What kind of welder should I buy
   / What kind of welder should I buy #11
I think people are mixing terms. When a mig welder says flux core or gas it means it will weld with wire that has a core of flux so shielding gas is not needed or solid wire with a gas shield. Some MIGs (metal inert gas) units are not set up for gas flow (timed pre and post purge and valves etc). There are gasoline powered welders. Good for mobile jobs. TIG welders are (Tungsten Inert Gas) and use a tungsten tip and an inert gas (Helium Argon) shield over the arc. Good for welding Alum. on AC and Stainless on DC and small parts and intricate welds.
What we call Stick is GMAW Gas metal arc welding and the flux covered rod produces the shielding gas. Stick welders can be AC and if you pay more AC/DC. Heliarc is actually a trade name for TIG back when they used helium gas for Aluminum.
I would recommend a AC/DC stick machine or a wire feed MIG unit that is capable of adding gas in case of welding Aluminum or Stainless.
DC stick will be the easiest to learn and you will look like a pro in no time because of its stable arc. AC takes a little more attention to joint prep and rod selection. Once again, a good machine with good stable open circuit arc voltage will help. 110 volt buzz boxes are not the ticket here.
   / What kind of welder should I buy #12
Follow MadReferee's lead here partner. A welder such as the Miller or a Hobart in the 175-185 amp range and using "flux cored wire" will do you fine. AND...if you cant get it to "stick"..so that the welded part cant stay together and function...just give it up! Its that easy.
Using solid wire and gas with it ( and easy change-over) allows you to make a weld that looks like a "pro"...but also allows you to weld AL...SST...and castiron!! ( with the proper wire material of course.
Ive started with a Hobart 140...that only need 110V..and will only do 1/4 inch thick stock with a double pass...BUT..for "MY USAGE" it seems to do fine. Should I dicover that in the future I need MORE...then I'll convert my little machine to MIG and use it with the gas on thin sheet metal jobs...and use the JMBO on much heavier material using flux cored wire.
I CANT ARC WELD AT ALL.....unless you call sticking the rods all the time "welding"..:)
   / What kind of welder should I buy #13
Don't believe a 110/120 Volt welder won't do the job. The people making those statements probably haven't used an inverter welder and are basing those statements on transformer welders. Inverter power sources are far more efficient than transformer welders. Also, most of the inverters are "auto linking" meaning you can use them on multiple voltages without making internal jumper changes.
This means if you have to run on 110 / 120 you can do that at a reduced output, but if you have 220 / 240 available, you can use that voltage with an increase in output.
A Miller MaxStarr 150 will put out 100 amps at 115 Volts and 150 Amps on 230Volts. I own the MaxStarr 140 (prior model to the 150) and have used it on 120 Vac to weld 3/8-inch metal. The bonus is the size and portability makes it far easier to use than the transformer welders. The Miller Passport MIG will output up to 140 Amps on 110 / 120.
Also, weld joint preparation can have a great effect on the final weld. It is possible to weld 3/8-inch metal with a 110 / 120 Vac MIG welder if you prepare the joint correctly, make a good root pass and then finish the weld with two filler passes.
Technique is just as important as equipment. Granted, a high output welder makes it easier to weld thick metal, but, you have to evaluate how much you're going to weld and the thickness of metal.
I have a 300 Amp multi-process welder, a 180 Amp TIG, the MaxStarr 140, a 40 Amp plasma cutter, and a gas welding setup. But, I could probably do about 70% of the arc welding I need to do with the MaxStarr - including lift TIG.
Welding steel with a MIG is easy, in fact poor weldors look like good weldors. If you want to weld stainless with a MIG then you have to change gasses to pure Argon or a different Argon mix as the CO2 in a 75/25 mix will make the weld brittle (the C in the CO2 adds carbon to the weld).
Aluminum is best left to AC TIG or stick. The AC provides cleaning on the aluminum surface - it breaks up the suface oxides so the weld material will adhere to clean metal. The term AC welding is often misunderstood. It is not using alternating current. It is in fact direct current welding with the electrode and surface changing polarity (DC - electrode negative / DC - electrode positive) = DCEN / DCEP - this IS NOT AC current being used for welding.
AC with stick for steel welding is often used for out-of-postion welding because the alternating polarity allows the weld metal to cool slightly before the next heating cycle so the weld bead does not run or drip as easily.
