Wheel Weights
/ Wheel Weights #21
<font color="blue"> Thanks, but no thanks Mark. Not being rude but I'm not going to have some goofy Gold's Gym barbell weights hanging on my rear wheels. LOL</font>
You need to change your name. A True Redneck wouldn't care how they looked. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Wheel Weights #22
/ Wheel Weights
MikePA,
That setup looks good. Best I've seen using barbell weights.
Randy
/ Wheel Weights
MikePA,
Randy
/ Wheel Weights #27
Randy,
Some farmers I know have coated the wheels with a release (plastic) and bolted threaded rod thru the holes that are in the wheel to hold the weights. Use stainless rod and nuts. The rod is long enough to extend past the outside of the wheel and is bent into a circle. Then with the tire on the ground they pour it full of cement. Some have made a form so it is taller than the wheel. The circle on the rods are used to pick up and move the weights.
The finished weight can be painted to match the tractor or left "natural" for that true redneck charm.
Cost -- about $20.
Oh, if they are poured flush with the wheel, it will enhance your aerodynamics and reduce drag when speed plowing....
jb
/ Wheel Weights #28
Randy,
Cost -- about $20.
jb
/ Wheel Weights #29
I don't know how much all you wheel weighters are using, but a word of caution may be in order. When thumbing thru my B7610HSD owner manual looking for oil capacity last weekend (Hehe, fresh Rotella T Synth - let the flame wars begin), I was surprised to see a max rear axle weight capacity of only 78lbs. per side! 150lbs... pfssst. The ballast box has a recommended 500lb capacity.
/ Wheel Weights #30
/ Wheel Weights #31
150 pounds seems quite low for an axle weight capacity. You might check that again and make sure it isn't referring to something else.
Another note about wheel weights, though, is that the weight never goes to the axle. The weight is all supported by the rims.
/ Wheel Weights #32
/ Wheel Weights #33
</font><font color="blue" class="small">( Thanks, but no thanks Mark. Not being rude but I'm not going to have some goofy Gold's Gym barbell weights hanging on my rear wheels. LOL
Randy )</font>
Might be the foundation for a new series of redneck jokes. /forums/images/graemlins/smirk.gif
/ Wheel Weights #34
Randy )</font>
/ Wheel Weights #35
</font><font color="blue" class="small">( 150 pounds seems quite low for an axle weight capacity. You might check that again and make sure it isn't referring to something else.
Another note about wheel weights, though, is that the weight never goes to the axle. The weight is all supported by the rims. )</font>
Seemed darn low to me too, which is why I mentioned it. Now you know I just had to run out to the shop for the manual to check my memory, here's what it says...
B7610: NO rear wheel weight recommended, use liquid tire ballast ONLY. Largest tire size listed is 11.2-16 with heaviest recommended loading of 172lbs per tire (5lbs CaCl2/1gal H2O=slush free @-52*F).
B7510 Narrow ONLY: Use liquid tire ballast; Rear Wheel Weights optional; Max Weight Per Wheel = 71lbs.
Personally, I have 12-16.5 R4s which I loaded with 15 gals RV Antifreeze per side; about 100lbs each. With the 500lb box and 200lb operator ballast, that's about 900lbs total ballast for FEL work but I can still lift a tire. /forums/images/graemlins/ooo.gif
/ Wheel Weights #36
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
2016 Ford F-550 Flatbed Truck (A64556)
2016 Ford F-550...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2016 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A64556)
2016 Ford F-550...
