What Size box blade?
/ What Size box blade? #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
With my L2500 (about 28hp, 2400#) I'm first thinking a 4'. It'll get used in some sandy loam bot also plenty of clay. I just started thinking aobut the 5' but it might be to much. I'd rather get a more usable 4' than overload with a 5'. A 4' won't cover all my tracks but I'll take that over one that's to big for my tractor. I will be using it to dig and move, not just grade light stiff.
Thanks,
Rob
/ What Size box blade? #2
I'd go with the 5' myself. For many of your applications, you'll be able to use it normally, and in some cases, you may have to take smaller bites, or boxloads, or maybe lift a couple of rippers out of the ground, but the 28 HP should be able to handle it.
A heavy duty guage box may be pretty heavy, and the Kubota is not real weighty, but I still think you'd be happier with the 5' light to medium duty.
It's aggravating not to be able to get the end of your box up against walls and fence lines which you'll experience with the 4'.
John
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
BULLDOG INDUSTRIAL 9000TB GAS GENERATOR (A64281)
BULLDOG INDUSTRIAL...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