Now for cast iron. That one's really difficult and best left to professional weldors, unless you want to play around and the final result doesn't matter. Brazing cast iron is relatively straight forward using a torch. But, welding is difficult unless you use special alloy welding materials, pre-heat the area, and then carefully cool it. Cast iron is a "dirty" metal in that it will have carbon inclusions in it that can make the weld area very brittle and susceptible to cracking.
If you have 220 / 240 Vac available, have about a $1800 budget, and want to make it easy on yourself - then, by all means go straight to a MIG machine like the Millermatic 210 or equal.
I poked around some of those welding sites and 50% of what they saying was greek to me. However, it is seeming like what I need may be a MIG welder in the 170-200 range that will work fine with a 40 amp breaker. The thought of one machine being able to do simple steel welding and also do aluminum is important for the future. I was thinking of a budget of $750 for the welder, cart, gas tank, helmet and a small amount of wire to get started. Other tools and wiring the shop were not included in that budget.
I will continue to do some research on the MIG welders. Would it be safe to assume that the consumables don't cost much? How much are the solid or flux core wires? If I welded some angle steel together and made fifteen 2" long welds (30" total bead length) could this be done on $20 or less in wire?
Is there a rule of thumb on the wire like $0.50 per foot, a dollar per foot, etc
Madreferee: I'm kinda slow, but I still don't understand where you can get 175 amps out of a 240 volt 40 amp breaker. V*A=W
Does this welder work at less than 120 volts? I can see 40 amp breaker service being run up to 175 amps, but only if the working voltage is dropped to something like 25 volts Please be patient-I'm trying to learn and none of the welding sites explained this.
   / What kind of welder should I buy #15
you can get 250 amps out of a 240 v 40 amp breaker. I think it has something to do with the transformer in the welder. I learned on a stick so a stick is easer for me . Keep in mind that if you are going to weld on stuff that may be rusty or painted that the metal will have to be cleaned to weld with a mig. With a stick & a 6011 rod you can weld over most anything. I do have a mig ,but I use the stick most of the time.Good luck to ya :)
   / What kind of welder should I buy #16
Now you have it figured out...The voltage is usually 22-30v or so...
Go to the Miller site in this link...
Miller - Welding Library, Safety Resources and Welder Eduation
and look at the left hand column. It has a online beginners course that will answer your questions. Look in the "Welding Dictionary" and the "Understanding Electricity in Welding"
   / What kind of welder should I buy #17
Raise your budget to $1500 to $1800 and you can get a good 210 amp MIG with all accessories. Then you can add a spool gun at a later date to do thinner aluminum.
For years I fabbed many, many projects including a landscape rake using a Miller 175 MIG. I finally upgraded to a Miller 251 when I needed the extra power for use with thicker steel. The 175 would do the jobs but it required multiple weld passes which was getting kinda repetitive for some of my jobs.
Generic solid wire is between $2 and $2.50 per pound in 10 lb rolls. Flux core wire is about $3.50 - $4 per lb. Gun tips are cheap but you WILL need some. That's it for basic consumables.
I believe kennyd answered that by pointing you to the Miller Education site.
   / What kind of welder should I buy #18
I have the Hobart 140 you mentioned. It is a great welder for me and I taught my self how to weld on it. I use it off of a regular 110 plug on my carport and it also runs off of my 3500 watt Craftsman generator when I am up at the cabin in the woods.
I have not converted it to shielding gas yet but spatter hasn't killed my welded projects yet. I currently just buy the flux core wire for it.
I have welded some rather thick pieces of metal with it and the welds are still holding strong. A lot of this is technique and preparation.
Attached is a pic of one of my simple projects that I have welded recently. Good luck!!
   / What kind of welder should I buy #19
I have a Hobart 225 amp AC stick welder and for all my steel projects this works just fine. Something to keep in mind is that a stick welder will do fine outside when it is blowing and a Mig or Tig just won't keep the gas shield in a wind. If you weld with anything inside you will need a way to get the weld smoke out of the area, it smells bad and is bad for your lungs. So, inside with a fan for any kind of machine or outside for stick either AC or AC/DC.
Suggest you take a welding course before you buy with the express purpose of trying/learning on all 3 basic welding machines, MIG TIG and STICK...then make a decision.
good luck
Fabrej: was your project the orange part or just the T-handle?
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2024 CASE TV450B SKID STEER (A60429)
2024 CASE TV450B...
Club Car Utility Cart (A55851)
Club Car Utility...
KOMATSU WA270 (A58214)
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
