Where do i put this or keep that?
/ Where do i put this or keep that? #21
Here is a picture of the bumper with weights on it. I purchased two 55 pound Kabota weights. It makes a big improvement in handling when the bucket is loaded. No PT pucker either.
/ Where do i put this or keep that? #22
Just a few more mods. This is a picture under the ROPS. It shows the three mirrors, the back up light and in the upper right hand corner are four switches mounted just under the ROP. These control the two front lights (separately), the backup light, and a strobe light on the back of the ROP Rack. There is also a dome light with its own switch built in. I have used this one very little.
/ Where do i put this or keep that? #23
What PSI are you using in your tires? With the extra weight in the back to counter the higher lift weight in front you might be exceeding the tire pressure.
PJ
/ Where do i put this or keep that? #24
I think this is the last for a while. I am showing the instrument panel. Please notice the oil pressure light where the light switch used to be. There is an existing oil pressure switch on the enginee. Also to the right of the panel is a car cigarette lighter outlet. I use this for charging the PT battery when not in use. I think you can see the machete on the right. It hangs on the ROP support.
/ Where do i put this or keep that? #25
I am using 11 PSI
thanks bobrip. these will sure give me something to ponder on for a while. I will get back to you later with some of my modifications.
/ Where do i put this or keep that? #27
Ok, I will look forward to it.
/ Where do i put this or keep that? #28
Clarke, just thought I would bring this to the top.
BobRip
/ Where do i put this or keep that? #29
Bob,
Where did you get those toolboxes that you mounted in front of and behind the fan?
I'm having trouble finding one that'll fit...
Thanks,
Kent
/ Where do i put this or keep that? #30
</font><font color="blue" class="small">( Bob,
Thanks,
Kent )</font>
I got them from Northern Tool and Equipment.
They were green when I got them. They turned black when I painted them.
Bob Rip
/ Where do i put this or keep that? #31
I thought I would bring this to the top since we are discussing modifications.
Bob Rip
/ Where do i put this or keep that? #32
I thought I would bring this to the top since there is some recent interest.
Bob Rip
/ Where do i put this or keep that? #33
I added an ammo box on the large post between the front lift arms nearest the operator. I drilled holes in the bottom of the box and ran tie wraps through the holes and around the post. You can adjust the position forward and backwards by rotating the box on the post. You have to do this because in the backwards position it hits the console when the arm is up and in the forward position it blocks your view of the attachment. It may also stop wood chips when stump grinding. I have not tried this yet. This is not the best modification I have made and you have to consider it for your needs. Another disadvantage is it reduces your lift capacity, not by much of course.
It is a good place to put your gloves since you can reach it while sitting. Also good for silicon lube.
Colombo Twin Master (A64119)
Colombo Twin...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2016 Ford F-550 Ext. Cab Enclosed Service Truck (A61573)
2016 Ford F-550...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
