What is wrong with this idea
/ What is wrong with this idea
yeah .... and another ohhhhhhhhhhhhhh 17 thousand and another 10 thousand for all the new to..necessary/must have/can't live without them more costly attachments ... right Mr. M.R.?
/ What is wrong with this idea #12
maybe we can supercharge the PT or add nitrous oxide
/ What is wrong with this idea #13
<A target="_blank" HREF=http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&langId=-1&catalogId=4006970&PHOTOS=on&TEST=Y&productId=405826&categoryId=85> Northern Tool</A> has a nice 3 cyl Diesel 27HP high torque engine that would probably solve your problem for only $3600. Now you would have to get creative on where you mount the radiator. And you will need to use an electric fan for the radiator because you will need both the front and rear PTO's for the pumps. Otherwise, with a good smoke wrench and a little patience, it shouldn't be much of a problem. Come on Hans, you can do it!
/ What is wrong with this idea #14
Now that would be cool, you would have wherrr of the hydraulics and whistle of the supercharger. Or maybe you could find an old goldwing motor cycle and drop that engine there.
/ What is wrong with this idea #15
Can't you just put the walk behind mower in neutral and push it with the Power Trac?
Mr. M.R. that is a good idea, but my mechanic inventor friend Francis had another one today, while i was out earning a living. your idea would have worked fine. the exmark walkbehinds hydros don't have a real neutral. you would have to open a valve on the two wheelmotors to freewheel like you do when you move a dead mower around the garage.
but today Francis had the surprise of the day for me, back behind his old cowstable where we keep the small and not so small tractor junkyard he pointed at a 17 hps motor and said, that will finish two of your winter projects.
one: the multiflora distroyer and two: to give the pt 60" finish mower another chance. i have to come to hate this mower, the belts go way too fast, two in 300 hours of mowing and three central spindle roller bearings; plus the degradation of output (blade tipspeed) going up hills.
one, the multiflora destroyer is an old machine to cut off small trees and multiflora bushes. it looks very much like an old walk behind rototiller. except it has a shaft pointing out to the front with a sawblade mounting (ripping blade) propelled by two belts.
Francis is going to cannibalize the pt 60" mowers hydraulic motor. we then will combine the saw blade mount of "one" onto a tubular frame which will be welded to another trailer receiver and fit into the before described pt quick attach plate we made last fall, which fits the leaf rake, the 11+8hp little wonder blower buggy, the trailer hitch to move the various trailers around the yard and the "cheap snow plow".
the power source will be the cannibalized hydraulic motor from the pt mower.
two, will receive a face lift. we will install front lawn tractor wheels in front and back with the ability to swivel, rather than plow the turf. we will also install anti scalp rollers. one in the front center and two to three in the rear of the deck. this next mod. is just a dream i would like to fulfill (to reduce the chaffing problem we will try to install a horse stable mat strip all a long the rear of the mower and cut open the right side of the mower, to foster some side discharge). we then will install the 17 hps engine and slightly redesign the pt quick attach situation to accommodate the engine and still warrant proper mowing/pushing and swiveling ability of the redesigned attachment/mower.
someday, we in the landscape business use these great little machines, hope that Ed and all the rest in Tazwell will hear us and put a 30 hp Deutz in that so able, agile piece of equipment. for the landscaping work we do, always in tight spots, muddy grounds, delicate turf, this is the size machine we need just more "umpf".
it may come to that some day when the Kohler engine goes. in our business they last about 1800 to 3000 hours when mainly used at full trottle to upkeep optimal blade tipspeed.
but i think i would put a Deutz or a Kubota engine in, since i already have one Deutz and two Kubota diesels.
there will be another midatlantic pt test pilot meeting, we are getting together with our lawyer, Charlie, because we are going out on strike .... not enough snow to plow .... yet.
i will take some of these inventions with me and hope that this time we won't forget to ask Charlie to take some pictures of some of our mods.
/ What is wrong with this idea #20
Hans, thanks for the morning wake up! /w3tcompact/icons/laugh.gif
Sounds like lots of projects going on there. Can't wait for some pictures and your commentary. /w3tcompact/icons/smile.gif
Bobcat MT85 (A60462)
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A60736)
2021 QUALITY...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
2018 FORD TRANSIT VAN (INOPERABLE) (A60736)
2018 FORD TRANSIT...
2014 Ford F-350 XL (A60462)
2014 Ford F-350 XL...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
