When is a BX enough?
   / When is a BX enough? #1
Idahomestead
Husqvarna TS354XD
I have 3.5 acres in rural Idaho that needs some work and I am trying to decide about tractor options. My needs include general clean up, brush removal, small stump removal, about 400 feet of driveway to put new gravel on, small rock removal, leveling, and trenching for electrical and water lines. My mowing and snow removal needs are taken care of. I’m pretty set on Kubota because the dealer is close and I like them. I’ve been planning on a BX23s for quite sometime but whenever I read threads about the BX line, the advice of upgrading to a bigger tractor is almost always given. I’m convinced I need a backhoe and though the B series looks great, a similarly appointed 2601 runs about another $7,500 and doesn’t have the quick connect feature of the 23s BH. I thought about buying the 2601 with just the FEL and saving up for the backhoe but am worried that if I don’t get the BH from the start, I probably never will.
   / When is a BX enough? #3
Buy what suits you. Use it and see how it goes, They hold value, so you can move up. ( I better be careful here, supply issues!)
But for MY MONEY. 3+ acres and "earth moving "ambitions". The B series might be a better bet.
I enjoy the abilities of my ancient B7200, the 35 HP Hurlimann is a bit disruptive for some tasks , but only just capable for moving earth and stone.
You might be like I am, Get one of each! ;-)
or..Buy once, cry once. Owner types differ!
   / When is a BX enough? #4
I have a BX on 5 acres. A low BX because the only flat land is under the house. I find the BX right at the limit or not enough every once in a while. On flatter land, a B would be just right for me.
Bruce
   / When is a BX enough? #5
I had a BX for 10 years, great little tractors but I agree, a B sized machine would be better for you. So far I’ve never needed a backhoe. I often see advice given to rent a backhoe or trencher and do all your stuff like that at once.
   / When is a BX enough? #6
Agreed, the B2601 is a good bit more machine than a BX and well worth the extra. Definitely would consider just how much you think you'll use the backhoe in the future. Takes quite a few mini ex rentals to get to that number and a mini ex will do much faster
   / When is a BX enough? #7
I cannot imagine how anyone would need to own a backhoe just to use on a 3.5 acre lot. Rent a backhoe, get the backhoe work done and move on. A tractor, especially a compact or sub-compact is not a bulldozer, is not an excavator, is not a stump grinder. Rent the equipment for each of those tasks as needed. That’s my two cents.
   / When is a BX enough? #8
I have a 5 acre property that goes from a hilltop to a creekbed and has some flat and very not-flat sections. I have a B6100 with a loader that is BX-sized, and a B8200 with FEL and backhoe that is closer to B than BX. There are definitely places I will take the B6100 that i wont take the B8200, but that's largely because of the backhoe and if the backhoe was on the 6100 it would be nearly the same effect in terms of limiting what im willing do drive through with it. It's mostly because it will drag its backhoe 'swing mount'/base part, or drag the bucket unless i stick the dipper up, and if i stick the dipper up the tractor gets a lot longer and i have to keep reaching back there and swinging the boom from one spot to another when driving through narrow stuff. But most people wouldn't drive through that many tight spaces to begin with.. it's just something to consider. When driving my backhoe tractor across a steep slope I have swung the boom to the high side as counterweight and that's a nice help for my piece of mind if nothing else.
Im fixing up another B6100 WITH a backhoe for a friend so ive had some opportunity to explore whether I would be satisfied if i downsized my small b8200 backhoe capabilities to even smaller.. and im not sure i'd take that trade. My 6.5ft backhoe is already frustratingly short on reach, plus i use it with a grabber (sort of a thumb thing) to grab and place large rocks and chunks of broken concrete building half-a$$ retaining walls and if it has less lifting ability at the end of its reach it would probably frustrate me.
I love the tinyness of my b6100, wouldn't change a thing about that for loader/3pt stuff since all im doing is landscaping stuff. But for backhoe purposes, i would say my 8200's 6.5ft backhoe is close to bare minimum capabilities and even with owning it i still spend a fair amount of time thinking about getting a slightly larger chinese mini-excavator or adapting a slightly larger backhoe attachment into a skid steer attachment and using it with a small skid steer i have, which in my mind would be the next best thing in function to a mini ex since i could easily move and rotate it while operating the hoe.
