Wheel Spacers?
/ Wheel Spacers? #1
tncruzin
Nashville, TN.
Iseki TL-1900
Has anyone ever heard of placing a spacer on the tractor before mounting the wheels to create a little wider foot print? I wonered if this might be a cure to my problem of the lift-arm braces rubbing against the tires.
/ Wheel Spacers? #2
Can you post a pic of the back end? I would like to see the difference between yours and mine.
/ Wheel Spacers?
Yes I'll post pictures if someone will tell me how to compress the picture so it's not too large.
/ Wheel Spacers? #4
You'll need a photo editor. If you dont have one you can download a free one that will resize the photo. Do a search for Vicman Photo Editor. Its pretty easy just open the picture and select to resize it. Then save it and use windows explorer to check the size.
/ Wheel Spacers?
See if this works.
/ Wheel Spacers?
Close up picture
/ Wheel Spacers? #7
Swap your tires side for side. That will put the the wheels to a wide position.
/ Wheel Spacers? #8
Those arms are atraight. I have heated them just past the tires and put a slight bend. That can give you some clearance.
/ Wheel Spacers? #9
It looks like your turnbuckles are a lot longer then mine and mounted further down the lifting arms
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
1996 International 4700 (A64126)
1996 International...
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
