What is the name for a Sub surface plow?
   / What is the name for a Sub surface plow? #11
We subsoil for the opposite reason. It opens up the subsoil layer so moisture can rise during the hot dry conditions.
It’s also good to do before winter so that moisture can penetrate deep into the soil.
   / What is the name for a Sub surface plow? #12
I also cut channels with a sub soil shank around our berry bushes, and trees... This to attract, and keep maximum moisture near..
I plan to build a homemade shank with a mole plow type head to leave a better channel than the sub soil shank provides..
You will need a subsoiler specifically designed for the limited TPH vertical adjustment on subcompact tractors.
TPH? I do not know that term. Can a
King Kutter Sub Soiler SUB RR be used? It seems to have a much narrower plow. Thanks​
I considered a "home made." Bolt-on attach to rear of box scraper?
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
UNUSED PABREAK DB220 - 84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
Tortoise Statue (A55853)
Tortoise Statue...
Schulte SBW800 Rock Windrower (A57024)
Schulte SBW800...
UNUSED JCT 84" HYD DOZER BLADES (A57193)
UNUSED JCT 84" HYD...