I think the bx would 'work' but for backhoe purposes you wouldn't regret going larger. If the backhoe is not very high on the list of why you need a tractor, i wouldn't hesitate to get the BX as the one you'd be getting is basically the size of my larger tractor anyway and overall im very happy with it.
   / When is a BX enough? #9
I started with 3.5 acres and a B2910 with backhoe and loader. I never regretted buying a tractor larger than a BX, although my son-in-law bought a BX23S for use on 3.2 acres, and I think that was a good choice for him, because most of his property is steeper than mine.
Over the years I’ve gotten a great amount of use out of my backhor and I never regretted buying it. The thing about having a backhoe is it’s there when you need to do something small. You would never rent a backhoe or mini ex to do small jobs. It just would not be cost-effective.
I did buy a BX a year after buying the B2910. Mainly to use as a mower, but it is useful for me in other ways as well. The B is my work horse, but the BX is more stable, but does not have the backhoe or loader.
The B series was the right choice for me. I now have 8 acres and I am still happy with it all in all.
So when would you say the BX23S would be the right choice? What situation would it fit best?
   / When is a BX enough? #11
How rough is the ground? Is there much slope? How fast do you need to do the chores?
BX is really a diesel powered lawnmower more than it is a tractor. Don't get me wrong I had two and loved them to death and often miss having one, but the tires really limit what they can get done for real work. Stepping up to the B or the L2501 is orders of magnitude more capability even with the same HP. The price difference between the BX and the B is essentially nothing if you're making payments and less than $1k with cash, L is going to be like 6K more but that's significantly more tractor. If you want to do all the work yourself without renting a mini ex for the stumps and rocks really consider the L just for it's ability to take the abuse.
FWIW when I went to the MX from the BX I was digging pine stumps from a previously harvested planted forest so all were pretty uniform 6-8" stumps. BX would take nearly 45 minutes per stump and the MX took six. BX would also take nearly 10 minutes to get from the front of the six acres to the back just because it had to go so slow navigating the rough terrain where the MX could get there fast enough it didn't need to be timed. Just differences to consider.
   / When is a BX enough? #12
Agreed. With the rocks and stumps, B2601 at minimum.
I had to go from the B2601 to the L2501 for these very same reasons. And, when I got the L2501 home…I realized I could have gone to an MX…tractors tend to shrink when you get them home.
That said, I’m happy with the L2501 and don’t have any immediate plans to upgrade.
Mike
   / When is a BX enough? #13
Mike
They do shrink. Funniest **** I ever seen.
   / When is a BX enough? #14
When I briefly lived in Corrupticut, I only had 1.2 acres. I had the equivalent of an L2501. I wouldn't have wanted anything smaller.
Once you have a backhoe, you should quickly realize it's for more than digging trenches. I highly recommend it.
   / When is a BX enough? #15
Agreed on that one. When you need to dig, rent an excavator.
   / When is a BX enough? #16
FWIW, I have a 40 hp tractor. I used that tractor on 6 acres for 10 years. I only used it on 3 acres of it. Never once did it feel to big for me. Now using on 16 acres and would like to step up one more size. My Uncle uses a Massey1643 tractor on his 5 acres and I help a lot over there. Never wished we had a smaller tractor.
I really like these smaller units like the BX but they would just not do it for me right now. They are well engineered and would be a blast to use. I almost bought a little Massey GC1710 but ended up not doing it. I still might get me a smaller tractor one day to compliment the bigger one but if I could have just one tractor it would be at least the full size compact (JD 4 series, Kubota Grand L, Massey 2800m, etc).
   / When is a BX enough? #17
You'll be fine with a BX23S. Very useful, utilitarian enough to get most jobs done.
IF you need something larger (I doubt it), buy a 2nd tractor that is 30 - 40 yrs old for $5000 - cheaper than the B2601 option (additional cost). Then you have it all. I needed the Open Deck of the newer models.
prior to buying the BX23S, we were busy as beekeepers and required pallet fork lift capacity of the B3030... never bought that one as the beekeeping time ended and the BX23S was fine for our needs.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 KOMATSU D61PX-23 CRAWLER DOZER (A60429)
2015 KOMATSU...
John Deere 6120M (A57148)
John Deere 6120M...
UNUSED X-STAR 20' X 101" LOADING RAMP (A60430)
UNUSED X-STAR 20'...
2012 International Prostar (A61306)
2012 International...
17501-FL (A56857)
17501-FL (A56857)
