What kind of welder should I buy
   / What kind of welder should I buy #31
gordon21 said:
The list is getting more refined. ?
Yeah, I joined ;-).
gordon21 said:
How does this sound for an initial purchase? You guys let me know what I am missing. Nothing is definite yet.
Hobart 187 MIG welder package that comes with cart and gas valve.
1-8" spool of aluminum wire
1-8" spool of solid wire
1-8" spool of flux core wire
1-small tank of C25
1-small tank of pure argon for the aluminum
extra tips
Self darkening helmet
Couple of triangle shaped magnet gizmos to hold steel pieces
Large chunk of plate steel to use as a work surface ?
Sounds like a good setup for light welding. And I think you will be disappointed with its aluminum welding capability. Personally, I'd buy a bigger welder. A Millermatic 210 at least. I've had a Millermatic 251 for two weeks and I don't know how I lived this long without it. I'm too old to chip slag anymore. I dearly love that machine.
gordon21 said:
I read a 200 page welding basics book last night. It mentions that a good beginner work table should be a large chunk of old plate steel. Nowhere in the book does it mention how and where to ground the piece you are working on. Does the work table itself have to be grounded? If so, how and where?
Needless to say I am concerned about 30-180 amps running around and me not having everything safe. Would a person get shocked if they touched the work table while welding? I am assuming the work piece will be clamped to the table to keep it from moving. ?
You wouldn't get shocked unless you had the ground clamp attached to your foot or something. Attach the ground to the table and make sure the work is sitting firmly on the table and is making good electrical contact (clean metal to metal, no painted surfaces between work and ground, etc.). The work doesn't necessarly have to be clamped to the table. If the work piece is big enough, attach the ground directly to the work.
gordon21 said:
What effect does the welding have on a tractor that is insulated from the ground by it's tires. Do you just hook the ground cable to it and let-er-rip? Any special precautions to protect the tractor's electronics or diesel?
I'd put the work clamp as close as possible to the weld area. Find an area that is clean metal so there's good electrical contact. The current is traveling between the electrode and the ground. If there is a bearing (there is a small contact area inside a ball bearing) somewhere in that loop, the weld current will be running through it, and that would be potentially bad for the bearing. If there is a computer or any microprocessors on the tractor, they might get fried. I'd probably disconnect the tractor's battery. Other than that, normal precautions apply. The Tires on the tractor don't mean anything to the weld current. It's not trying to go to the "ground" under the tractor; it's traveling from the weld electrode to the ground clamp.
   / What kind of welder should I buy #32
Hi, I know the literature, and probably folks on here will tell you that machine will do aluminum (and it will) but personally, I would not spend the money on that part of the setup, I think you will find the results less then satisfactory (and somewhat aggravating) You can also weld aluminum with an oxy / a torch set up, it just is not that practical.
The way I try and explain it too folks is that you are trying to push a spaghetti noodle through a straw and hitting it into a piece of metal at the end of the straw. (that is welding with steel) Now go ahead and cook that spaghetti noodle (Aluminum) and do the same. You will quickly learn the definition of "birds nest" with regards to a Mig if that is the route you choose.
For me, I would buy a big bottle of C25 (or rent or lease or whatever your gas supplier does) My experience that most of the cost of the gas is in the filling, handling etc. The price difference between a refill of a big bottle vs a small bottle has been negligible. (your gas company may very well be different)
Anyway, sounds like a good plan, did not notice antispatter spray or dip, but you need a can of that.
Oh, and ground as close as possible to where you are working, the post above gave some very relevant tips.
   / What kind of welder should I buy #33
Lewis,
Since you are a "reader" here are some good books:
Welding Essentials, W. Galvery & F. Marlow ISBN 0-8311-3151-9
Welding Fabrication & Repair, F. Marlow ISBN 0-8311-3155-1
You can get some really good pamphlets mailed to you for free from Lincoln here:
Literature Request | Lincoln Electric
"Stainless Steels - Properties, How to Weld, Where to Use"
"GMAW Welding Guide"
"Aluminum MIG Welding Guidebook"
There are some others there too.
If you can't take a class, I recommend the videos/DVD's from these guys:
Instructional Welding Videos
Good Luck
PB
   / What kind of welder should I buy #34
gordon21 said:
The list is getting more refined. How does this sound for an initial purchase? You guys let me know what I am missing. Nothing is definite yet.
The Hobart 187 is getting very good reviews and would certainly be adequate for hobbiest/home use. It costs a lot more to get a bigger MIG.
You should probably consider the new Lincoln 180C as well. It costs a bit more than the Hobart (about $100 more I think) but seems to have some significant advantages based on the buzz in welding forums. I haven't seen either yet.
Both the Hobart 187 and Lincoln 180C are more advanced than any of the currently available similarly priced Millers. I presume Miller will have an update soon to the excellent but relatively outdated 175.
If you want a really neat solution and are willing to pay more, the Miller Passport will give you a very portable (40lbs) MIG with dual voltage capabiltiy and built in gas capacity. Really a nice unit but costs about double what you are looking to spend.
