip and could fall off the jack. Use blocking and pickup from the axle or rear lower mount.
/ Jacking points
As a closing point: this worked like a charm, under the draw bar in the rear and right under the front guard/brush guard. R1 tires are on and need to now be filled, so another task....
Thanks to all advice/advisors!!
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
BX23 TLB 10k OBO
BX23 TLB 10k OBO
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
2005 BMW 545i Sedan (A68183)
2005 BMW 545i...
