What max engine RPM to use?
/ What max engine RPM to use? #1
SnowSeb
atlantic canada
Kioti CK30HST
What would be max rpm to for CK30HST for transportation where speed is important, but without causing any problems or premature wear... I need drive a good amount snowblowing about 35 driveways. I usually go with about 2300rpm for road transport. It's never fast enough, LOL, but then again its a tractor, not a sports car /forums/images/graemlins/grin.gif
/ What max engine RPM to use? #2
I drove both my Kubotas and the neighbor's Oliver quite a bit on the road and always ran them at least PTO speed, and usually full throttle.
/ What max engine RPM to use? #3
I run full throttle.
If I'm going down a steep hill where the weight of the machine pushing against the motor may try to overrun the engines governer (trys make the motor rev to high). I back off the throttle. Once a the bottom of the hill its back to full throttle.
/ What max engine RPM to use? #5
Seb how much did you pay for your CK30 HST with FEL.Also is it 54 or 60 bucket you have on there...cag
46001CFL (A59230)
46001CFL (A59230)
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
