When did electronic fuel injection become common?
/ When did electronic fuel injection become common? #1
Fields_mj
Central Indiana
Ford 1710, Kubota F2880, White FB16
I'm looking to replace my 1983 1710. Originally I was looking at pre-emission machines. Then I had someone mentioon that they had to replace the fuel control module on their 2003 NH machine. I'm not a fan of any form of electronics on a utility tractor so I immediately started wondering far back I needed to go to predate electronic fuel injection on these machines.
/ When did electronic fuel injection become common? #2
I can say my 2008 Massey 1540 is mechanical injection
/ When did electronic fuel injection become common? #3
I suspect it depends on the make and model and or horse power of the engine vs stating in 20** they all were built this way
/ When did electronic fuel injection become common? #4
My TYM T474 (48.3Hp) is a mechanical injected diesel even to its Tier 4 DPF. I have 565h on it without issues. Most under 25Hp comes with mechanical injection too.
/ When did electronic fuel injection become common? #6
It become more common when Tier 4 diesel emissions standards came into effect.
That's when you started seeing more tech like electronic injection, common rail, DEF, DPF,...
In my case I bought my 2015 Kubota M59TLB because it was the last model year without all the electronic emissions stuff added. In 2016 it became the M62TLB
It makes sense that it varies my mfg. Realistically, I'm not even sure what the fuel control module does on a 2003 NH machine. It might just be a relay that's used to cut off the fuel supply. My real question should have been something like "How hard is a XXX to work on?" I'm a pretty handy individual, but I'm limited on what diagnostic tools I have. That's always been one of my favorite things about diesel engines. Just needs atomized fuel, oxygen, and compression. No ignition system to troubleshoot.
/ When did electronic fuel injection become common? #8
The issue with common rail is the plethora of sensors and signals that the computer reads, just to run the engine. Mechanical injection needs fuel and air and compression... No computer.
Exactly
2017 Thompson 32HPU 55kW Towable Pump (A59228)
2017 Thompson...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
