When to use four wheel drive?
/ When to use four wheel drive? #21
Your Kubota will be the only newer model I've ever saw without an indicator if it doen't have one. Mine is a small green tractor shaped light in the dash pod. Similar in size to the PTO indicator.
My 9 year old B26 does not have an indication of 4WD other than the position of the engagement lever. Much of the time the B26 stays in 4 WD and I do see some signs of wear on the front tires due to the constantly spinning tires. Much of the B26 work involves FEL work and sometimes muddy areas like ditch clean out so 4 WD is a must.
My LS pretty much stays in 2 WD unless I need the traction. The LS automatically engages 4 WD whenever the brakes are engaged so it is safe to travel on hills in 2 WD since just a tap of the brakes gives you 4 wheel braking. The heavy LS will dig up the ground when turning sharply if left in 4 WD which is the main reason I keep it in 2 WD. The lighter B26 doesn't make much difference other than it tends to turn a bit sharper in 2 WD than 4 WD unless the ground is slippery, in which case 4 WD really helps to pull the frontend around.
As for wear, I cant say that running in 4 WD hurts anything other than the front tires as long as you are not on an asphalt or concrete surface.
/ When to use four wheel drive? #22
My tractor is always in 4wd. I do operate mostly in soft soils and muddy conditions and the tractor is never on pavement.
The only thing you will "hurt" is the tires if you leave it in 4x4 on pavement.
Fuel economy was mentioned.......that made me laugh!
High speed stability was mentioned.....that is why the front tires turn slightly faster.
I have run at top speed many times on dirt roads. Stability and handling were not an issue.
I also trailer the tractor a lot. 4wd is much safer for loading and unloading. Just like with hills and slopes.
/ When to use four wheel drive? #23
Probably depends more on the option package.
I have a 2017 L2501. No electronic controls. Live PTO engaged with a lever.
4wd engaged with a lever.
No indicators on dash.
Only indicator I miss is a brake indicator!
I often move the tractor a few feet then I realize the brake is still on!
/ When to use four wheel drive? #24
I am new to having 4WD myself. It wasn't working in my backhoe until recently. I just got around to investigating why and found the solenoid coil burnt up. Didn't thnk I would ever need or use it but I am finding it useful in the area I began work right after fixing it. My tractor has a rocker switch for OFF/4WD/4WD BRAKING. I imagine the solenoid coil burnt up in mine because it was left on so I am only using it when I need it.
/ When to use four wheel drive? #25
It probably depends on your terrain. Ours is hilly to steep with no hard surfaces, so 4WD is always on. It's needed for mowing on the hillside, loader work, and plowing snow. I only switch it off when I drive on the paved public road. When cleaning the ditch with the FEL on the public road I turn it on to back out of the ditch then off turn when on pavement and drive off to dump the load.
Yes, I suppose using it does cause more tire wear. After 20 years my fronts had lost most of their tread (R-1's) but needed to be replaced anyway because they were getting rotten. :laughing: Not an issue to worry about in my view.
/ When to use four wheel drive? #26
Your terrain and your tractor size make big differences in 4wd use. I personally would never be operating on sidehills without 4wd on - because front wheels driving pull you while rear wheels push you - so the front wheels keep you going in a line on sidehill activity. And of course as others have mentioned going down slopes needs 4wd because if your rears "get light" - you have no hydro braking or braking in 2wd on many tractors.
If your land is all flat - 4 wd is not a constant companion - if you have my type of lawn or land - 4wd is only off when in transport mode. Think of it this way - if your greatest cost in using 4wd is some tire wear on front tires - that's a pretty cheap health and life insurance cost in my book. And if lawn use is a part of your activity - 4wd itself is not the primary concern for damaging the lawn - its the tire choices and size of tractor that make the differences.
jmho
/ When to use four wheel drive? #27
IMO in some instances/scenarios...waiting to engage 4 wheel drive until after the rear tires lose traction can lead to disaster...! always better to be safe than sorry...
/ When to use four wheel drive? #28
I can attest to this... 4WD braking with HST is needed on my property. I had a couple scary moments going downhill until I got into the habit of default 4WD on vs. off.
/ When to use four wheel drive? #29
Four wheel drive systems without a center differential are usually set up so the front tires have a few percent higher ground speed than the rears. It makes the vehicle more stable in loose soil.
My Branson is a 2017 model and does not have a 4wd indicator light on the dash. I wish it did as I have left it in 4wd when going on pavement a few times. I put it in 4wd when I'm going down a significant hill, especially if I'm going down forwards.
/ When to use four wheel drive? #30
I'd be really careful about keeping 4x4 on clean pavement. There's usually no diff up front and it can put a ton of stress on the drivetrain.
/ When to use four wheel drive? #31
If there was no diff on the front, you would not be able to steer.
/ When to use four wheel drive? #32
Yeah you're right, meant transfer case.
