Whats wrong with tier 4
Status
Not open for further replies.
/ Whats wrong with tier 4 #82
Dave1949 You are correct, the EPA won't come out and say it. They just will not enforce it, which for the EPA is like saying they messed up. And you might ask, "how did they mess-up"? They pushed the standards onto the engine manufacturers before they had the technology. And i don't believe it would be politically palatable to go back and enforce it. Best example i can come up with is the AIR pumps everybody took off in the late 70s early 80s. Compared to the catalytic converters which have to be left on. I think they will just ignore it and move on. Some states might go after it, but it will be expensive proposition, the only way they could find it is they would have to smog test for it. And on top of all this the EPA has to be smart enough to figure it is going on as large scale as it it. They are just not going to stick it to the little guy and tell him he has to spend that money to put it back on, it will put to many trucking companies out of business. the EPA will mess with one or two little guys, not a large group like this and they'll mess with the deep pockets i don't think they would mess with what would turn out to be a large issue. Might try, just don't think it would turn into anything. Individuals vote companies don't.
/ Whats wrong with tier 4 #83
I think you are correct in that the EPA will just look the other way. It is similar to the early emission controls on autos. They built some real crap in the beginning but they built something that would pass the tests--and a lot of it got removed. It did eventually lead to cleaner engines though.
/ Whats wrong with tier 4 #84
The Mahindra design of engines has a DOC Diesel Oxidation Catalyst. Instead of the DPF in the exhaust. Only time will tell how reliable this system is. It appears to work like a Catalytic Converter for gasoline engines. The DOC appears to cost less to replace if it did break. Some people act like Mahindra designed an engine that has no exhaust after treatment. That is not true.
/ Whats wrong with tier 4 #85
I believe that AGCO also went the DOC route for their larger 75+ hp tractors.
/ Whats wrong with tier 4 #86
I think you're slightly off. I think everyone has read the same information as you. I don't get where "some people" are acting like Mahindra doesn't use any treatment to the exhaust (got a source?). I think the preference some show toward the Mahindra system has to do with part of what you mentioned which is the apparent cost difference. Hearing about the few DPFs that've had to be replaced at $3k each (even though most or all have been warranty items thus far) should be enough to make anyone cringe at the thought of owning one. I think the other thing that folk like about the Mahindra system is there is no regeneration cycles needed to clean it back up every few hours. I've personally came across nobody that thinks the Mahindra engines are just magically cleaner.
/ Whats wrong with tier 4 #87
I've read all of the comments in this thread and it is a good discussion.
If I were to summarize I would make these points.
Nano Particles make dust particles seem like boulders - Thanks Dave1949
The compounds attached to these particles cause cancer, period. Scientific evidence has proven this; it is fact.
Various methods of reducing or eliminating diesel soot are being employed. Some may be better than others but at the end of the process, clean diesel engines will be the result.
Cost to the equipment user is appropriate. There is cost regardless but asking your neighbor to pay the price instead of you, the owner operator of the engine, is just not right.
For those that just reject science, I have nothing to say. I suppose some folk continue to believe the earth is flat.
We are not going to see a reversal of the requirement to control diesel soot for the same reason we will never see the requirement to wear a seatbelt reversed.
For anyone that finds himself with a poorly designed or short lived system to reduce soot, raise **** with the dealer/manufacturer. The systems should be cost effective, robust and transparent to the operator.
/ Whats wrong with tier 4 #88
I've read all of the comments in this thread and it is a good discussion. If I were to summarize I would make these points. Nano Particles make dust particles seem like boulders - Thanks Dave1949 The compounds attached to these particles cause cancer, period. Scientific evidence has proven this; it is fact. Various methods of reducing or eliminating diesel soot are being employed. Some may be better than others but at the end of the process, clean diesel engines will be the result. Cost to the equipment user is appropriate. There is cost regardless but asking your neighbor to pay the price instead of you, the owner operator of the engine, is just not right. For those that just reject science, I have nothing to say. I suppose some folk continue to believe the earth is flat. We are not going to see a reversal of the requirement to control diesel soot for the same reason we will never see the requirement to wear a seatbelt reversed. For anyone that finds himself with a poorly designed or short lived system to reduce soot, raise **** with the dealer/manufacturer. The systems should be cost effective, robust and transparent to the operator.
The only thing you get wrong is; no one is getting sick or cancer from diesel particles. HS
/ Whats wrong with tier 4 #89
What I didn't post is that engines that have just a DOC do not remove as much particulate matter as a DPF system does. I have not seen how clean the exhaust is or has to be. It appears that a engine with just a DOC is quite dirtier than one with a DPF. A lot of machinery ( large off road and pick up trucks and large trucks) use both.
/ Whats wrong with tier 4 #90
but enough to meet EPA regulations apparently.
/ Whats wrong with tier 4 #91
/ Whats wrong with tier 4 #92
Don't get things confused. Just because it has DOC doesn't mean it meets tier IV. There was some Tier III and interim IV running just DOC(don't quote me) If you go back to the link on how Mahindra is meeting tier IV with just a DOC and no DPF, there is a lot more going on there. Better control of the burning of the fuel with common rail being the key. I believe better control of combustion will get the DOC to last longer. My premise all along has been that DPF and a regen does not decrease as a whole the amount of emissions. it may change the size when it regens it is not decreasing it. Burning more in the engine gaining horse power out of it DECREASE THE FUEL USAGE for the same amount of work, that is decreasing the emissions. My premise has been based on purely total emissions.
/ Whats wrong with tier 4 #93
I think what I have quoted from you above is an entire subject of discussion in itself. Good science I respect, but there are many good honest knowledgeable scientist, guys and gals that are truly peers that do not agree on major issues. There are scientist with political agendas, scientists with atheistic agendas, etc. As much as they may wish to be neutral, our world view affects our opinions even when we are convinced we are taking a scientific approach.
As to clean air, I'm for it.
/ Whats wrong with tier 4 #95
For the amount a "hours" these little tractors are used, I think its unnecessary for them to have all this equipment, it's detrimental to sales...IMO.
Its like having dpf and regen's on lawn mowers and chainsaws.
/ Whats wrong with tier 4 #96
For the amount a "hours" these little tractors are used, I think its unnecessary for them to have all this equipment, it's detrimental to sales...IMO. Its like having dpf and regen's on lawn mowers and chainsaws.
That's coming and I'm not joking. It's planed. HS
/ Whats wrong with tier 4 #98
new 2 cycle stuff has already been outlawed.
California has regulations affecting lawnmowers.
/ Whats wrong with tier 4 #99
The problem with tier 4 is... people will use contaminated DEF fluid.
/ Whats wrong with tier 4 #100
I don't think people are going to do that. DEF is cheap. You can buy it almost everywhere. The problem will be how well built is the High Pressure Fuel Pumps (hpfp). A lot of on road diesel vehicles, cars and pickup trucks have all had problems at first. The pump is lubricated by diesel fuel. If you have contaminated fuel (gas or water) it will fail and cause contamination throughout the fuel system. Ford, Chevy, Dodge, BMW, Mercedes, VW have all had some problems. They appear to be changing pump designs so this does not happen. Hopefully these on tractors are of new design.
Status
