Wheel Spacers?
/ Wheel Spacers? #1
tncruzin
Nashville, TN.
Iseki TL-1900
Has anyone ever heard of placing a spacer on the tractor before mounting the wheels to create a little wider foot print? I wonered if this might be a cure to my problem of the lift-arm braces rubbing against the tires.
/ Wheel Spacers? #2
Can you post a pic of the back end? I would like to see the difference between yours and mine.
/ Wheel Spacers?
Yes I'll post pictures if someone will tell me how to compress the picture so it's not too large.
/ Wheel Spacers? #4
You'll need a photo editor. If you dont have one you can download a free one that will resize the photo. Do a search for Vicman Photo Editor. Its pretty easy just open the picture and select to resize it. Then save it and use windows explorer to check the size.
/ Wheel Spacers?
See if this works.
/ Wheel Spacers?
Close up picture
/ Wheel Spacers? #7
Swap your tires side for side. That will put the the wheels to a wide position.
/ Wheel Spacers? #8
Those arms are atraight. I have heated them just past the tires and put a slight bend. That can give you some clearance.
/ Wheel Spacers? #9
It looks like your turnbuckles are a lot longer then mine and mounted further down the lifting arms
Luck Now 425 (A64126)
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
FLAT BED (A65643)
FLAT BED (A65643)
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
