Whats the difference between 4/6/8 hydro rollers?
/ Whats the difference between 4/6/8 hydro rollers? #1
wkheathjr
Bronze Member
Seven Springs, NC
80's Massey Ferguson 240
I was looking for a PTO-driven pump for the boomer sprayer and I see several different prices from $59 to $259 at Tractor Supply Store and it had 4, 6, and 8 with 8 being high in price.
What's the difference, really? The boomer I am going to buy has 55-Gal water tank on it. I'm looking for something economically right now that will last maybe 5 years and hopefully longer! :D
Also, is there something else I need beside pump and regulator to get the boom sprayer to work?
Thanks in advance for answering this question.
/ Whats the difference between 4/6/8 hydro rollers? #3
This is a good document. The one thing I am not seeing (unless I missed it) is how does a roller pump mount to the sprayer frame? I am assuming, for example, if I purchase a 55 gallon sprayer from Ag Supply and the recommended roller pump and coupler I still need to buy a PTO shaft fit to length and what else. Is there a bracket that I need to mount the roller pump inline of the of the PTO shaft just like any other PTO driven implement? Should the frame of the spray be pre-drilled with hole or should I expect to have to drill holes for the pump mounting?
For example: 55 GAL 3PT. SPRAYER - Agri Supply
Mark, I'm glad you brought that up. I was reading the same info last night and was wondering if I would need to add something to support the rollers because my PTO area doesn't have anything to support any bracket that will help hold the roller in place. I might have to buy one or make a homemade one that I can take off when not using the roller.
If anyone has a pic of roller being attached to the PTO, that would be great! :D This might give us some idea on how to work with it.
/ Whats the difference between 4/6/8 hydro rollers? #6
Agri supply has all the "right" items to make it work, see here:
TORQUE BAR & CHAIN FOR ROLLER PUMP - Agri Supply
I am more interested in seeing some real pictures and hearing some words of wisdom as to how it goes together. For example, they show a draw bar being used. I don't have draw bar and am not install one on my tractor just for this application. That said, how else can the mount be attached to prevent the pump from spinning on the PTO. Coupler application I think is self explanatory but feel free to share that info as well if you'd like. Agri-Supply does a decent job of mentioning what other part numbers you will need. In this case which pump is needed with the sprayer I linked. Of course with chemicals you could always upgraged.
/ Whats the difference between 4/6/8 hydro rollers? #7
(not an answer to your post, but, still relevant)
From AgriSupply's web site:
55 GAL 3PT. SPRAYER - $585 ?
And, pump not included ? And, handgun kit not included ?
I found interesting. Why don't you go for such sprayers (see attachment) with diaphragm type pumps? You don't need to worry about bringing components together. Italians are good in manufacturing such sprayers (although their prices are a little higher.)
/ Whats the difference between 4/6/8 hydro rollers? #8
Hey, I am not against implements that are all inclusive. IN FACT I prefer to buy pretty much anything ready to use out of the box. I just have yet to find a 3pt. sprayer that had everything ready to go off the truck. Got a source????
/ Whats the difference between 4/6/8 hydro rollers? #9
Furthermore, I am willing to pay a pit more for items that I DON'T have to do a lot of work to. Time is money to farmers but it is too when you work a full time job other than running a farm.
/ Whats the difference between 4/6/8 hydro rollers? #10
I used to have a 6-roller Hypro pump mounted on an angle iron frame on wheels along with a 25 gallon tank. It was powered by a 3 hp Briggs & Stratton engine through a "transmission" that reduced the RPM. It had a pickup hose, then a "filter" that was actually only a metal strainer, additional hose to the pump, then a hose to an adjustable pressure regulator, a bypass hose from the regulator back to the bottom of the tank so that provided the "agitator" for the tank. Then there was also a steel line (pipe) from the regulator to a cut off valve (ball valve) and then a 100' hose and spray nozzle. Of course, the 100' hose was a high pressure hose; all the others were simply pieces of 3/4" garden hose.
Corrosion will cause the pump to seize up. I learned to leave mine filled with anti-freeze when not in use and that prevented the corrosion. However, I also learned it's a simple job to take the pump completely apart so you can (1) reverse the rotation direction, or (2) clean out the corrosion. My glass bead blaster cabinet worked great for cleaning out the corrosion when I let the pump seize.
/ Whats the difference between 4/6/8 hydro rollers? #11
You don't you put the pump on your PTO Shaft...:D
Hypro - Recommended Pump Placement
/ Whats the difference between 4/6/8 hydro rollers? #12
I understand that. In fact I linked this a few threads earlier. I more concered with bracket the pump mounts too. Can it be chained to anything solid such as the top link. I don't know about you but I don't have a draw bar on my tractor as show in the picture and don't plan on installing one just for a sprayer. Any "real" pictures of an install?
/ Whats the difference between 4/6/8 hydro rollers? #13
I have the luxury of a Farmall 460 with the said drawbar...:D
It's not as easy, but you can hook it to the frame where your drawbar should come out from under the tractor...that is the way I hook it when I run the sprayer off my JD855...:)
Sorry no pics...:(
/ Whats the difference between 4/6/8 hydro rollers? #14
Sorry no pics...:(
I have a draw bar but not a three pt. hitch type. At any rate I think I am going to go with the a 12volt powered pump. Seems less cumbersome . . .
/ Whats the difference between 4/6/8 hydro rollers? #16
bostonrats said:
Thanks so much! That was what I was looking for. Two questions . . .
Is the angle iron or light channel bolt or mounted to the tractor frame or just setting flush against the frame? It looks like the height of the PTO shaft vs. were your angle iron sets is near perfect. Did you need to add some spacers?
It looks like you chained the spring to you ROPS, is that correct?
I'll probably use (if I go this route) this unit out of ease and I am trying to determine where to bolt it.
