What is the name for a Sub surface plow?
   / What is the name for a Sub surface plow? #11
We subsoil for the opposite reason. It opens up the subsoil layer so moisture can rise during the hot dry conditions.
It’s also good to do before winter so that moisture can penetrate deep into the soil.
   / What is the name for a Sub surface plow? #12
I also cut channels with a sub soil shank around our berry bushes, and trees... This to attract, and keep maximum moisture near..
I plan to build a homemade shank with a mole plow type head to leave a better channel than the sub soil shank provides..
You will need a subsoiler specifically designed for the limited TPH vertical adjustment on subcompact tractors.
TPH? I do not know that term. Can a
King Kutter Sub Soiler SUB RR be used? It seems to have a much narrower plow. Thanks​
I considered a "home made." Bolt-on attach to rear of box scraper?
2015 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A52707)
2015 CATERPILLAR...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(APPROX 7) 10" X 20' CHANNEL IRON (A57192)
(APPROX 7) 10" X...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2018 CATERPILLAR 336FL EXCAVATOR (A52707)
2018 CATERPILLAR...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
