What to park outside?
/ What to park outside? #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I have a bit of a dilemma. With my purchase of a new used MF 255 I have now officially reached the point where all my equipment cannot fit into my shop.
I kept trying to convince myself that if I reorganized I might manage it. Does not look good. One of my manure spreader (NI 210) or the MF 255 will need to be stored outside as a result.
My first instinct was the manure spreader as it cost me less. Then I started thinking about the fact that it has a wood floor and would be better out of the weather as a result. Many a old farm tractor has spent its life outside and not been too badly off for it.
What would you do if you were me? (building a new building is not an option at this time).
/ What to park outside? #2
Since you cannot spread on the snow, and it will not see much use on the winter, why not grab a tarp from Princess Auto, throw some Boards across the top of the spreader( so it will not fill up) and tarp it?? Park the MF inside.
/ What to park outside? #3
Since you cannot spread on the snow, and it will not see much use on the winter, why not grab a tarp from Princess Auto, throw some Boards across the top of the spreader( so it will mot fill up) and tarp it?? Park the MF inside.
My thoughts, exactly. It appears to be a positive and cheap solution for the time being, until your budget allows you to do otherwise Good Luck.
/ What to park outside? #4
I 3rd that. Tractor should stay dry! :thumbsup:
Now why didn't I think of that!
I vaguely recall a thread suggesting not to tarp over equipment due to condensation developing and that wrecking the equipment over time. Any thoughts on this angle!
/ What to park outside? #8
Tarp the top with some overhang but minimize tarping the sides for airflow
/ What to park outside? #9
Or if you have some metal siding from a barn you can cover the spreader with that. Having the spreader covered is certainly better for it and leaving it uncovered. :D
/ What to park outside? #10
Exactly. Tie it so it will not blow off. You only want too keep the snow out of it. Spray it with fluid film just before you tarp it.
Do not park it on grass, if possible.
/ What to park outside? #11
Mop down the floor with some of your used hydraulic fluid and cover with tarp as suggested, spreader will be fine outdoors.
/ What to park outside? #12
A new building may be out of the question, but is a 'lean to' doable?
/ What to park outside? #13
Keep the equipment off the ground (I've used cinder blocks and 6x6 landscape ties) and use a canvas tarp.
It's the plastic tarps that really hold in condensation.
I also spray any parts that move or rotate with Fluid Film or something of that nature. Although I like WD-40, it doesn't hold up long enough for winter storage.
/ What to park outside? #14
Agreed!! WD40 is the last thing you want to use for winter storage.
Canoe, do you own a undercoating gun??
/ What to park outside? #15
Common problem with semi grain trailers. If tarped for winter rots inside the tarp..often better open to the elements !
Most equipment that has been exposed to fertilizer gets a pressure wash then a run past the diesel tank and soaked with the nozzle before storing ..inside or out .
With the cost of shops thesae days your seeing more and more $300'000 combines stored outside winter is,nt the problem it's the spring is the trouble when the thaw melts into everything !
/ What to park outside? #16
I do just like suggested, manure spreader stays outside but under one of those canopy thingees. I give it a good wash, make sure it's dry then park it up on pallets and spray it with either fluid film or used oil. Before I had the canopy thingee I put boards and used roofing tin over it and all was well.
These seem like some excellent ideas. I just invested in a pressure washer as well and can't believe I lived without one so far!
Good thing I asked about the tarps and condensation.
I am still somewhat nervous about tarping over it as the bottom is closed. I can certainly just tarp over top of the box and the beaters but still keep some room open at the rear so that air can get into the box without much snow.
The spot I have in mind has a building on one side (my dog kennel), neighbours fence on the other side, 3ft retaining wall behind and mature trees covering the whole area. Probably about as good as you can get for outside storage.
Don't have an undercoating gun but it seems like a good idea. I imagine you are spraying fluid film with this Will? Alternatively I could use a few of the Aerosol can's every year.
The spreader is probably an ideal implement to store outside as my spreading is concentrated around a couple weeks in late fall and thats it.
I imagine I should keep it tarped or covered with roofing material all year until it is time to spread?
BTW Will - where do you source the Fluid Film from around here? Does PA carry it?
/ What to park outside? #19
This will be the first year we are spraying with Fluid Film. Used Rust check from CDN tire previously. TSC sells it in the spray can, quart, and gallon. I bought the undercoating gun from Car Quest a few years back, as we undercoat everything annually.
/ What to park outside? #20
Definatly keep the tractor in ... as for the manure spreader. When your done use old motor oil and soak the wood floor, grandad and dad always did this and that darn floor stayed in very good shape.
I would also oil the chains with old oil, the levers and any moving parts and grease her good.
I would not tarp it. Thats just me.