   / What kind of welder should I buy #35
fabrej said:
Gordon21,
I welded all of the bucket hitch. I just didn't paint the T handle.
Attached is another one of my mini projects that I welded with the simple Hobart 140.
Let's be getting that ammo box painted!...lol....*wink*!
   / What kind of welder should I buy #36
1-small tank of C25
extra tips
Gordon: IMHO..."INITIALLY" I wouldnt spend the $$ for the "aluminum" part of the list...thats YET. Not the wire..not the gas..etc. It MAY BE a long time before you get the hang of using the machine...before you start working with AL.
Toss in some anti splatter "cream"...its cheap..and it works to get and keep tips / nozzles good and clean.
I bought a Jackson AD helmut..wasnt cheap...but I love the thing.
The triangle magnets..I get from HB...when they are onsale..3 different sizes.
Other than that..Id say go for it!
   / What kind of welder should I buy #37
Don't overlook the old transformer/rectifier power supplies if money is the major issue and if you have the space. I got along fine for about 30 years with an oxyacetylene setup and a Miller Thunderbolt (AC only) with 30 feet of #2 welding leads.
I'm getting more interested in metalwork now that I have some spare time, and I want to have aluminum and stainless capability so I recently got an old used Miller Dialarc HF for TIG and a new Miller 251 for MIG. The Dialarc HF was a only a couple of hundred dollars and it weighs 500 pounds but it is one sweet running power supply. I think it was only used a few times for stick welding because the factory caplugs were still on the gas and water solenoids. Apparently the previous owner never even used its TIG function. These things are basically bulletproof. If something does break they're easy to repair and Miller still has parts for them. There are lots of old welders sitting around that are in this category.
The main thing with welding is to learn to use what you've got, whatever it may be. You can learn more in a couple of hours hanging around in a vocational school welding class than you can learn in dozens of hours reading books. When you see it done you get an idea of what is possible and practical. You will get a "feel" for it. Kind of "one with the flow" of the electrons (little joke ;-) ).
For instance, I once saw a brazing demonstration by an expert. All he had was an oxyacetylene rig and some bronze rod and a can of flux. But he was the consummate artist. He could repair just about anything using bronze. He had so much experience that he could sense the temperature of the metal and could predict its behavior. If it was steel, brass, or cast iron he could fix it or make a joint with brazing rod. His main trade was making bronze jewelery and pieces of art. Watching him work was an education in itself.
   / What kind of welder should I buy #38
gordon21 said:
I could care less about the final bead appearance. I am looking for functionality, not looks.
a good functional bead will look good. but a good looking bead may not be functional
Here goes the questions:
Electric or gas? And what's the basic difference in the results they give
electric is just that runs off electricity, the other i think your talking about is engine driven. you have a diesel or gasoline engine driving a generator to make the electricty to weld with.
MIG, TIG, various gases, etc
MIG stand for Metal Inert Gas it is also know as GMAW or Gas Metal Arc Welding, TIG is Tungsten Inert Gas or GTAW Gas Tungsten Arc Welding
Can one welder do steel AND aluminum?
yes a good wire feed machine can do both. You will need the appropriate gas and regulator and the appropriate filler metal.
Which is safer to use?
any can be dangerous all can me safe
Which is easier to use?
i personally think that MIG (wire welding with sheilding gas) is by far the easiest.
How do you keep from getting electrocuted when electic welding?
dont stand in water :D :D
What is wire feed welding?
Wire feed welding is GMAW it is where the filler metal is in the form of a spool of wire and as you weld it constantly feeds more filler metal out.
Suggested rods?
6010 or 6011 and 7018 will do just about any mild steeel welding you would need to do with SMAW (Sheilded Metal Arc Welding)
Portability? Electric welders obviously need power close by. 120 or 240 volt?
The engine/generator type are much more portabel but are also much more expensive. i would go with a 240 machine with the thickness of metals you are talking about.
It comes with a gas conversion kit. How do you convert an electic welder to gas?
What they are talking about is the Sheilding gas regulator and conversion to take a wire feed welder and turn it into a true GMAW
Answers sorry i guess I should read all 4 pages before making my reply. :rolleyes: :rolleyes:
   / What kind of welder should I buy #39
Forget about doing aluminum with that welder unless you have a spoolgun and the spoolgun controller. The additional cost will be at least what the welder is. The aluminum wire is so soft that it will not flow well, if at all, thru the normal MIG gun. As a minimum you will need a seperate liner for the gun if you still plan on using AL and even then there is no guarantee that you will be able to feed the wire on a consistent basis. Welding AL also takes plenty of practice and with that small of a welder all you will be able to do is 11 gauge sheet or less. So skip the AL and the pure argon tank. Put the money toward a good 4" or 4.5" grinder and some wheels.
Stay with flux core or solid wire with C25. When you get real good at steel then either get a spoolgun/controller or a TIG for the aluminum.
   / What kind of welder should I buy #40
I second what Madref just said. Save the extra for a band saw. You do have one, right? A hack saw will wear you out cutting all that steel?
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
CAT930K (A58214)
CAT930K (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
