What to use Carry-All for (other than carry-all)
   / What to use Carry-All for (other than carry-all) #31
Selling me on UTV's... 🤣
   / What to use Carry-All for (other than carry-all) #32
I used to thing I wanted a carry all, but could also find a lot of reason I didn’t need/want one. But there was still times I could use one.
So instead of a carry all, I bought a virtually new hitch hauler off FB marketplace for $30 a mere mile from me. I use it fairly frequently as it is easy to install into my 3 point receiver.
It does have limitations due to size, bu it works well for a lot of little jobs around the property. Hauling saws, firewood, mulch, feed, etc. The wife has even used it for a seat for a few short rides.
   / What to use Carry-All for (other than carry-all) #33
The thing I like about my carryall is if I don't want to put it on my three point, I just put my FEL landpride forks under it like I would a pallet. I can load it up with gear, go to the spot I need it, just drop it off right there. It beats having to fasten stuff on a pallet, especially if traversing rough ground.
   / What to use Carry-All for (other than carry-all) #34
gg
   / What to use Carry-All for (other than carry-all) #35
you could convert by adding (or building) a Gibon box on top of it.
would more than double carrying capacity (loader bucket + box) than just loader alone which is great if you are moving things longer distances as saves road/trail running time.
Would prefer to use a trailer but I have a lot of areas where I like getting into where something longer or wider than tractor would be problematic. Just getting an tractor in / out of some of these areas is bad enough.
   / What to use Carry-All for (other than carry-all) #36
I use mine all the time as long as I have the tractor at home. Mine is a slightly different style from the ones you have there and it's technically called link box.
I bought it used, needing some sheet metal work on the bottom corners for around $120. Got that fixed and recently gave it a nice paint job. It can dump, tailgate can flip down like a pickup truck, flip up like a dump truck for dumping purposes or simply removed and out of the way. It also has a cutting edge to scrape loose materials. It also provides a nice and fairly compact counter weight for loader work once loaded, which can be simply done by reversing to a pile of loose material.
It gets often loaded with 1300+ lbs of firewood with the tailgate down. I've used to move concrete tubes and rings, sand, gravel, half filled 200 GAL IBC tanks, all kinds of stuff really. Before I bought a pick up truck, I used to take the tractor with the box attached to the local feed store to get feed and small square bales for the chickens, ducks and goats.
I could easily sell it for $300+ at the moment, but as someone said before, once I sell it, it'll be when I'll need it the most.
Don't really have a good pictures of it unfortunately, so here's a couple from the manufacturer.
View attachment 783702 View attachment 783703 View attachment 783704
Don't forget, America is about 50 years behind Europe, so take pity on us.
   / What to use Carry-All for (other than carry-all) #37
I showed my wife a good time today and we cut wood. Put the Hillbilly Carry All to good use
   / What to use Carry-All for (other than carry-all) #38
My carry-all was originally a hog & pig carrier I rescued from the weeds. I use it mostly without the sides to haul my 25 gallon 12v spot sprayer & battery. Great for spraying from high up in the tractor seat along wood lines, fences, and the pond edge.
This is similar to what it once was:
   / What to use Carry-All for (other than carry-all) #39
My carry-all is from Omni MFG and small but versatile.
On the Toolcat 3 point receiver hitch:
On the top receiver hitch:
Carrying hay on the EV's front receiver hitch:
And the storage dolly:
   / What to use Carry-All for (other than carry-all) #40
I have previously posted on TBN that I farmed up to 3000+ acres with another 2000 share farmed in several countries and never had the need for a FEL, briefly owning one in the late 1970s, but a link box was essential on all of them - the last 18 years in Portugal (until I retired 2 years ago) where I had exactly the same box as the photo.
The "carry-alls" shown in some threads are not the same thing, and would have been fairly well useless for the jobs I did with my link box. No doubt they could be modified into something as useful though.
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A54865)
2004 Ford F-350...
2018 COMPTANK ACID TRANSPORT TRAILER (A55745)
2018 COMPTANK ACID...
2015 BIG TEX FRAC WATER TREATMENT TRAILER (A55745)
2015 BIG TEX FRAC...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