Either way not a great idea to run 4x4 on a surface where the wheels can't slip a little.
/ When to use four wheel drive? #33
Agreed! This applies to any 4x4 that I know of.
/ When to use four wheel drive? #34
Agreed.....nowhere in my post that you quoted did I recommend running 4wd on pavement.
/ When to use four wheel drive? #35
I think the moral of this story is that for so many of us who learned perhaps erroneously that you used 4wd only in cases of real need,
just like our pickup trucks, we have been too cautious and perhaps missed out on safety.
I wouldn't even drive down the road on dry pavement in the "auto" modes of many of these new computer guided
transmissions. Always thought you should disconnect everything that wasn't needed.
and here to learn that my two 4wd tractors really should/could stay in 4wd on my small farm, since I'm on lawn and field only.
But.......when I mow roadsides with the cab Kubota, I have to remember to turn off 4wd. I forgot once and on the way home wondered what is all that
noise? Whirrings and whinings added to the normal hydro howl. Almost at the end of the lane, I thought oh no I know what it is...and stopped, pulled the lever up
and resumed with much less machinery noise.
what about running 4wd on the road at 15mph? Even if you don't care about your tires...
just wondering what those transfer cases were designed for
Lots of the big tractors have 40kph top ends now, to compete with the Europeans, but
could be comparing apples to oranges here, perhaps high speed versions have different style
gears, don't know. But I bet some one here does.
When I realized I had run a mile on the road in 4wd, I felt a little better knowing I had used synthetic lube oil
on the last change. Figured i must have heated something up pretty well in there, but maybe not.
I learned not to jump to conclusions based on my oldest tractor.
The transmission howl out of my Super A is remarkably loud, straight cut gears, but all the mechanics just smile and say
that's normal. Simply cannot imagine taking that ancient thing out on the road in top gear at full throttle.
So as much as I swear something is seriously broken in there (tractor runs great...) compared to my other tractors,
all that whining in 4wd may also be more of a worry than it need be.
Titan and Firestone sure like it...
/ When to use four wheel drive? #36
I use 4wd when the ground is soft while pulling a heavy grain drill, other heavy equipment or equipment that causes a significant drag on the tractor. My M7060HD12 has four wheel braking when both brakes are applied at the same time, otherwise it is two wheel braking. On gravel or dirt I don't run in 4wd when I am traveling at higher speed. I definitely hit the push button 4wd when I'm on inclines either dry or wet, better safe than sorry. Hope this helps.
/ When to use four wheel drive? #37
And yet think how others would react to our 4wd concerns. 25 years ago I owned a AWD Ford Explorer. We now have many brands of AWD walk behind lawn mowers. And Subaru - since it began making cars, SUV, or trucks . . . aren't they all AWD ?
My point is. . . Being 4wd isn't as big an issue of concern as maybe we've made it to be. 4wd is very helpful, but it's not like "lock out hubs" on pickup trucks used to be in the 70s.
Now what I don't understand is. . . . Why some tractor owners experience much steering difference in 2wd vs 4wd ?
Now my Massey gc1715 SCUT has no difference in steering regardless of 2wd or 4wd. But my neighbor's j. D. X728 mower has a difference I'm told, and reviews of other tractor units often mention it.
/ When to use four wheel drive? #38
you bet, my Outback has amazing traction along with good Michelin tires. Sticks like a leech to the road.
I call it my poor man's Audi. Which also has remarkable traction.
In fact, many of the super high performance cars today have AWD simply because rear wheel drive can't provide enough
grip. Can you imagine an AWD Hellcat?
Or the new Hellcat RedEye with AWD. :thumbsup:
but I digress...
Hasn't there been a lot of improvement over the original 4wd mechanisms in tractors?
The early ones had those big transfer cases, now we have axles going through oil pans, all kinds of interesting engineering.
My understanding is that there are two different types of 4wd front transfer cases and one turns more tightly in turns.
but I'm sure there are more differences than that.
First thing I'm going to do this morning is check to see if my Kubota dash has a 4wd light, that green tractor.
I must be blind if it's there.
/ When to use four wheel drive? #40
but I digress...
So AWD and 4x4 are different in a subtle way. With AWD there's another some sort of coupling that can slip(to keep driveline from binding, think the case of why you have a differential but for the forward/rear tire sets) and some systems(high end Subaru, all Audis, etc) can adjust the amount of power front/back.
Running 4x4 on a surface with high traction puts a ton of strain on the transfer case as the front/back wheels won't spin exactly the same speed. Easy way to get a $$$ repair on your truck if you do it often enough.
Also, no need to imagine a Hellcat AWD, we already build one of those in the US and it's a Tesla P100DL :). I've had a chance to drive one and it's straight up bananas. It's also a 3rd, different type of drive system with two completely independent front/back motors and an open differential in each.
