What is the name for a Sub surface plow?
   / What is the name for a Sub surface plow? #1
nickzim
Spencer, IN
Kubota BX25
Several years ago I borrowed a 3-point equipped mini-dozer. On the rear it had what I would describe as a sub-surface plow. It looked a lot like a long scarifier or cutter from a standard grader box.
In essence you could lower it several inches into the ground and it carved out a tunnel if you will. It allowed yard drainage without digging a ditch. I ran several passes down my hill and it pulled off a lot of runoff water
I suppose it could have been a custom build. I've tried to do this with my grader box but depth is not very deep. In addition if dragging only one scarifier, there is a lot of side load on the 3-point. I'd like to buy one. don't know the name to search for it. Thank for your time
   / What is the name for a Sub surface plow? #2
sub soiler
   / What is the name for a Sub surface plow? #3
Yup....in tractor lingo it's a subsoiler.
If you had something similar on a dozer it was probably called a ripper.
   / What is the name for a Sub surface plow? #4
Subsoiler and when you attach a plow point to it we call it a middle buster. Nowadays the subsoilers are much different than the old ones in that they go much deeper and have trip functions or shear pins on them.
   / What is the name for a Sub surface plow? #5
You will need a subsoiler specifically designed for the limited TPH vertical adjustment on subcompact tractors.
Ah, the internet can be a wonderful place. Thanks All! I suppose the trick is knowing where your powerlines and such run 1st :)
I've got a Kubota BX-25. I saw one mention of a shear pin. On the one I borrowed years ago I folded the center link. Had to buy a new one.
Or I guess I could have been an Axxhoxe neighbor and returned it broken.
   / What is the name for a Sub surface plow? #8
Yea, on my place if I'm running a 2 or 4 row subsoiler bedder I'm constantly hooking old fat lighter stumps. Some will pull out and some will shear a pin or trip the plow.
   / What is the name for a Sub surface plow? #9
Mole plow, Mole ripper.
I first learned of a mole plow (or plough) in a British video about old methods of drying out wet fields.
   / What is the name for a Sub surface plow? #10
We subsoil for the opposite reason. It opens up the subsoil layer so moisture can rise during the hot dry conditions.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
183 (A52705)
183 (A52705)
Midwestern Industries MEV Screen Model MEV 5X10-2 (A57024)
Midwestern...
2020 Sellick S80 (A53317)
2020 Sellick S80...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
