What is the name for a Sub surface plow?
/ What is the name for a Sub surface plow? #11
We subsoil for the opposite reason. It opens up the subsoil layer so moisture can rise during the hot dry conditions.
It’s also good to do before winter so that moisture can penetrate deep into the soil.
/ What is the name for a Sub surface plow? #12
I also cut channels with a sub soil shank around our berry bushes, and trees... This to attract, and keep maximum moisture near..
I plan to build a homemade shank with a mole plow type head to leave a better channel than the sub soil shank provides..
You will need a subsoiler specifically designed for the limited TPH vertical adjustment on subcompact tractors.
TPH? I do not know that term. Can a
King Kutter Sub Soiler SUB RR be used? It seems to have a much narrower plow. Thanks​
I considered a "home made." Bolt-on attach to rear of box scraper?
2008 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2008 Chevrolet...
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
Unused 2025 HD Trailer Solutions EQ17.5 20ft. 8 Ton T/A Equipment Trailer (A59230)
Unused 2025 HD...
TANK MANIFOLD (A58216)
KBH Tank Trailer (A61307)
KBH Tank Trailer...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
