What material for ford 1700 subframe?
   / What material for ford 1700 subframe? #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
I'm getting ready to fab up a subframe for my Ford 1700 / LW-6 backhoe. Thinking about 2x2 or 2x3 tubing with 5/16 wall. Seen some where it was flat plate but tubing might weld better.
Thanks!
Brian
Well the square tubing didn't pan out, limited supply, have to buy full sticks ect. But I did find a stick of 3x4 angle 1/2 inch thick. Thinking that might work better any way.
Comments?
Brian
   / What material for ford 1700 subframe? #3
4" C channel is what mine is made of if I remember correctly.
On the pictures I saw on the Ford 758 bh frame it looked to be 4 x 2 channel with some boxing near the axle. Looks to be 3/16 to 1/4 thick material. The 4 inch is vertical X 2 horizontal. Any where close to yours?
Thanks!
Brian
(cropped pic from ebay)
   / What material for ford 1700 subframe? #5
Here's some pics and info for the Ford #8401 Sub Frame. This frame is supposed to fit Ford 1320,1520,1720, & 1920 models. Not sure if 1700 is the same but probably similar. This frame is on a Woods BH750-3 I bought and adapted to fit my tractor. It is made of C Channel but it has several sections of flat steel welded in the C to box it in for strength.
  • Ford 1320-1920 Sub Frame.pdf
   / What material for ford 1700 subframe? #6
Measured the channel on mine and it's 5"x1.75" x 3/16". The first 3'of the frame is boxed. (End closest to the hoe.) If you do a search I posted a bunch of pics a while back.
Thanks for the pics and information. Have a bit more to think about before I buy any more steel. Quite a bit of info in just a few posts.
Brian
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
International Farmall 856 2wd Tractor (A52128)
International...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
