What material for ford 1700 subframe?
   / What material for ford 1700 subframe? #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
I'm getting ready to fab up a subframe for my Ford 1700 / LW-6 backhoe. Thinking about 2x2 or 2x3 tubing with 5/16 wall. Seen some where it was flat plate but tubing might weld better.
Thanks!
Brian
Well the square tubing didn't pan out, limited supply, have to buy full sticks ect. But I did find a stick of 3x4 angle 1/2 inch thick. Thinking that might work better any way.
Comments?
Brian
   / What material for ford 1700 subframe? #3
4" C channel is what mine is made of if I remember correctly.
On the pictures I saw on the Ford 758 bh frame it looked to be 4 x 2 channel with some boxing near the axle. Looks to be 3/16 to 1/4 thick material. The 4 inch is vertical X 2 horizontal. Any where close to yours?
Thanks!
Brian
(cropped pic from ebay)
   / What material for ford 1700 subframe? #5
Here's some pics and info for the Ford #8401 Sub Frame. This frame is supposed to fit Ford 1320,1520,1720, & 1920 models. Not sure if 1700 is the same but probably similar. This frame is on a Woods BH750-3 I bought and adapted to fit my tractor. It is made of C Channel but it has several sections of flat steel welded in the C to box it in for strength.
  • Ford 1320-1920 Sub Frame.pdf
   / What material for ford 1700 subframe? #6
Measured the channel on mine and it's 5"x1.75" x 3/16". The first 3'of the frame is boxed. (End closest to the hoe.) If you do a search I posted a bunch of pics a while back.
Thanks for the pics and information. Have a bit more to think about before I buy any more steel. Quite a bit of info in just a few posts.
Brian
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
