Wheel Spacers?
/ Wheel Spacers? #1
tncruzin
Nashville, TN.
Iseki TL-1900
Has anyone ever heard of placing a spacer on the tractor before mounting the wheels to create a little wider foot print? I wonered if this might be a cure to my problem of the lift-arm braces rubbing against the tires.
/ Wheel Spacers? #2
Can you post a pic of the back end? I would like to see the difference between yours and mine.
/ Wheel Spacers?
Yes I'll post pictures if someone will tell me how to compress the picture so it's not too large.
/ Wheel Spacers? #4
You'll need a photo editor. If you dont have one you can download a free one that will resize the photo. Do a search for Vicman Photo Editor. Its pretty easy just open the picture and select to resize it. Then save it and use windows explorer to check the size.
/ Wheel Spacers?
See if this works.
/ Wheel Spacers?
Close up picture
/ Wheel Spacers? #7
Swap your tires side for side. That will put the the wheels to a wide position.
/ Wheel Spacers? #8
Those arms are atraight. I have heated them just past the tires and put a slight bend. That can give you some clearance.
/ Wheel Spacers? #9
It looks like your turnbuckles are a lot longer then mine and mounted further down the lifting arms
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
213135 (A64276)
213135 (A64276)
2021 Takeuchi TL6R (A64126)
2021 Takeuchi TL6R...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
